Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
That leaves two options for Poser users. 1) Use the .obj with .mtl and get it in that way, save out as a prop. 2) Use DS to load the set, then export a prop (.pz2), load into Poser. China Town is DS only, I bought it, used option 2 and have the set, with all textures, as a single Poser prop now. That still doesn't offer everything a complete Poser set will. But if you just have to have it, then this is better than nothing.
McG.
@ Stefan - Thanks for the info man. Appreciate ya for the huge body of work you've made easily available to us through the years!
McG.
the trouble with importing these obj's into Poser is your really not getting what you see in the promos,your certainly not getting anything close to what the DS users are getting,for example the forest sets coming out soon have a large amount of instanced geometry,probably 80% of the trees in those DS scenes simply won't be exported into the obj(you can't export instances)
your also not getting the best of the materials,..translucency maps,roughness maps,reflection maps,normal maps or any of their settings won't export,any emissive lighting maps or settings won't export.
and then things like the terrain shader certainly won't export,and I'm using that same shader on all the roads in sprawl3 and some of the buildings also.
also the mesh smoothing angles won't export so the model ends up looking very badly made.
I can see the day coming when I just can't provide the obj because it looks nothing at all like the scene I made
As I toon everything anyway for my comic, maybe the above factors will not be so much of an issue in poser. I can adjust smoothing in poser too of course.
Is instancing used in this next urban sprawl?
Kind regards,
esther
Stefan I hear you about the problem with the .obj's being too primitive to see the full features of the sets, even now. That leaves Option 2. Use DS (I keep 4.8 installed for this) to load then export a prop, when that is available. I think for the most part, the few die hard Poser users will just not get the new stuff. The new people will be convinced to use DS and never even see Poser. I just can't see the quality of content staying high for Poser.
McG.
So McG, if I export the prop using DS is it still somehow connected via the DSON script (which seems to slow my poser down) or will it be an ordinary poser prop in poser? I've done it before, but not for awhile and never for a really big set like this.
es
Weeeellll - the part about Bryce will make Chohole happy.
LOL
Hopefully there will be 3Delight support since it is a Studio only product now would hate for it to be a Iray only product.. :(
the interesting thing about this thread is it shows how much time and effort Stonemason puts into a project such as this with previews started in May 2013
+1
You can use the option to Create Poser Companion Files, and that is when DSON will show you the item in Poser. Then you can save it out from Poser as either a boned .CR2 or a simpler .PZ2 prop, whichever is appropriate for the item. Neither of these Poser formats should be tied to Studio.
OK, well I might just buy this set and try it then.
es
.pp2 (Prop) - pz2 is poses (sorry for nitpicking ...)
I can only imagine how amazing this set will be! Super cool.Wow! Your stuff is always amazing!
Right you are Kerya. You know I know better than that boo boo! :)
McG.
I don't want to see the day when you stop offering OBJs.
I'm running Carrara 7Pro and I miss your Poser versions because that's what I used to use and your sets looked GREAT in Carrara, I'm really surprised you didn't make more for just Carrara because those sets were awesome.
I bought your Streets of London and had to return it because the OBJs didn't load up right (They all loaded in the middle) and I had to put the textures on by hand!
I had a friend who took a WEEK to figure out where everything went and made some nice renders in Carrara for the London set.
I wish you set the OBJs so they at least load up where they are supposed to. If the textures are labelled right, then I can take the time to put them on, because your sets ARE worth it.
Thanks
Edited to fix quotes
that sounds like an error on import for carrara,some poser users have been using the wrong import settings and getting the same thing,but when they use the right settings then everything loads where it should.the obj's are saved in position and should not load all centered
Stefan, I do not miss some of the stupid things I have said and done through the years. I will truly miss being able to use your newest sets. I cannot be made to like DS any more than I can the change Earths rotation or the Suns spots. I think it is why we still have several different programs that do the same basic things. I am really saddened to see you part company with Poser man. But I do wish you all the best. You've certainly earned it!
McG.
Yes, if buying you a copy of poser would help Stonemason, I would actually do it.
Love esther
BTW, Stonemason's store items are included in MM pricing today, so a chance to snap some up if you're hovering.
let me know. I'm not joking.
Love esther
The problem is that maintaining skills and time to test in another app is a cost. And if you aren't enjoying the return on that cost...
well I can only try.
Stephen said he didn't have it installed anymore. So I think he just feels it just isn't worth it anymore. It is also a lot of time to setup shaders. Doing 3delight, iray, AND poser materials? Sounds like a whole bunch of nope.
Uhm - the London set was updated to include mtl too - so you don't have to add the textures by hand.
heh,thanks
it's really the enjoyment factor though,I just don't like using it.on the other hand I love jumping into DS
looking cool
Oh wow, really?
Does anyone know what settings I should use for Carrara 7Pro for the OBJs ?
If so, I'm going to pick up the Stonemason sets I returned AND start using the ones I kept, but couldn't use!
None of my props load up where they should. Really a BIG problem with Chinatown.
Thanks
Stefan,
Thanks so much for keeping Poser users in mind! I'm a new user to both programs. They each have their strengths and I'm enjoying exploring them and using the same content in both (when possible). So glad to be able to be able to do that with your sets. Urban Sprawl 3 looks wonderful! Can't wait to snag it when it's in the store! Thanks for the great products. They are a dream to use!
