Digital Art Zone
Gen3 + Gen4 Characters to Genesis with Iconic shapes?
Posted: 16 October 2012 04:36 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2004-12-05
Its probably a stupid question, but I am still going to ask it *g*.
If I get the iconic G3 and G4 shapes for genesis, is it possible to use G3 and G4 characters with Genesis?
Probably not, but I’m not sure.
And if not, how do I make Genesis use - say a M4 texture?
And I read autofit will work now with gen3 clothing, but You need the Gen 3 shapes for it. Is this correct?
I’d really appreciate some “shortcuts”, as I’m really not very good at finding the answers *g*
So thanks in advance for any help.
 Signature
It does not do to leave a live dragon out of your calculations, if you live near him.
J.R.R. Tolkien
Profile
Posted: 16 October 2012 04:50 PM   [ Ignore ]   [ # 1 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
You can use V4 and M4 textures on Genesis without anything, built into DS. The Autofit should Work for V4 and M4 clothing items as well it is also built into DS. You do need the other figure shapes installed for use of the other Figures, and Textures that are not based on V4 and M4.
You can not use G4 or G3 morphs on Genesis without converting them to Genesis with the Gen X plugin. The Plugin requires you have the Genesis G4 and G3 shapes installed before it will convert the morphs to Genesis.
I hope this helps clear things up.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 16 October 2012 05:44 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2004-12-05
Thank You, that did help a lot. Now I have just one more question.wink Is there a method to get genesis clothes conforming to a Gen 4 figure? I tried to dial it in but I couldnt get to fit it at all…..
 Signature
J.R.R. Tolkien
Profile
Posted: 16 October 2012 07:21 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Rabe - 16 October 2012 05:44 PM
Genesis clothes are weight-mapped, so to use them on a Gen 4 figure you would need to rig them with old-style parametric Poser rigging.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 16 October 2012 09:34 PM   [ Ignore ]   [ # 4 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
fixmypcmike - 16 October 2012 07:21 PM
Also try this, do a Fit to, then Right click your figure in a area the clothing does not cover. In the Pop up menu pick this, Transfer Active Morphs, after it runs select the clothing item in the Scene Tab and open the Parameters Tab. Try Smoothing at other levels. This will not work for items that are not close at load but it might help, for the smoothing be sure V4 or the G4 figure is the collision target.
 Signature
Profile
Posted: 17 October 2012 02:36 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2004-12-05
Thanks for the explanation, unfortunately I don’t know a thing about rigging and stuff :-(
Jaderail - 16 October 2012 09:34 PM
Thank You, I tried, it looks better now.
Now I found this Tutorial
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/rigging/tutorials/transfer_utility/start
It did look pretty straightforward, so I thought i’d try .
The tutorial uses genesis as source figure and a clothing item as target.  Now I want to use M4 as source figure and a genesis clothing item as target., but I cannot select M4 as source.
Does it simply not work this way round or did I just miss any settings/options etc ?
Sorry for asking a lot of stupid questions, help would still be very much appreciated *g*
 Signature
J.R.R. Tolkien
Profile
