MelanieL - 26 May 2013 05:41 PM
Are you remembering to set the UVSet to M4 instead of the default (V4)?
Also if you then re-apply any textures, you’ll need to set it back to M4 again as it “forgets”, unless you lock the UVSet to M4 (little padlock symbol beside it).
Thank you MelanieL for your quick reply!
That totally did it and I’m looking forward to working with this Character once again!
Took me a little while to figure out what you were talking about as I’m getting used to DS instead of Carrara
For others new to the process,
1) Select your Genesis model
2) On the Surfaces tab Select Editor
3) Select the Genesis root node (so all the regiens are modified at the same time)
4) Scroll all the way to the bottom to UV Set
5)Select Michael 4 from the drop down menu
6) Lock the UV set with the pad lock icon.
Thank you again MelanieL.
**Update, a quick render using the Defiance textures on Valiant for M4
Click thumbnail to see full-size image
