Digital Art Zone
2 of 4
2
Imposible to obtain good result
Posted: 18 October 2012 08:32 PM   [ Ignore ]   [ # 16 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
JavP - 18 October 2012 08:25 PM
Thank you Kendall, I will proove it.
Just out of curiosity… where did you get the jet from?  I’d like to try to see if I can replicate your results.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 19 October 2012 12:31 AM   [ Ignore ]   [ # 17 ]
Member
Rank
Joined  2008-03-27
I made it all from cero with Hexagon Kendall. Like the terrains. There are one year of work there.
You can see the evolution here, and a “LEVEL 3” RENDERING.
http://www.facebook.com/javier.povedano.v
Good fly.
Profile
Posted: 19 October 2012 12:41 AM   [ Ignore ]   [ # 18 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
JavP - 19 October 2012 12:31 AM
Good fly.
Well, I guess I can’t try to replicate the error grin  Nice model!
Looking back at your previous post.  You’re going to want to remove everything in the valley behind the first line of mountains, as well as the backside of the 2nd.  Those polygons are nothing but wasted memory.  LOTS and LOTS of wasted memory by the looks of the detail. They aren’t going to help your render in any way.
Also, since you are doing an aerial set, you should run the renders in 2 passes.  First pass without the jet, and the 2nd without the hills.  Then use a 2d bitmap package to overlay the jet onto the landscape.  Since there are no shadows this will save you HUGE amounts of time.  Running 2 passes will take less time than 1 pass with everything.
Just some friendly advice from someone who also likes to do extremely detailed renders.
ALSO:  Switch your distance lights off of shadow maps and to raytracing @ no more than 1 bounce for the landscape render.  In the newer versions of 3DL raytracing is going to use fewer resources and render faster than the shadow maps.
Kendall
 Signature
Profile
Posted: 19 October 2012 01:18 AM   [ Ignore ]   [ # 19 ]
Member
Rank
Joined  2008-03-27
Ok. I will proove it.
Let me 40 hours for sleep, work in my other but official and real work, and attack again this problem.
Thank you again for to be there.
Javier
Profile
Posted: 19 October 2012 02:56 AM   [ Ignore ]   [ # 20 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Also I wouldn’t rely on the Render Quilaity Presets can we see all you Advanced Render settings please
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 19 October 2012 07:36 AM   [ Ignore ]   [ # 21 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Yup, that’s the next bit of info we need.  A screenshot ideally of the entirety of your advanced render settings tab would be perfect.
DAZ Studio is quite capable of rendering massive images.  It’s something of a hobby of mine to “push” DS to its limits.  Some of the largest renders I’ve done have used nearly 12GB of RAM.
This one is about 6.6GB of RAM http://adamtls.deviantart.com/art/The-Dragon-Battle-205847981 during rendering.
This one is almost 11.3GB of RAM during rendering… http://adamtls.deviantart.com/art/Adventure-Classics-04-Redux-173248510
 Signature
My Tutorials and Freebies Index
Profile
Posted: 19 October 2012 09:33 AM   [ Ignore ]   [ # 22 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
adamr001 - 19 October 2012 07:36 AM
Where’s the kitchen sink?
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 19 October 2012 10:08 AM   [ Ignore ]   [ # 23 ]
Member
Avatar
Rank
Joined  2004-04-07
hexagon should be able to tell you the polycount.
It looks nicely detailed!:-)
 Signature
regards
prixat
Profile
Posted: 19 October 2012 10:28 AM   [ Ignore ]   [ # 24 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
prixat - 19 October 2012 10:08 AM
So can Daz Studio via the Scene Info Pane. It will show what the scene polycount (faces) is or what the count is for a selected object.
 Signature
Pete
My Render Thread
Profile
Posted: 19 October 2012 11:07 AM   [ Ignore ]   [ # 25 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
mjc1016 - 19 October 2012 09:33 AM
It’s under water, drain was plugged up.  wink
 Signature
Profile
Posted: 21 October 2012 09:10 PM   [ Ignore ]   [ # 26 ]
Member
Rank
Joined  2008-03-27
Thank you.
