Help with Missing morph warning errors in log file loading basic genesis 2 - Solved
KharmaKharma Posts: 3,214
Hope someone can help, everytime I load a basic gen2f I get these errors in my log file and I donot think these should be trying to load with a basic genesis figure, how do I remove these errors?  This is a fresh start of DS 4.12 Beta and a fresh load of genesis 2 , following is the errors I receive in log.txt.  This is also causing a problem using GenX2 to transfer morphs to G# so I can then use XTanfer to G8.  If anyone has a solution it would be much  ppreciated, I have tried uninstalle and reinstalle of G2 and G3 and all GenX modules
2019-12-07 09:50:29.889 *** Scene Cleared ***
2019-12-07 09:50:30.879 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(660): sync completed successfully, 9 items succeeded, 0 items failed.
2019-12-07 09:50:30.879 Metadata update succeeded.
2019-12-07 09:50:37.342 E:/My Daz Library/data/DAZ 3D/Genesis 2/Female/Morphs/FWSA/MeMoo/MCMMeMooNipples.dsf (463,1): Unexpected Character
2019-12-07 09:50:42.627 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: GenesisFemale:/data/DAZ%203D/Genesis%202/Female/Morphs/sickleyield/BigBeautifulGenesis2/PBMBBGLiftHelper02_proj.dsf#PBMBBGLiftHelper02_proj?value in file : /data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/PBMBBGLiftHelper02.dsf
2019-12-07 09:50:42.635 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: GenesisFemale:/data/DAZ%203D/Genesis%202/Female/Morphs/sickleyield/BigBeautifulGenesis2/PBMBBGLiftHelper01_proj.dsf#PBMBBGLiftHelper01_proj?value in file : /data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/PBMBBGLiftHelper01.dsf
2019-12-07 09:50:42.637 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: GenesisFemale:/data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/FBMHeavyHelper04_proj.dsf#FBMHeavyHelper04_proj?value in file : /data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/FBMHeavyHelper04.dsf
2019-12-07 09:50:42.645 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: GenesisFemale:/data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/FBMHeavyHelper03_proj.dsf#FBMHeavyHelper03_proj?value in file : /data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/FBMHeavyHelper03.dsf
2019-12-07 09:50:42.645 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: GenesisFemale:/data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/FBMHeavyHelper02_proj.dsf#FBMHeavyHelper02_proj?value in file : /data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/FBMHeavyHelper02.dsf
2019-12-07 09:50:42.658 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: GenesisFemale:/data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/FBMHeavyHelper01_proj.dsf#FBMHeavyHelper01_proj?value in file : /data/DAZ%203D/Genesis%202/Female/Morphs/SickleYield/BigBeautifulGenesis2/FBMHeavyHelper01.dsf
2019-12-07 09:50:43.691 File loaded in 0 min 13.9 sec.
2019-12-07 09:50:43.692 Loaded file: Genesis 2 Base Female.duf
2019-12-07 09:50:44.794 Loaded image CTRLZahara.png
2019-12-07 09:50:44.812 Loaded image CTRLZahara.png
2019-12-07 09:50:44.842 Loaded image AmaraBody.png
2019-12-07 09:50:44.845 Loaded image AmaraBody.png
2019-12-07 09:50:44.872 Loaded image FBMPebble.png
2019-12-07 09:50:44.875 Loaded image FBMPebble.png
2019-12-07 09:50:44.887 Loaded image FBMPebbleHD.png
2019-12-07 09:50:44.890 Loaded image FBMPebbleHD.png
2019-12-07 09:50:44.929 Loaded image VSBodyCard.png
2019-12-07 09:50:44.932 Loaded image VSBodyCard.png
2019-12-07 09:50:45.429 Loaded image V5BreeTorsoM.jpg
Post edited by Kharma on
  • KharmaKharma Posts: 3,214
    I am continuing to have this problem with loading G2 and G3 figures,  even tho I have deleted and reinstalled these figures, has anyone experienced this and what was the solution to correct it?
    Thanks for any help or suggetions
  • LeanaLeana Posts: 11,026
    When you load a basic G2F DS will read the list of all morphs available for G2F so they can be available as parameter sliders for you to use.
    I see messages related to 2 different products in the log you posted.
    This one seems to be an error: 2019-12-07 09:50:37.342 E:/My Daz Library/data/DAZ 3D/Genesis 2/Female/Morphs/FWSA/MeMoo/MCMMeMooNipples.dsf (463,1): Unexpected Character
    => Apparently there's something DS doesn't like with one of the morphs for the MeMoo character.
    The other messages are warning messages related to the "helper" morphs included in the "Big Beautiful G2F" pack.
    Maybe try reinstalling both of those products?
    @Leana thank you for the suggestions, I will try uninstalling and reinstalling both G2 and G3 plus the MeMoo morphs and  Big Beautiful G2 morphs again and see if it helps this time ..  if it doesn't I don't know what else to try.  These seem to also cause an issue when I try to GenX2 transfer from G2 to G3 it says these morphs are missing in a popup in th GenX window.
