Digital Art Zone
Smart content disappeared.
Posted: 18 October 2012 04:57 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2005-10-26
Last month I had to rebuild my computer and have been hit by several errors.
I’m not sure when it happened exactly , but my Smart Content has stopped showing up.
I’ve tried re-setting the database, re-importing metadata .....nothing.
If anyone has had this problem or knows why this is happening please tell me as it is driving me crazy.
I’m off to work now so won’t be able to respond til tonight.
Thanks, flashback.
 Signature
Old post count 4147
MY DA Gallery : http://flashback37.deviantart.com/
Profile
Posted: 18 October 2012 05:04 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
You don’t say what OS you are using?
Smart Content relies upon the CMS (Content Management Service) running as a process.  If you are using Windows of some type, look in the Task Manager to see if the process is running, if not, then you will have to start it from Start > All Programs > DAZ 3D > Content Management.  Smart Content will not work without it.
Profile
Posted: 19 October 2012 03:45 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2005-10-26
I’m using Win7 and yes the CMS is running.
 Signature
Old post count 4147
Profile
Posted: 19 October 2012 03:52 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Does your Content Library look like the image below, is there a little triangle beside Products and Categories.  If not, the CMS is not running, and you may need to uninstall it, and re-install DS4.
If you do have the triangles as shown, then select Content DB Maintenance from the dropdown menu in the Content Library Tab as shown below, and Reimport Metadata.
Image Attachments
Profile
Posted: 19 October 2012 05:06 PM   [ Ignore ]   [ # 4 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
JimmyC_2009 - 19 October 2012 03:52 PM
What Image? I think you forgot something.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 19 October 2012 05:16 PM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Thanks Geoff, what a silly sleepy boy I am, bedtime I think.
Sorry flashback, I blame the tablets smile
Profile
Posted: 20 October 2012 12:05 AM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
JimmyC_2009 - 19 October 2012 05:16 PM
You have an iPad and an Android tablet?
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 20 October 2012 02:21 AM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
grin
It does sound a bit like that.  Nice to start the day with a laugh.
Profile
Posted: 21 October 2012 12:49 PM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2005-10-26
Should I do a manual uninstall?  Or just re-run the DS4 installer and let it uninstall?
If I go manual, should I uninstall in a particular order (CMS first then DS4 or….)
This is all very upsetting/confusing as this is the first time I’ve had major problems with any iteration of DS, and I found DAZ just before DS2 came out.
 Signature
Old post count 4147
Profile
Posted: 21 October 2012 04:00 PM   [ Ignore ]   [ # 9 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
I usually uninstall CMS manually, then let the installer automatically uninstall the rest.
 Signature
Products In Zips
Profile
Posted: 21 October 2012 04:15 PM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
I don’t know if resetting your Database will lose your Categories or not, it didn’t for me, but that is a bit risky if you have a lot of work invested in it.
If that all fails, you need to manually uninstall the CMS first, the DS installer does not replace it.  Then reinstall your DS version, and it will install the latest version of the CMS for you.
Hang around for a little while, and I’ll see if I can get someone else who uses Categories to help you.
Profile
Posted: 21 October 2012 04:48 PM   [ Ignore ]   [ # 11 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Uninstalling the CMS doesn’t remove the database,  DS 4,5 added the ability to export User Data, but if CMS isn’t working you won’t be able to do that.  Once you do get it working, I recommend exporting user data, so that if there’s a problem with the database you aren’t restarting from scratch.
 Signature
Products In Zips
Profile
Posted: 21 October 2012 04:57 PM   [ Ignore ]   [ # 12 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Thanks Mike.  I meant using the DB Maintenance > Reset Database, does that remove Categories, it didn’t for me?
I am glad you came along, all of this DB stuff is a bit out of my comfort zone smile
Profile
Posted: 21 October 2012 05:08 PM   [ Ignore ]   [ # 13 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
JimmyC_2009 - 21 October 2012 04:57 PM
Reset Database WILL remove Categories.
 Signature
Products In Zips
Profile
Posted: 21 October 2012 05:18 PM   [ Ignore ]   [ # 14 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
Now that is strange.  I just did it, and it didn’t destroy mine.  I only had a couple set up, but they are still there, or at least most of them.
I will take your word for it, I imagined it would, and was very surpirised when it didn’t, maybe mine weren’t done properly, or is did delete some of them.
Profile