The render parameters are the default for level 4, except the 16:9 format with res 1024 x 576.
The information of the original scene:
Nodes : 114
Lights : 4
Cameras : 1
World-Space Modifiers : 0
Scene Geometry :
Total Vertices : 2132702
Total Triangles : 636826
Total Quads : 1769776
Total Faces : 2406602
The information of the 1st scene that I can render deleting objects:
Nodes : 60
Lights : 4
Cameras : 1
Scene Geometry :
Total Vertices : 737727
Total Triangles : 94544
Total Quads : 668098
Total Faces : 762642
In any case I see that i am not the only one with these problems, and I see somebody exactly width the same error:
http://www.daz3d.com/forums/viewthread/5940/
http://www.daz3d.com/forums/viewthread/10118/
http://www.daz3d.com/forums/viewthread/5940/P15
Javier
Profile
Posted: 22 October 2012 04:33 AM   [ Ignore ]   [ # 27 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Well if you are using the Defualt render setting then there is problem one, hence way we asked for a screen shot like the one below.
Anyways 2 million faces (polygons) are way too many foir your computer to handle.
Image Attachments
 Signature
Pete
My Render Thread
Profile
Posted: 22 October 2012 05:24 AM   [ Ignore ]   [ # 28 ]
Member
Rank
Joined  2010-02-10
I’d suggest turning all of the texture maps off in the surface tab then saving as a new file. Quit Daz Studio and maybe reboot your computer. Restart then Load the new scene with no texture maps and attempt a render. This will at least let you know if the issue is with geometry or with the texture maps.
Though I agree with Szark 2 million is pretty heavy
 Signature
Razor42
MY STORE
MY GALLERY
Profile
Posted: 22 October 2012 07:10 AM   [ Ignore ]   [ # 29 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
JavP - 21 October 2012 09:10 PM
Thank you.
Nodes : 114
Lights : 4
Cameras : 1
Scene Geometry :
Nodes : 60
Lights : 4
Cameras : 1
Scene Geometry :
Javier
You’re not likely to get 2.4 million faces rendered in a 32 bit environment with textures.  There’s not enough memory space available.  This isn’t a DS or 3Delight issue, just an issue of too much geometry for the environment.
If it isn’t in your viewport, delete it from the scene.  Seriously.  You’ve got a whole bunch of poly’s that are doing nothing for you except using memory.
Kendall
 Signature
Profile
Posted: 22 October 2012 09:50 AM   [ Ignore ]   [ # 30 ]
Member
Rank
Joined  2008-03-27
As I show you, the 1st frame that I can render at 4 level has this:
Scene Geometry :
Well, I have other scene width Michael 4 and a flight swit. All from DAZ content. The question is that only this combination have 246.000 faces. Put 3 pilots together and you will be out of limits. Or add a vehicle, a background, a second person and you will be again in the limits. This not seems to me very serious.
Kendall, yes. Shure that there is a lot of faces that can be deleted. But there are a lot of them that had to be putted to force to DAZ to understand surfaces that were perfectly in Hexagon, but not well displayed later by DAZ. Other part are an effort to make a model that can be used for very nearly takes too, and of course the rest are my own mistakes.
The question is that I am very, very, very tired to solve problems since June, to arrive to a no exit way. I will not redesign all… for memory limits… or from my point of view, software limits.
What machine will I need and what OS to render this in quality 4 ? I have a server with W2008, perfect to avoid memory limits, but it’s funny. Daz does not can be used into. Seriously. I will buy it.
I send you the only scene that I can render at this moment. No mountains, no sky, no surfaces. no pilot, no seat, no cupule, no tails, no flames, no, no, no, no…. nothing.
Javier
Image Attachments
Profile
2 of 4
2
