Thanks for the replies.
I haven’t used this function yet, but if you right-click there is an option Database/Edit Base Paths. From what I can make out you can use that to edit the path to content items. I suggest you try that.
I thought this was only for ‘My Library’ level if you are using moving drives or base folders. adamr001 covers this neatly in his tutorials but this is not my case.
If you move items inside the Content Library tab in DS rather than outside of DS, then the CMS will correct the metadata paths.
I am moving within the Content Library. Basically I move all content out of Vendor folders into folders for each costume/character etc. Then put all relevant Materials in that folder too. Until I setup Metadata for all my content that doesn’t have it the Smart Content tab is limited in value. So I use the Content Library a lot.
I have never had CMS do this yet, maybe it is a feature of 4.5 which I have just changed to. Is it meant to happen automatically?
