Digital Art Zone
13 of 14
13
DSON Importer for Poser 1.0.0.13 is now available!
Posted: 07 November 2012 05:46 PM   [ Ignore ]   [ # 181 ]
Active Member
Avatar
RankRank
Joined  2005-11-27
Sunfire - 07 November 2012 01:40 PM
I’m waiting for when Stephanie 5 is DSON compatable.
It already is. Morphs don’t need Poser Companion Files as long as they are in DS4.5 format. Just install Stephanie 5 in the same place you installed Genesis, and it will show up in the morph dials when you load Genesis in Poser.
Profile
Posted: 07 November 2012 06:31 PM   [ Ignore ]   [ # 182 ]
Member
Avatar
Rank
Joined  2005-04-05
TheWheelMan - 07 November 2012 05:46 PM
That part I know, but there is the base Steph texture, and the rest of the stuff I got in my little bundle to go with her and not all of it is ready though some of it is released, but when I reset my bundle I don’t get updated files on what should be updated.
Profile
Posted: 08 November 2012 07:48 AM   [ Ignore ]   [ # 183 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
New version, new thread: DSON Importer for Poser, version 1.0.0.27
http://www.daz3d.com/forums/viewthread/11137/
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 19 December 2012 01:19 PM   [ Ignore ]   [ # 184 ]
New Member
Avatar
Joined  2006-02-25
I bought david 3 for genesis . It’s DSON importer compatible but there is only the DS4 installer . I tried to install the files in the genesis same
folder but I couldn’t ....
Profile
Posted: 19 December 2012 01:26 PM   [ Ignore ]   [ # 185 ]
Member
Avatar
Rank
Joined  2005-04-05
Yannich - 19 December 2012 01:19 PM
Install David 3 for Genesis in your directory as you normally would. Then go into Poser and load Genesis, then look through the morphs in the Genesis Figure you will find the David 3 morphs there.
Profile
Posted: 19 December 2012 01:34 PM   [ Ignore ]   [ # 186 ]
New Member
Avatar
Joined  2006-02-25
OMG, it’s so easy ! Thank you so much red face
Profile
Posted: 19 December 2012 01:35 PM   [ Ignore ]   [ # 187 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Yes, D3 for Genesis is only Shape dials, so there are no library files needed.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 19 December 2012 01:41 PM   [ Ignore ]   [ # 188 ]
New Member
Avatar
Joined  2006-02-25
Thank you . Next time, I’ll try before asking cool smile
Profile
Posted: 25 December 2012 05:04 PM   [ Ignore ]   [ # 189 ]
New Member
Joined  2008-11-17
I have tried a dozen different ways to install this for Poser Pro 2012 and every time I try to load a character I always get the same error message :Traceback (most recent call last):
  File “C:\Program Files (x86)\Smith Micro\Poser Pro 2012\Runtime\libraries\Character\ART_AndreaYT\+Andrea_Character.py”, line 1, in <module>
  import dson.dzdsonimporter
ImportError: No module named dson.dzdsonimporter
blank stare
Profile
Posted: 25 December 2012 05:16 PM   [ Ignore ]   [ # 190 ]
Member
Avatar
Rank
Joined  2005-04-05
Spookiie - 25 December 2012 05:04 PM
blank stare
First you can’t keep your DSON compatable content in your primary runtime. It has to be outside the main runtime structure in a directory it can write to.
Second make sure you have SR3 or later installed to your Poser, and that you’ve installed the right version for your version of poser.
Third, your DSON Importer needs to be installed in the main runtime so that it can properly execute the python scripts, and you MUST make sure you are using the right version and that it installed into the right place.  From the directory structure there, you’re using the 32 bit Poser Pro, so you must use the 32 bit installer for the DSON Importer and it must be installed in the right place.
Profile
Posted: 23 January 2013 07:37 PM   [ Ignore ]   [ # 191 ]
New Member
Joined  2005-07-10
Well great.  I was wondering about why the DSON program wasn’t discounting in the cart but it seems it doesn’t work in the first place.  Also I never did get a response for the help message I submitted about that issue.  That isn’t the way things are normally done here.  You saved me a lot of cash!
Profile
Posted: 24 January 2013 03:41 AM   [ Ignore ]   [ # 192 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
Choronzon - 23 January 2013 07:37 PM
You did add 20Dollars worth of DSON products to your cart?
http://www.daz3d.com/dson-all/
When and to whom did you write the help message?
 Signature
Profile
Posted: 24 January 2013 02:37 PM   [ Ignore ]   [ # 193 ]
New Member
Joined  2005-07-10
Over that!  V5 and M5 and the horse.  Nothing.
Profile
Posted: 24 January 2013 02:38 PM   [ Ignore ]   [ # 194 ]
New Member
Joined  2005-07-10
It was your help board so it was to no one in particular that I know of.
Profile
Posted: 24 January 2013 02:42 PM   [ Ignore ]   [ # 195 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Choronzon - 24 January 2013 02:38 PM
OK so you filed a help request, to Zendesk.  Did you send it to Sales dept, and give them all the information that they would need.?
When did you send the ticket?
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
13 of 14
13
