Shader Mixer and Uber products
Ongoing MomentOngoing Moment Posts: 78
edited July 2012 in Daz Studio Discussion
I am getting into the shader mixer to see the nuts and bolts behind lighting and materials. I watched tutorials about building materials and shaders in 3D max. It is not a one to one translation, but it helps you understand the theory, architecture and objectives in building shaders. I am a 2 month newbie and the non documentation issue is really killing me.
So I go over to Studio 4 and the Daz Default Shader architecture is essentially very easy compared to the video I just watched. So I want to look at say my UberSurface Bricks and it won't load. UberEnvironment is the same thing. I highlight the shader and hit load current shader, choose light (even tried material) and nothing loads. Ugggg, so frustrating. Uber is essentially the main shader extension to access higher level rendering options for Daz studio. What gives?
Does Studio 4.0 have this capability? Am I missing something, like the architecture is not built off of the shader mixer but somewhere else that is not accessible? Or am I missing the mark as to what Uber products do?
Grateful3D
Post edited by Ongoing Moment on
  • PendraiaPendraia Posts: 3,598
    Grateful3D
    Hi, if I'm not mistaken Über was created by aPA initially the file is probably encrypted. If you save ShaderMixer files with an encrypted format you won't be able to open those either.
    I know how you feel about the lack of documentation...: (. I had planned on writing up tutorials for some of the networks that had been posted but with starting anew job this year I just haven't had the time.
    If you look at the links in my sig it will lead you to some of. The threads created on ShaderMixer when it first came out. You may need to change some of the links to access the old threads to include IIRC forum archive in the URL . If you get stuck just ask in the forum and I'm sure people will help.
    Cheers
    Pen
  • SzarkSzark Posts: 10,634
    ...and it doesn't help that the Shader Miixer functions have changed a little too since DS3. Every tutorial I try to follow works with me pulling my hair out. You should look and compare the old Glass Shader and the New one in DS4.5 RC2. There seems to be more bricks in the new one.
  • BejaymacBejaymac Posts: 1,938
    3rd party shaders (they come with .sdl files) can't be opened as they are copyrighted, on top of that they weren't built in the ShaderMixer, so there is nothing in them that it can use to generate the required bricks.
  • Ongoing MomentOngoing Moment Posts: 78
    "3rd party shaders (they come with .sdl files) can’t be opened as they are copyrighted, on top of that they weren’t built in the ShaderMixer, so there is nothing in them that it can use to generate the required bricks."
    Ahhh, so you are saying that Uber is software driven and is not represented by the shader mixer routine. It is a specialized software routine. Do you know what it accesses? The rendering engine and or the computers hardware?
    Will have to look at the shader mixer tutorial and see if I can figure out how to build some Subsurface Scattering and velvet skin effects. But I am afraid without proper docs it might be like spitting into the wind.
  • Richard HaseltineRichard Haseltine Posts: 106,652
    Strictly, even the default shaders aren't being read - it's just that they have equivalent bricks and DS knows how to convert to Shader Mixer. We were told that other shaders could, in principle, do the same but so far none of the addons have brick equivalents.
    Saving a Shader Mixer shader as .dsb won't stop it from being loaded into Sahder Mixer once it's been applied, as far as I know.
  • Takeo.KenseiTakeo.Kensei Posts: 1,303
    In fact the only difference between Shader mixer shaders and others is that DS4 has the source code of the bricks somewhere (don't ask me where I don't know). This gives users the ability to build their own shaders which are compiled at rendertime. From what I've read it uses a feature called co-shaders if I'm guessing right
    UE or other 3rd party shaders are already compiled and you don't have the source...so no brick in shader mixer. Now if you want to understand shaders, I'd suggest to read renderman documentations after you're done with shader mixer tutorials.
    "I’d suggest to read renderman documentations after you’re done with shader mixer tutorials."
    That was such a great idea. Thanks for suggesting it. I won't be coding shaders anytime soon but reading the documentation really gives you a complete insight into what the foundation of shaders are doing.
    Haven't had chance to look at shadermixer much recently been too busy with work...I'll have to check it out.
    They did change a number of things when it came out of beta, a number of the bricks changed their names I know. I wish I had more time so I could write some proper tutorials for some of the networks that people have created. I keep meaning to do the networks Yacoma and Age of Armour provided(I've gotten permission to do so from both of them) I just haven't had time...: (
    When I released the cat fur preset there was a way to save as an encrypted file format this may have changed since as that was when it was in beta.
    I remember a conversation with Adam (or someone) about the different formats as some of the testers had problems with one of the formats.
    edited July 2012
    Yes, DSB and DSE are version tagged and so wouldn't open in an older version of DS. But I thought the network could still be read into Shader Mixer once applied to a surface.
    It was my understanding and I could be wrong that it couldn't but from the conversations I had at the time I was under the impression that it would allow pa's to release presets without worrying that someone would pinch their network and release something similar.
    Sorry if I'm taking this thread off topic...
  • NeilV_1NeilV_1 Posts: 442
    I had this understanding as well so that if you wanted similar capability to a PW shader you would need to work them out from scratch your self rather than dissecting the shader. This was what seamed to stop any similar shaders for DS 4 until DAZ brought out most of PW and compiled them for DS4.
