There is something else that I’ve inquired about in the past, although it wasn’t as important as fixing Powerpose. Many Genesis users will see that some of the morph parameters are colored, such as ones for Hitomi, morph sets by Xena and Rawn, and others. These colors can be set by clicking on the little gear on the right side of each parameter, choosing “Parameter Settings…” and then setting the Color A and Color B to create a gradient.
However, if a user sets their own colors, they are only saved with that particular Genesis scene. If you load a new Genesis, it will load with all of the default colors. I do know it’s possible to set all of the colors, then save that Genesis scene and load it whenever you need Genesis, but I believe that if you update Genesis with new morphs, you’ll either not have them in the saved scene or it will reset the colors anyway. I’d like to know if there’s a way to set the colors within Studio and then save it so that every new Genesis loads with those custom colored parameters. I was told that it couldn’t be done, but…well frankly, I don’t believe it. ![]()
Adzan and Blackfeather did a really good job of fixing Powerpose, so maybe we can have some luck with this too.
Thanks for taking a look.
SnowS
