Digital Art Zone
49 of 100
49
Show Us Your Bryce Renders! Part 2
Posted: 29 November 2012 07:53 AM   [ Ignore ]   [ # 721 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
eireann.sg - 29 November 2012 05:43 AM
LordHardDriven - 29 November 2012 05:05 AM
eireann.sg - 29 November 2012 04:49 AM
mermaid010 - 29 November 2012 02:14 AM
@ Dave – excellent work, do you do all your modeling in Bryce?
Bryce doesnt allow you to do any modelling unless you talk about trees and terrains.
What about boolean modeling? Haven’t you ever seen the Bryce Master series The Great Hall where the entire scene is built out of booleans made with primitives?
Do you really consider that modelling?
In the end you can make a shape that hast the volume of all shapes involved and its even possible that you cant put the final shape properly on the ground because when pushing the “Land objects” button it follows the bounding box and not the object. The final object can be smaller than the bounding box.
Based on this definition from wikipedia “In 3D computer graphics, 3D modeling is the process of developing a mathematical representation of any three-dimensional surface of object (either inanimate or living) via specialized software. The product is called a 3D model. It can be displayed as a two-dimensional image through a process called 3D rendering or used in a computer simulation of physical phenomena. The model can also be physically created using 3D printing devices.” Yes I consider it 3D modeling. There is nothing I’ve seen that says the model has to be able to be placed on the ground at the push of a single button to qualify it as a 3D model.
To me all it has to do is look like the object it’s a model of, in 3 dimensions. Placement on the ground can be achieved by other means and so what if it takes slightly more then the click of a single button. Now is it a model in the same way as a model from say 3D Max, Lightwave, Maya, ZBrush, etc. probably not but it’s a hell of a lot easier to pick up how to do it and create something worthwhile then it is with any of those other programs. Provided of course you can visualize the result of the boolean operation you plan on performing.
Profile
Posted: 29 November 2012 08:37 AM   [ Ignore ]   [ # 722 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Still tinkering… here I have tired to use curvature as a substitute for SSS - hence the “faceted” appearance of the model.  Curvature suffers most from Bryce’s mesh smoothing issues.  Don’t know if this would be a viable approach if the mesh was smoother… or not.  Just an experiment really.
Image Attachments
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 29 November 2012 09:09 AM   [ Ignore ]   [ # 723 ]
Active Member
Avatar
RankRank
Joined  2007-12-10
Yes, indeed it is modelling.
Here’s a way around that problem (if it is indeed a problem and I suppose it would be to some people)
Using the example of my barrels from earlier:
First Picture
Step 1: Make your shape out of primitives and set the positive and negative attributes to get the shape you need and make a group.
Step 2: With the group selected, go to ‘Objects’ in the top menu and select; ‘Convert Boolean to Mesh’.
Step 3: With the newly made mesh selected, go to File/Export Object and export your mesh as a Wavefront Obj file.
Step 4: Go to File/Import Object and navigate to where you saved your mesh and re-import it back into the document.
You will now have a perfect mesh who’s bounding box will not exceed it’s actual volume.
Second Picture
Render of the screen grab showing the finished barrel sat on the ground plane as well as the other two stages of construction.
Hope this helps.
Image Attachments
 Signature
I’ve got nothing of my own to promote, no models, no tutorials, no website, nothin’, nada, nill, nowt.
Profile
Posted: 29 November 2012 10:52 AM   [ Ignore ]   [ # 724 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
TheSavage64 - 29 November 2012 09:09 AM
First Picture
Second Picture
Hope this helps.
wow thanks I learned something new about bryce.. fun fun fun
Image Attachments
 Signature
http://rarethdigitalmusings.blogspot.com/
http://rareth1966.deviantart.com/gallery/
Profile
Posted: 29 November 2012 06:21 PM   [ Ignore ]   [ # 725 ]
Member
Avatar
Rank
Joined  2012-10-14
First Picture
Second Picture
Hope this helps.
Yes, that helped. I would never have thought of that rather complicated way of getting rid of the additional baggage Booleaning with Bryce comes with.
Maybe it would be an interesting feature to modify the function of the Convert button so that Boolean shapes are immediately simplified so that the user doesnt have to go through the export and reimport steps.
Profile
Posted: 29 November 2012 06:28 PM   [ Ignore ]   [ # 726 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
All this talk of modelling inspired me to give an idea I’ve had rattling around in the back of my head a trial.
Turned out to be a bit trickier than I imagined. I thought a pocket knife would be fairly simple, but it turned out to be a bit of a challenge. On the plus side, I learned more of Wings 3D in the process.
I can see where I can improve my design. The gimping on the back of the blade could do with being deeper and also some corresponding gimping on the handle would be nice. The back lock is a bit high. The finger choil could do with being larger and the flipper is not quite long enough to reach through the back. The hole at the back is actually a bit of a hazard I see now, since you could put a finger through that while inadvertently closing the blade - what would be bad.
The blade is supposed to be bead blasted black - perhaps a bit too shiny.
The handle is intended to be G10 but it looks more like FRN.
The metal inlay is more a fancy of my own invention - would probably make this a rather expensive proposition for a pocket knife.
