How to install v4.2 in Poser on OSX Mavericks
BlazmethBlazmeth Posts: 36
edited December 1969 in Poser Discussion
I just bought it and spent the last hour figuring out how to install it. Total newbie here so it would be great if the instruction could be clear enough that I can't mess it up!
What I have tried: zip installer from Poser 10 => fail
Thanks
  • fixmypcmikefixmypcmike Posts: 19,657
    Can you explain in more detail what you tried? If you are installing manually, make sure you did not put the folder named Content inside your actual content folder -- the Runtime folder inside the zip needs to be merged with your actual Runtime folder. You will also need to manually run the "Runtime:Libraries:!DAZ:DzCreateExPFiles-V4.COMMAND" file.
  • BlazmethBlazmeth Posts: 36
    Sorry, I think I was just too tired because I just copied the files and ran the script and is seems to work. I can add Victoria to my scene. I can't confirm if the morphs are working because... well... I dont know how these things are supposed to work yet :-S
