How to convert a G8M character to G8F?
I have been commissioned to create a gender transformation animation of the commissioner's likeness, however, I created the commissioner's likeness using G8M, as he is a male. I discovered only afterwards, that the props I would need to make this animation work are only compatible with G8F, and there is no way I would be able to accurately recreate his face a second time with a new base - this already took hours. I was linked a guide from a user on reddit on using the Genesis 8 cross-figure resource kit in conjunction with the Transfer Utility, and transferring the character's body worked great, but the face? See for yourself. https://imgur.com/a/PsqANG3. I can quote/link the exact guide I followed as well, but this is my first post on these forums, and I'm still unclear on the rules of inside/outside web links.
Post edited by zuon94_606619d1be on
  • GordigGordig Posts: 10,543
    Try this.
  • zuon94_606619d1bezuon94_606619d1be Posts: 28
    edited October 2019
    Gordig said:
    Try this.
    I have that. What it is is a morph for G8M, but what I need is to transfer my entire G8M character into the G8F base, as I need to use some "props" that are 100 percent incompatible with the G8M figure, only G8F. Thank you.
  • Oso3DOso3D Posts: 15,077
    What I would do is export the figure, use Morph Loader Pro to load it back in as a new personal morph, then use Transfer Utility to transfer the morph from G8M to G8F (there are instructions out there for how to do that).
    Mind you, if there are JCMs or whatnot those won't come across.
    edited October 2019
    I have tried that as well, but I don't believe I was doing it correctly. I'll see if I can find those instructions you speak of, but in case I cannot find a suitable guide on my own, would anyone be so kind as to link to one below, if I need to come back here later?