Comments welcome on either the design or the render. I don’t mind.
Horo’s HDRI Treppenhalle 2 used for backdrop and lighting via obscure light method through TA gels.
Image Attachments
 Signature
Profile
Posted: 29 November 2012 06:38 PM   [ Ignore ]   [ # 727 ]
Member
Avatar
Rank
Joined  2012-10-14
David Brinnen - 29 November 2012 06:28 PM
I find the knives look very nice. Does it always have to look 100% realistic?
BTW: I just found that if you create boolean shape, export it to [NAME].obj and re-import it then you dont have a single shape but a group of fragment which can be ungrouped and torn apart.
Profile
Posted: 29 November 2012 07:14 PM   [ Ignore ]   [ # 728 ]
Member
Avatar
Rank
Joined  2003-10-09
Wow David - you and Savage are doing some of the best photo-realistic images I’ve seen in Bryce…
Profile
Posted: 29 November 2012 07:46 PM   [ Ignore ]   [ # 729 ]
Active Member
Avatar
RankRank
Joined  2007-12-10
eireann.sg - 29 November 2012 06:21 PM
Well it only takes seconds to do, so it’s not like it adds loads of time to the process and in my opinion, is still easier and quicker than trying to extrude a shape in Carrara or the other modelling applications that I’ve tried out in the past. But I am so familiar with the Bryce interface that I will be biased about it’s ease of use. smile
 Signature
Profile
Posted: 29 November 2012 08:00 PM   [ Ignore ]   [ # 730 ]
Active Member
Avatar
RankRank
Joined  2007-12-10
I’m convinced… after I’d got my head around the fact that it’s the straight edge that’s sharp. I was originally looking at it as if the curved edge was the sharp bit… which was confusing.
Materials and lighting look great though.
 Signature
Profile
Posted: 30 November 2012 12:42 AM   [ Ignore ]   [ # 731 ]
Member
Avatar
Rank
Joined  2012-10-14
TheSavage64 - 29 November 2012 07:46 PM
Actually it adds loads to rendering time.
7 spheres render faster than one sphere minus 6 spheres.
Profile
Posted: 30 November 2012 01:52 AM   [ Ignore ]   [ # 732 ]
Member
Rank
Joined  2008-11-26
chohole - 29 November 2012 07:18 AM
You would probably hate to see the wire frame of my village, but you can see that I have everything on the ground, not floating.
It may not be quite as intuitive as modelling programs are to some people, but I personally love modelling with booleans within Bryce,
I have been known to say that it is not true modelling per se, more like using building blocks, with the advantage of having subtractive building blocks as well as additive ones.
But it is fun, some of us love using booleam operations, and some (ie like the Person Horo linked to) have created some masterpieces.
Horses for courses.
It will be interesting to see the wireframe of your scene smile
Profile
Posted: 30 November 2012 02:00 AM   [ Ignore ]   [ # 733 ]
Member
Rank
Joined  2008-11-26
First Picture
Second Picture
Hope this helps.
Thanks Dave for the explanation, much appreciated.
Profile
Posted: 30 November 2012 02:04 AM   [ Ignore ]   [ # 734 ]
Member
Rank
Joined  2008-11-26
I like the knives David, they look like someone retrieved them from the bottom of the ocean, sunken treasure.
Profile
Posted: 30 November 2012 03:40 AM   [ Ignore ]   [ # 735 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
eireann.sg - 29 November 2012 06:38 PM
No it doesn’t have to look realistic, but if I could get it 100% realistic that would satisfy one of my aims with this scene.
On the topic of converting, exporting and re-importing, if you want to experiment further and you don’t already know this, the wireframe mesh resolution is involved in the conversion calculation (image 1).  I’m not sure which it is… vague memories suggest it is selected - but it would be worth testing all of them to be certain… being selected makes sense though, since the object has to be selected before it can be converted.
Dan, thank you!  I keep trying to push things a little bit further - but for skin, the lack of inbuilt SSS is proving a real stumbling block.
Dave, yes, well, I’m not really into “stabby” knives.  I wanted to design something practical and also - easy to sharpen - which I thought the straight blade might be good for.  For work I have a variety of folding locking knives (which stay in my tool box unless being used), but it is difficult to get ones that haven’t been designed to have some kind of “tactical” element - the result of which is that I end up stabbing myself by accident.  Because it is useful for when scrambling through roof spaces, I have a UK legal SOG slip knife (with a tanto blade - again a pointlessly stabby shape - but the blade is about 1 1/4 inches long so inoffensive) and a Blackhawk safety cutter - which handily incorporates a broad flat screwdriver just the right size for turning off isolation valves.
And I realised too, I missed out provision for a thumb stud for one handed opening.  Which is very useful when you have your hands full!  I’d also put one on each side to make it ambidextrous.  And likewise a back lock over a frame lock or liner lock, because not only is it stronger, it’s also ambidextrous.
mermaid010, oh, they were supposed to be new.  I have some corroded metals I could use… but I’d have to eat into the blade to do it properly.
Thanks for the feedback!
Image Attachments
 Signature
Profile
49 of 100
49
