[Solved] Broken pelvis Genesis 3
sveekeymailsveekeymail Posts: 5
edited June 2023 in Daz Studio Discussion
Hi,
I had a library of Gen3 Female poses from yoga. Yesterday I opened DAZ and it showed cubes instead of bodies. It was a cms location issue (could not login and retreive cloud data). And after I fixed that ALL my gen3 scenes became humped strangely in the Pelvis area and feet. You can see the difference between the same scene rendered before and after in the attachment. Any idea why this happened (I think its MacOS or video drivers issue, or something is wrong in parameters after CMS was fixed).
I tried to reinstall Studio - didn't help. Thank you!
EDIT: a picture don't attach :( shared it here: https://drive.google.com/file/d/1kX5dz8bCLj6PGQiTwUkADkae1UV9TMFi/view?usp=sharing
Post edited by sveekeymail on
  • Richard HaseltineRichard Haseltine Posts: 108,934
    It's probably a character, shape set, or joint adjustment tool, that you didn't have installed then but do now, kicking in when it shouldn't.See if you can isolate the minimum pose (fewest bones/rotations involved, not a matter of how much they are rotated) to trigger the issue as that will make it much easier to figure out the cause.
  • Thank you Sir, flat butt issue resolved.
    Your message made me realise something could be missing as well. And I think it was Genesis 3 Starter Essentials package. Thank you very much!
