MEC4D PBS shaders vol.2 -Released- [Commercial]
1293032343547
  • RAMWolffRAMWolff Posts: 10,343
    That's an awesome tip Cath.  thank you!
  • HoMartHoMart Posts: 487
    MEC4D said:
    That's cute little guy , is that Polish;s new mini car ?
    Yes, youre right - its "Mini Car Nino"
    I´d love to have one in RL - but, living in one City Centre without own carport, I´d have to throw a powercord from 1st floor to charge it ... crying
    foregot to write - I used "Lekkulion" Mat3 in the translucency of the "grey Alien"
  • Richard HaseltineRichard Haseltine Posts: 107,911
    L'Adair said:
    Newbie question here, (and yes, after a mere 1.5 years toying with DAZ, I'm still a newbie in so many ways...)
    What is the difference between "Fabric" and "Procedural Fabric"?
    Procedural usually means something that is generated from data not a texture (or geometry, in other situations) - the advantage being that a procedural material is scalable without risking loss of quality and has a much smaller memory requirement.
  • barbultbarbult Posts: 26,177
    MEC4D said:
    I was expecting it will expire, going to send you the new password right now
    AND WELCOME BACK !  you was missed around !
    barbult said:
    Cath, I'd really like to play with these, but the link you sent me expired before I got back from vacation, and Daz has not added the product to my library. Could you please give me a new link where I can download them as prize for participating in the St. Patrick's Day contest? smiley
    Thank you for the new link and password. I have downloaded and installed them. I reimported the metadata and it seems to be working fine. smiley
  • MEC4DMEC4D Posts: 5,249
    As Richard said already ..
  • L'AdairL'Adair Posts: 9,479
    Thank you. And thanks for an easy to understand explanation.
  • JerifeJerife Posts: 272
    edited April 2016
    Done, 135 iterations on 2:43 hours on an Asus Laptop W10 with an Intel i7, 8gb Ram and only one NVidia card GeForce 740M.
    As I said incredible fast shaders to render!
    I made the Pier with Vol 2 wood shaders but I am not very satified even though I used the two NormalMaps tip, have to test scaling more, so I am already saving for vol 4 (Nice woods one, right?) Metals are Brass Shell. To use vol 2 tiles for the pier roof I made a mask and used it on a geoshell as all the roof and the pinnacle is one shading domain only.
    6000x3373 downloadble image here: http://jerife.deviantart.com/art/HMSVictory-from-the-Pier-602296988
    3000 x 1687 - 6M
    Post edited by Jerife on
  • MelanieLMelanieL Posts: 7,716
    edited April 2016
    Finally had the chance to play a little with these. Not trying to win any prizes for artistic merit with these, but I'm impressed how quickly they render. I maybe should have given the glass a bit more time (this was 95% convergence).  I think I'm going to love using these laugh
    The spiders are using a variety of metal and plastic shaders. The scene uses from architectural and painted ones, fabrics, plus glass and red wine.
    Edit to fix typos.
    768 x 1024 - 785K
    768 x 1024 - 623K
    Post edited by MelanieL on
  • nicsttnicstt Posts: 11,715
    Wow very impressive.
    Very nice done, the wood need to be scaled down not up in your render ,  try to use horizontal tile value bigger than vertical to get the plank effect  , you can also change slightly the diffuse color to give it a varnish effect
    the render would be much faster done but it take a lot on the water and I guess displacement , I need to make a sea water shader for waves so you can use higher normal or displacement  with  less water destruction on the surface , if you use the water from vol.2 you can reduce the SSS amount and set the SSS Directions to higher 0.50 or 0.90 for faster calculation of the iterations
    edited April 2016
    very nice ! I love the cloth very authentic photo feel to it and very cool spiders  , also the bricks on the floor cool idea, I think you forgot to set Thin Walled ON as the glass seems not to be volumetric or the wine  , looks like thin glass to me , use the Soda Lime glass it is my favorite and of course if your system allow then Caustic but can slow down the process a little
    P.S also if you want the cloth to pass the light (Transmit to the other side below ) a little bit simulating thinner cloth then set the Scatter  to Scatter and Transmit under Translucent it will allow back scattering of the light on materials below the cloth , great for thin curtains and light clothing like thin cotton or satin
    Edit to fix typos.
