Morph’s won’t work in Poser 10
gadgytman2011gadgytman2011 Posts: 46
edited December 1969 in Poser Discussion
I bought and payed for creature creator for V4 and only the head and hand (not including the fingers) will morph.
  • fixmypcmikefixmypcmike Posts: 19,657
    Moved to Poser forum.
    What SR do you have installed? ISTR there was a problem with SR5.
  • edited December 1969
    I checked using my Poser pro 2014 version 5.2 and Creature Creator morphs seem working fine for V4.
    480 x 640 - 55K
  • gadgytman2011gadgytman2011 Posts: 46
    I have poser 10. SR?
  • WandWWandW Posts: 2,882
    edited March 2015
    If you didn't install them through DIM, make sure V4 was reinitialized after installing the morphs. Browse to; the folder you installed your stuff/runtime/libraries/!DAZ and Click on both: (in Windows; there are Mac scripts in the same directory)
    - DzCreateExPFiles-V4.bat
    - DzCreateExPFiles-V4V3.bat
    Post edited by WandW on
    http://my.smithmicro.com/poser-10-updates.html
    I already installed the updates, didn't make a difference.
    Where can I download the .exe file? The Daz install manager has to many bugs.
    edited March 2015
    The exe installers are no longer avalible.
    I have no issues at all with DIM, myself, but it if you want to install manually, download the zip file from the Content Library in your Account, copy the contents of the 'Content" folder. (should contain folders 'Runtime' and 'Data' ) into the folder containing your V4 runtime, and reinitialise V4 as I noted in my post above...
    edited March 2015
    Post edited by gadgytman2011 on
    I did that and it had no effect.
    Do you have only one "Runtime:Libraries:!DAZ:Victoria 4" folder in any runtimes listed in Poser? Is that runtime outside of Program Files?
    Programfiles x86 I'm using Poser 10 2 bit.
    C:\Program Files (x86)\Smith Micro\Poser 10\Runtime\Libraries\!DAZ\Victoria 4
    edited March 2015
    I don't have this problem with installing figures, props, poses or textures or anything else with the DIM, it's only morphs. Is there a way to get the Bitrock instabuilder?
  • Richard HaseltineRichard Haseltine Posts: 106,652
    Don't place content in the application folder, with Windows Vista and later that is likely to cause problems. Poser should have offered, as a default, \Smith Micro\Poser 10 Content in the Public Documents folder - the DAZ Install Manager defaults to My DAZ 3D Library in the Public Documents folder. use one of the defaults, or another folder of your choice, and make sure you have the destination folder selected as an external library folder in Poser.
    No there is no folder specifically labeled "content" in Poser 10
    1366 x 768 - 601K
    I didn't say there was - the content folder is the folder with the content, in your case you seem to have it set as C:\Program Files (x86)\Smith Micro\Poser 10\ and that won't work on any Windows version later than XP.
    I have windows 7
  • mrposermrposer Posts: 1,134
    Make sure you look for the creature creator morphs on the body.... not the hip ( which Poser usually sets me to initially). I wasn't sure if you can't find the dials or they are there but nothing happens when you set them.
    I did that, the dials don't even show up on the body.
    They won't work reliably inside Program Files (x86), because the files aren't actually where Windows is pretending they are.
