Digital Art Zone
Smoothing modifier and collision objects
Posted: 18 October 2012 01:04 PM   [ Ignore ]
Member
Rank
Joined  2011-05-17
Is it possible to have multiple collision items for a single item? For example, I apply a smoothing modifier to a shirt, and have a sword resting on the shoulder. Is there a way to apply the smoothing modifier to fix the pokethrough against the figure (normal) AS WELL AS ajust for the sword touching the cloth?
Profile
Posted: 18 October 2012 01:24 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2012-02-04
Not directly.  Some folks will load a bodysuit and make it invisible at render time.  Then ‘outer layer’ stuff is set to collide with the bodysuit, which is scaled up slightly to give the needed clearance from the body for the ‘inner layer’ clothing.
 Signature
My deviantART Homepage
Profile
Posted: 18 October 2012 01:55 PM   [ Ignore ]   [ # 2 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
You can also create a Geo-Shell and use it as the second collision item. It can be scaled as well.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 18 October 2012 02:55 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
when i have a scene absolutely finalized, I will sometimes take a certain object, set it to collide, and then export that object with the collision shape, and import again, and this time set it to collide something else.
This has been my only work around for me.
Profile
Posted: 18 October 2012 03:52 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2011-05-17
All of these things seem terribly clever. I will try them all!
Profile
Posted: 22 October 2012 02:24 PM   [ Ignore ]   [ # 5 ]
New Member
Joined  2012-02-02
Jaderail - 18 October 2012 01:55 PM
I’m curious on how you would do this. For example I want the Cube to collide with both Cones (see attachment). I created a Geo-Shell from the Cube, applied Smoothing to the Geo-Shell, and have it collide with the Red Cone. But nothing is happening.
belovedalia’s idea seems pretty good. I’m just curious to know if there’s some built-in approach.
Thanks!
Image Attachments
Profile
Posted: 22 October 2012 02:29 PM   [ Ignore ]   [ # 6 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
It already had a collision with the first cone. But I was speaking in terms of clothing, I’ve never tried a primative.
 Signature
Profile
Posted: 22 October 2012 02:54 PM   [ Ignore ]   [ # 7 ]
New Member
Joined  2012-02-02
I used primitives because they were easy to test. I assume smoothing and collisions still apply, do they not?
I tried using a clothing item (see attachment.) The clothing item collided with Genesis. I created a Geo-Shell out of the shirt (and hid the original clothing). Then I tried to collide the Geo-Shell with a prop sword. But nothing is happening. Maybe I’m approaching this wrong. =\
Thanks!
Image Attachments
Profile
