Digital Art Zone
53 of 100
53
Show Us Your Bryce Renders! Part 2
Posted: 01 December 2012 10:32 AM   [ Ignore ]   [ # 781 ]
Active Member
RankRank
Joined  2004-06-12
@Rareth
Nice renders, but don’t get any hopes up about FreeCAD until you try it because it’s not the same sort of thing as Wings and Hexagon etc.
@David
Don’t worry about the geometry unless you are forced to do it using two geometries, and even then, it’s just a matter of using a shell operation on your sweater or whatever clothes geometry you wish.  Any geometry basically just needs to be moved outwards slightly along it’s normals.  It’s an issue only if you let it be.  But anyway, best to test using the spheres because at least that way any geometry discrepancies can’t get in the way of visualising while you tweak it.
Already sounds as if two is needed then, that’s a shame although I thought as much.  As for the ticket, already supported that one, I remember that was for what resulted in being the in-scattering effect, but don’t see how it effects the Angora thing unless you have a trick up your sleeve already!
Profile
Posted: 01 December 2012 10:41 AM   [ Ignore ]   [ # 782 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
pumeco - 01 December 2012 10:32 AM
@Rareth
@David
one of the things to consider is if you DO succeed in recreating Angora with Bryce, it’s not going to transfer to other programs
 Signature
http://rarethdigitalmusings.blogspot.com/
http://rareth1966.deviantart.com/gallery/
Profile
Posted: 01 December 2012 11:06 AM   [ Ignore ]   [ # 783 ]
Active Member
RankRank
Joined  2004-06-12
He’ll definitely succeed, he already knows the basics of how to get such an effect even if I’d never mentioned two geometries.  I was pondering whether I should mention the two geometries or not, but I thought I’d better just to try and push him to manage it with just one (which would be much better if it could be done).  I suppose if the light hits it right then you could skip the base geometry and let the Volumetric hold it’s own effect, but it would probably have to be so dense it would lose the right effect and you would still need geometry beneath it anyway otherwise it would just look like a Volumetric material.
The problem I faced was that I couldn’t get the DTE to do what I wanted so that I could get it to work right with the hardness control for the Volumetric.  I remember that vividly, I’d never messed around with the Volumetric slider settings so much.  But I remember that video David made recently about creating skinny blades of grass in the DTE and even having control over the directions of them!  I only wish I had a grasp of that level of control when I was messing around with it.  I don’t have now, never mind back then.
But anyway, we don’t want it being able to transfer over to other programs, although that should be possible with any renderer that has Volumetric materials or Voxels.
Profile
Posted: 01 December 2012 11:06 AM   [ Ignore ]   [ # 784 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Several tricks…
OK, so this one has a valid mechanism.  But I need to now look at how it is held together.
Image Attachments
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 01 December 2012 11:13 AM   [ Ignore ]   [ # 785 ]
Active Member
RankRank
Joined  2004-06-12
Filthy crossposter!
Profile
Posted: 01 December 2012 11:15 AM   [ Ignore ]   [ # 786 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
The cutting edge of the centre one is particularly convincing. I have a problem with the one with thr blade half out. The angle seems queer to me. Otherwise, excellent models and light.
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 01 December 2012 11:24 AM   [ Ignore ]   [ # 787 ]
Active Member
RankRank
Joined  2004-06-12
I think it looks viable although I don’t like the body colour or square pattern.
Profile
Posted: 01 December 2012 11:29 AM   [ Ignore ]   [ # 788 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
David Brinnen - 01 December 2012 11:06 AM
Several tricks…
Nice Work, very impressive, I’ll take one
 Signature
Profile
Posted: 01 December 2012 11:33 AM   [ Ignore ]   [ # 789 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
eireann.sg - 01 December 2012 03:54 AM
When you still patrolled Platzspitz they only did Heroin and Shit and now its worse, right? LOL
Do they still distribute free syringes with the syringe packages lying all over the place?
That was fashinable in the late sixties and early seventies. No idea what they do now. Probably nothing you could learn anything decent from watching.
 Signature
Profile
Posted: 01 December 2012 11:35 AM   [ Ignore ]   [ # 790 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
pumeco - 01 December 2012 11:06 AM
20 mins on the render on my first attempt, and any attempt David makes will certainly exceed what ever I come up with,  so well see when it’s done cooking
 Signature
Profile
Posted: 01 December 2012 11:43 AM   [ Ignore ]   [ # 791 ]
Active Member
RankRank
Joined  2004-06-12
Cool, hurry up then, lets see it! :-)
Actually, now that I think about it I think Rashad would have been candidate for this one as well.  He managed that fancy velvet thingummy on a single material so who knows what he might have devised.  Then again I’m still waiting to see his rain scene with the scruffy Femme Fatale!
Profile
Posted: 01 December 2012 11:51 AM   [ Ignore ]   [ # 792 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
ok Angora first pass Single Material looks more lace than fuzzy sweater..
Image Attachments
 Signature
Profile
Posted: 01 December 2012 12:11 PM   [ Ignore ]   [ # 793 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
Angora 2nd Try,  part of the problem is trying to get it to look fuzzy without making it too transparent and having the image pulled for naughty bits.
this looks somewhat better
Image Attachments
 Signature
Profile
Posted: 01 December 2012 12:14 PM   [ Ignore ]   [ # 794 ]
Active Member
RankRank
Joined  2004-06-12
It looks nothing like Angora, but that said, it has a cool look of it’s own!
Pity the pattern didn’t have a thickness to it, because if you pulled that same pattern off with a Volumetric, it would look quite neat.
Profile
Posted: 01 December 2012 12:17 PM   [ Ignore ]   [ # 795 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
pumeco - 01 December 2012 12:14 PM
it is a volumetric material, they both are, you just really need two copies of the same object to get the fuzzy factor
 Signature
Profile
53 of 100
53
