What the heck is going on with my conversion?!
What the heck is going on with my conversion?! I converted an item from G9 to G8, the overalls from https://www.daz3d.com/dforce-urban-overalls-outfit-for-genesis-9 and though they had weight map issues (which I had a tutu with but made it worse so gave up...I HATE weight maps) I was ok with the result. Until I saved and reloaded them...not what I expected. Why did DS save them like that? Am I condemned to converting them each time I want I want to use them. My head hurts.
Before saving1
Before saving2 (simmed)
After saving1
After saving2 (simmed)
1000 x 1000 - 664K
1000 x 1000 - 458K
1000 x 1000 - 557K
1000 x 1000 - 487K
Post edited by Lorraine on
I don't have them, and I can't remember seeing something similar.
Smoothing might be involved in causing this.
You can try the following.
1. Autofit pants to G8F
2. Fit another pair to G9 base
3. In hidden parameters dial G8F clone, and thighs side-side 6.6/-6.6 (so it matches G8F default pose)
4. Export the G9 pants in base resolution.
5. With G8F pants selected go to Edit > Object > Geometry > Update Base geometry > Vertex position from file, and select the file you exported and then save.
For a tutu you wamt all weight on the pelvis. With Weigth brush tool active, select Pelvis in the tutu. In Tool settings set it to vertex selection, and in viewport right click and Geometry selection > Select all. Then again right click Weigth editing > Fill selected > 100%
Thank you, Felis! I shall give all that a go tomorrow and report back :)
By following the steps you mentioned, I couldn't reproduce the issue with Urban Overalls in DS 4.24 and DS 6.25 ~ What is DS version that you were using ?
As for the issue with Tutu(s), you can fix it in the way I showed in this thread: https://www.daz3d.com/forums/discussion/comment/8498346/#Comment_8498346
Thanks for your help, peeps but nothing worked except for a whole day playing with weight maps, then tweaking the dforce settings. It's as good as I'm going to get it.
And I'm sorry I put you crook about 'tutu', it's a kiwism meaning to ‘fiddle around with something’, pronounced tut (like put) two
Good to know another meaning of "tutu" ~
What Clone did you choose from the list in Auto-Fit dialogue, the official Genesis 9 ? I tried with this option again but still found no issue after loaded the saved the preset of auto-fitted version ~~
Yes I used the official clone and full body template in Daz 4.24. The weight maps had carried over from the left into the right leg (thigh bend, thigh twist and shin) and I painted that out plus did some more tutuing to the other maps...not my favourite job in the world at all !
'Tutu' is actually a tree (most people call it 'toot'), highly poisonous to humans and cattle. It may not kill you but the whole time you will wish you were dead. We don'tt have venomous snakes and spiders like across the ditch but our foliage will get you ;) How the tree became fiddling bout with stuff goodness only knows.
Hello,
is there a full list somewhere telling which bone from G8F to use as a source for which bone of G9?
I actually have a script which automates that, but alas, I didn't write the whole thing, so I can't share it.
I did however put together the array that matches up the (internal) names, so I can reasonably share that:
['pelvis','pelvis'],
['head','head'],
['neck1','neckLower'],
['neck2','neckUpper'],
['spine1','abdomenLower'],
['spine2','abdomenUpper'],
['spine3','chestLower'],
['spine4','chestUpper'],
['l_shoulder','lCollar'],
['l_hand','lHand'],
['l_thightwist1','lThighBend'],
['l_thightwist2','lThighTwist'],
['l_shin','lShin'],
['l_foot','lFoot'],
['l_metatarsal','lMetatarsals'],
['l_toes','lToe'],
['l_forearmtwist1','lForearmBend'],
['l_forearmtwist2','lForearmTwist'],
['l_upperarmtwist1','lShldrBend'],
['l_upperarmtwist2','lShldrTwist'],
['r_shoulder','rCollar'],
['r_hand','rHand'],
['r_thightwist1','rThighBend'],
['r_thightwist2','rThighTwist'],
['r_shin','rShin'],
['r_foot','rFoot'],
['r_metatarsal','rMetatarsals'],
['r_toes','rToe'],
['r_forearmtwist1','rForearmBend'],
['r_forearmtwist2','rForearmTwist'],
['r_upperarmtwist1','rShldrBend'],
['r_upperarmtwist2','rShldrTwist'],
['l_pectoral','lPectoral'],
['r_pectoral','rPectoral'],
['l_thumb1','lThumb1'],
['l_thumb2','lThumb2'],
['l_thumb3','lThumb3'],
['l_indexmetacarpal','lCarpal1'],
['l_index1','lIndex1'],
['l_index2','lIndex2'],
['l_index3','lIndex3'],
['l_midmetacarpal','lCarpal2'],
['l_mid1','lMid1'],
['l_mid2','lMid2'],
['l_mid3','lMid3'],
['l_ringmetacarpal','lCarpal3'],
['l_ring1','lRing1'],
['l_ring2','lRing2'],
['l_ring3','lRing3'],
['l_pinkymetacarpal','lCarpal4'],
['l_pinky1','lPinky1'],
['l_pinky2','lPinky2'],
['l_pinky3','lPinky3'],
['r_thumb1','rThumb1'],
['r_thumb2','rThumb2'],
['r_thumb3','rThumb3'],
['r_indexmetacarpal','rCarpal1'],
['r_index1','rIndex1'],
['r_index2','rIndex2'],
['r_index3','rIndex3'],
['r_midmetacarpal','rCarpal2'],
['r_mid1','rMid1'],
['r_mid2','rMid2'],
['r_mid3','rMid3'],
['r_ringmetacarpal','rCarpal3'],
['r_ring1','rRing1'],
['r_ring2','rRing2'],
['r_ring3','rRing3'],
['r_pinkymetacarpal','rCarpal4'],
['r_pinky1','rPinky1'],
['r_pinky2','rPinky2'],
['r_pinky3','rPinky3'],
['l_bigtoe1','lBigToe'],
['l_bigtoe12','lBigToe_2'],
['l_indextoe1','lSmallToe1'],
['l_indextoe2','lSmallToe1_2'],
['l_midtoe1','lSmallToe2'],
['l_midtoe2','lSmallToe2_2'],
['l_ringtoe1','lSmallToe3'],
['l_ringtoe2','lSmallToe3_2'],
['l_pinkytoe1','lSmallToe4'],
['l_pinkytoe2','lSmallToe4_2'],
['r_bigtoe1','rBigToe'],
['r_bigtoe12','rBigToe_2'],
['r_indextoe1','rSmallToe1'],
['r_indextoe2','rSmallToe1_2'],
['r_midtoe1','rSmallToe2'],
['r_midtoe2','rSmallToe2_2'],
['r_ringtoe1','rSmallToe3'],
['r_ringtoe2','rSmallToe3_2'],
['r_pinkytoe1','rSmallToe4'],
['r_pinkytoe2','rSmallToe4_2']
Note that with the head, you may often need to just paint in areas which are assigned to face pose controls; G8 and G9 have sufficiently different face rigs that stuff no longer matches up... but, fortunately, most things that might be fitted to the head do not need to be rigged in detail.
Thank you very much
