Digital Art Zone
obj/obp files
Posted: 18 October 2012 07:12 AM   [ Ignore ]
New Member
Joined  2007-11-20
Can someone please tell what the difference is?  I can use the obj files, but the obp files don’t show up.  I’ve gotten some freebies and can’t seem to use them.  Just want to know.  Thanks.
Profile
Posted: 18 October 2012 07:29 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
OBJ files are imported using the main import object dialogue.
OBP need to be imported into your object preset library, as they are the Bryce native format, and only work in Bryce.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 18 October 2012 09:39 AM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2011-07-31
Thanks, Chohole.  I wondered about this too.
 Signature
AtticAnne in Austin TX
FREE GANGSTER RPG GAME
Profile
Posted: 18 October 2012 10:05 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2011-09-25
@goofy:  Access the Preset Object Library by clicking the right facing arrow to the right of Create on the top palate.  Another window opens with the title of Objects.  Along the left side are headings for different objects loaded into Bryce.  Near the bottom are a minus and plus sign, to the right Add/Delete/Import/Export.
Whatever OBP you have can be added to this library by clicking on Import and placing the object in whichever category you want—whichever one has the most open boxes.  Or, using the Plus sign creat a new category that matches the object you want to add.  Just make sure the title you chose will help you find that object(s) when you want them.
 Signature
If you constantly look backward, it’s guaranteed you’ll run into something on your forward journey.
Profile
Posted: 18 October 2012 10:27 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Yes sorry, I should have been more explicit.
I have my own added OBPs in the user category, and then my own folder names there.
 Signature
Profile
Posted: 18 October 2012 10:58 AM   [ Ignore ]   [ # 5 ]
New Member
Joined  2007-11-20
Thank you both for the info.  Now I can play in Bryce and get more organized.
See you over at DB Guss.
Profile
Posted: 18 October 2012 11:00 AM   [ Ignore ]   [ # 6 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
I recently added a container with Bryce relevant documents on my website (see sig). The document describing the Bryce file types and where they belong are in this 11 page PDF (590 KB):  http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 18 October 2012 03:20 PM   [ Ignore ]   [ # 7 ]
New Member
Joined  2007-11-20
Thanks Horo.  I’ll head over there and check it out.
Profile
