Can anyone help me make DzCreateExPFiles-V4V3 work with Poser on a Mac?
will shetterlywill shetterly Posts: 278
edited July 2015 in Poser Discussion
Totte helped me successfully set up DzCreateExPFiles-V4. Based on what we did, I made this guide in the hope of using V4.2-to-V3:
1. Start the terminal, type cd with a space after it, drag the !DAZ folder (under runtime/libraries) from the finder window to the terminal window, and hit return.
2. Type
chmod +x ./DzCreateExPFiles.app/Contents/MacOS/DzCreateExPFiles
and hit return.
3. Type
ls -ls DzCreateExPFiles-V4V3.command
and hit return.
4. Type
chmod +x DzCreateExPFiles-V4V3.command
and hit return.
5. Type
and hit return.
6. Doubleclick the DzCreateExPFiles-V4V3 script.
But I'm doing something wrong, because when I do that, I get this:
Last login: Wed Jun 3 23:12:14 on ttys000
/Users/Shared/Daz-\ Victoria\ 4/Runtime/Libraries/\!DAZ/DzCreateExPFiles-V4V3.command ; exit;
will-shetterlys-imac:~ will$ /Users/Shared/Daz-\ Victoria\ 4/Runtime/Libraries/\!DAZ/DzCreateExPFiles-V4V3.command ; exit;
Password:
sudo: DzCreateExPFiles.app/Contents/MacOS/DzCreateExPFiles: command not found
logout
[Process completed]
I double-checked my password, and it's the only thing I'm sure I did right. Anyone have any idea where I goofed up?
ETA: I'm using the current OSX and Poser Pro 2014.
Post edited by will shetterly on
  • WandWWandW Posts: 2,882
    I don't have a Mac, but I do use Linux; OS X is stupid old UNIX under the pretty GUI. :) .
    Step 2 is redundant, because you already did it to get V4 set up, but it shouldn’t hurt anything, unless you happened to enter '-x' .
    In the Terminal window, try..
    ls -l *.app
    ...to make sure that the executable bit is set for DzCreateExPFiles. If it isn't, set it using chmod.
    BTW, the original thread is http://www.daz3d.com/forums/discussion/47761
