another [tricky] problem...
dondrawdondraw Posts: 167
edited February 21 in Daz Studio Discussion
i need to save a character in such a way that i can add it to another existing scene. i thot this is done by saving it as a scene subset but that doesn't seem to work. ? Is there a way to save an image of, say, a tiger and adding it to an existing scene showing frightened spectatoRS?
thanks.
  • Use File>Merge to add the extra scene? It will just import the 2nd scene with all its elements to your current scene. I would merge in the main scene as it will overwrite the environment details of the existing scene and save you having to set up those again.
  • dondrawdondraw Posts: 167
    it works, great! thanks.
    don
  • Merge should be the default behaviour when you double-click a Scene Subset in a content pane.
