Problem with a dynamic skirt in Daz
DaleCar_06ae99e4f4DaleCar_06ae99e4f4 Posts: 178
Hi all,
I'm having a problem with a dynamic skirt in Daz. I have a character that is falling to the floor. The dynamic skirt conforms properly to V4. But for some reason does not recognize the floor. And sinks through it where it touches, pretty much ruining the effect. I believe I have all the proper settings. If I understand how this works correctly. I've set everything in the scene so it should effect the dynamic cloth. But it still sinks into the floor rather than colliding with it.
Any thoughts?
Thanks,
Dale
  • JaderailJaderail Posts: 0
    If your floor is a very low poly item it will not stop the dynamic items. The floor needs to have a pretty high poly count.
  • Zev0Zev0 Posts: 7,120
    Also if the item is too high polycount it will ignore:)
  • jmperjmper Posts: 261
    If you don't want to mess up your scene, find a high poly floor and make it transparent after placing it where the dress would collide with the floor.
    edited June 2012
    A primative Plane set to about 25 divisions at 6 M would also work. I'm pretty sure I've used that before. Just set opacity to 0 after you position it properly. Then just collide with the plane and anything else that needs it. You could stop the collision with the floor that does not work, that might even speed up the calculation time.
    Post edited by Jaderail on
  • DaleCar_06ae99e4f4DaleCar_06ae99e4f4 Posts: 178
    Thanks, I'll give that a try
    Dale
  • IkyotoIkyoto Posts: 1,159
    Here's the Little Black Dress with a 24 division plane, single distant light (Raytraced, 50% soft shadow). Works quite well.
    824 x 431 - 50K