    Post edited by MEC4D on
    Thanks, I will scale down and alter the ratio.
    No displacement, the water is your Fern Lake volumetric water with your Normal, clear tweaked, mounted on a 'Deep water prop' I made, essentially a black box containing the water body mass scaled A LOT on x and z axis and enough in the y one. Here is at Horizontal tiles 10 vertical 30 and some vertical offset. The time is ok considering is only a laptop and you know dinner time in Spain is done with calm wink
    Have not tried yet vol 2 waters but thats on the list, lol
    Thanks for your compliment Nicstt but is nothing beside your watch. (I've started learning Blender and know how hard to do was your great Omega)
  • Oso3DOso3D Posts: 15,085
    Here we go, almost completely vol2 shaders (except for emissives, and with a few tweaks here or there)
    (click for full image... which is a bit large)
  • JeremyDJeremyD Posts: 265
    MEC4D said:
    Thanks, it was bloom filter in Iray, and since I use my own physical camera and I guess chromatic aberrations kick in by the angle of reflection from the gold creating a flare , I use HDR for the ambient , on side point light  behind .spot light
    JeremyD said:
    MEC4D said:
    Here one more close up
    click the small thumb for full version
    Incredible.
    How do you get that nice effect that lights up the XII on the watchface?
    Good tip, I'll have to check out the bloom filter.
    That is indeed not from this world ! surreal !  you forgot to add your cool wasps wink
    You can do a lot of nice effects with from glare reflections to atmospheric effects
    JeremyD said:
    Incredible.
    Edit to fix typos.
    Aagh! You're right about the glass of course blush Thanks for the tips - I'll be sure to try them.
    edited April 2016
    I was cooking today in Zbrush Cookware to use for my new shader product Pure Metals
    and here is the result , it took me 12 hours from modeling to final render
    Click for big resolution
    1920 x 720 - 632K
    Post edited by Cris Palomino on
    edited April 2016
    I played with some of the cloth shaders. The one with the woods in the background uses an HDRI from Aversis.
    988 x 1600 - 1021K
    988 x 1600 - 991K
    988 x 1600 - 1M
    Post edited by barbult on
    Very nice @barbult even the procedural zebras and t-shirt look cool , all just the way it should be .. sorry no Tips for you  you know it all already cheeky
    edited April 2016
    I still having fun rendering pans lol
    this time for the country lovers , brushed copper, smoked glass lids and a touch of brass wink
    click for higher resolution
    1920 x 720 - 534K
    Post edited by Chohole on
    LOVE the copper pots and lids.  YUMMY
    edited April 2016
    I knew you will , it is out of the box set .. it will be one of my freebies for my end of June celebration .
    Yea, so you know I'm a country boy that lived in the big city and hated it!  lmao
    LOL  .. I hate it too but no choice ..  and I never lived in the country but I always wanted because I was born to be wild IMAO
  • VhardamisVhardamis Posts: 576
    That copper version is amazing. Real pans never looked so good.
    That's because copper pans suck to clean.
    Those look amazing, Cath.
  • SzarkSzark Posts: 10,634
    Here you go Cath as promised
    The only things not pimped with you shaders ares Stefans Utopia Deck, skin and sandal soles.
    Most shaders had scaling adjusted to 1x1 as I used my own normal maps. Some had scaling up to 50x50 like the beads on the hair...I used the Palm trunk shader with the normal strength turned down..
    1600 x 2263 - 2M
    Thank you, my favorite too so far
    I know they do I had couple of them back in Europe then decided to spray it with anti oxidation layer and keept as kitchen decoration
    Thanks !
    Thanks for sharing Pete, I see the tank shader on his armor the scale did create fading effect  and clever usage of the palm shader, I TRIED it also on the fibers as it looks like hair under electronic microscope with the cuticles
