Pose Randomizer [Commercial] - Compatible with Genesis 8 Female
2»
  • RiverSoft ArtRiverSoft Art Posts: 6,780
    Yea!  Now that Genesis 8 Female is out, I can finally announce my new product, coming out tomorrow (though date may change, legal argle bargle, blah, blah)
    https://www.daz3d.com/forums/discussion/175756/coming-tomorrow-bone-doctor-pose-control#latest
  • SF-DesignSF-Design Posts: 987
    so bone doctor is also a pose randomizer?
    No, Bone Doctor is not a randomizer.  It is a set of scripts for improving and modifying poses you have.  The two products complement each other.
    Pose Randomizer was designed to work with Genesis 8 Female.  It won't show up in Smart Content because the metadata for Genesis 8 Female didn't exist at the time, but it has been coded for and tested with the new figure.
    Eye Clock Pose Control also works with and was designed for Genesis 8 Female.
  • ArtiniArtini Posts: 10,297
    Great, I have bought Eye Clock Pose Control too, so I can play with the new Genesis 8 characters, as well.
    That is awesome.  Thank you for supporting me. I wish Daz had a loyalty customer program smiley
  • My wallet is sad, but my creative mind is estatic!  I've been longing for something like this and the Bone Doctor plug in forever!!  Thanks for the hard work!
    You are very welcome!
  • dHandledHandle Posts: 617
    edited August 2017
    As I mentioned in the Pose Blender thread, I bought Blender and Randomizer last night.
    I'm having the worst time getting them to work.
    I loaded up G3F, put a pose on her, and ran the script.
    Got an error:
    here is the log file:
    2017-08-17 14:05:41.896 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/pose randomizer/randomize pose.dse
    2017-08-17 14:05:41.946 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-17 14:05:48.317 WARNING: Script Error: Line 86
    2017-08-17 14:05:48.317 WARNING: ReferenceError: Can't find variable: SetValueInRange
    2017-08-17 14:05:48.317 WARNING: Stack Trace:
     <anonymous>()@C:/Users/Public/Documents/My DAZ 3D Library/data/RiverSoft Art/Common/RSRandomizationFunctions.dse:86
    2017-08-17 14:05:48.319 Error in script execution: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/pose randomizer/randomize pose.dse
    Edit to add:
    I went back and tried to randomize a pose from the shoulder down on the same G3F figure.  I clicked on and highlighted the right shoulder.  Then I tried to run the Selective Randomize Pose script.  Again got an error.  However, this time, the script window did come up.  The error happened when I clicked "accept".  Nothing appeared to happen when I clicked "preview".
    Here's the error log file, (including errors from the earlier trial)
    2017-08-17 14:06:05.271 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2017-08-17 14:08:09.613 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2017-08-17 14:10:25.711 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2017-08-17 14:12:33.344 Loading script: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/pose randomizer/selective randomize pose.dse
    2017-08-17 14:12:33.395 WARNING: libpng warning: iCCP: known incorrect sRGB profile
    2017-08-17 14:12:36.953 WARNING: Script Error: Line 147
    2017-08-17 14:12:36.953 WARNING: ReferenceError: Can't find variable: InitBodyParts
    2017-08-17 14:12:36.953 WARNING: Stack Trace:
     <anonymous>()@C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/pose randomizer/selective randomize pose.dse:147
    2017-08-17 14:12:36.954 Error in script execution: C:/Users/Public/Documents/My DAZ 3D Library/scripts/riversoft art/pose randomizer/selective randomize pose.dse
    Post edited by dHandle on
    Working with you by email.
    Pose Randomizer is compatible with Genesis 8 Male.
    Got an error:
    Edit to add:
    The fix that addresses this is now live in the Daz Install Manager
    Yeah, I saw that when I picked up the weekly freebie earlier today.  Thanks for that!
  • Can you add the ability to randomize the Hip bone's Transformations too? The script doesn't seem to affect it at all. It will really expand the possibilities of poses, if this feature gets implemented
  • barbultbarbult Posts: 26,179
    I'm having a bizarre problem with the Randomize Pose script. I applied it to a G8M character that was in the default pose. I had Modify Used Parameters Only checked. His pose didn't change when I hit Preview. That is understandable, because I didn't have any "used parameters". But what did happen is that when I hit the Preview button, a previously deleted item was restored to my scene. It was like it was processing the Undo stack. Every time I hit Preview, it was like another Undo was processed.
    Yes, this can happen.  In order to "rewind," the script randomizes stuff and saves the changes to the undo stack.  If you then hit preview again, it undoes the preview randomization, then randomizes stuff, etc  If nothing is randomized/changed, Daz does not put anything on the undo stack when the script asks it to, so the undo rewinds accidentally farther back on the stack.  It was enough of an edge case that I never bothered to fix it.
    Thanks for the reply and explanation. You can imagine that I was quite surprised when the posing script started loading characters into my scene! Now I am aware of the problem and how to avoid it, I think.
