Particles3
Death ZDeath Z Posts: 45
edited December 1969 in Poser Discussion
http://www.daz3d.com/particles-3-pz-1
The Particles plugin says it's for Poser 6&7 only... does that mean it doesn't work on Poser 10, or it's just came out when Poser 7 was new?
I'd like something to use for particles and sprites but want to make sure it will work in Poser 10 before I buy it.
  • Richard HaseltineRichard Haseltine Posts: 106,652
    It means it won't work - compiled scripts, like this, are sensitive to the Python version used and that changed in more recent versions of Poser.
  • Death ZDeath Z Posts: 45
    does anyone know of any other particle or sprite system or anything?
  • WandWWandW Posts: 2,882
    edited February 2015
    The scripts portion of Particles 3 has been made open source, so if you know something about Python (I dont know enough!) here is the source code:
    https://code.google.com/p/pw-particles-3-source/
    Under 'trunk' you will fine a runtime folder containing the scripts. The easiest way to download it is with the program subversion; ootherwise it is a lot of cutting and pasting...
    https://subversion.apache.org/packages.html
    Good Luck!
    Post edited by WandW on
