Can I make a figure of a prop?
Is there a way to make a prop or hair item into a figure wich conforms to Genesis?
I think it should work if you use the transfer utility. Maybe use the 'Convert prop to figure...' command in the geometry submenu in the edit menu. Not sure, though.
thank you. "convert prop to figure" works great :-)
NO YOU MAY NOT! I forbid you to do it! You absolutely MUST NOT! :P :P
But have fun doing it anyway :)
What you might try doing is go to r.com or wherever, download clothing and translate it to Genesis. You'll need Victoria 4 shape for Genesis or Michael 4 shape for Genesis depending on the clothing you're converting. I found doing this helps one understand how conforming anything works with Genesis
Parden?
