Digital Art Zone
26 of 100
26
Show Us Your Bryce Renders! Part 2
Posted: 11 November 2012 06:47 PM   [ Ignore ]   [ # 376 ]
Member
Avatar
Rank
Joined  2004-06-24
Stanford models in converted file formats free download zip files those that would like to have them are available here.
www.mrbluesummers.com
Cheers
GG
 Signature
WHO said Kiwis can’t fly ?????
Profile
Posted: 12 November 2012 01:02 AM   [ Ignore ]   [ # 377 ]
Member
Avatar
Rank
Joined  2012-10-14
kiwi_gg - 11 November 2012 06:47 PM
Cheers
GG
Thanks for the very helpful link smile
Profile
Posted: 12 November 2012 01:08 AM   [ Ignore ]   [ # 378 ]
Active Member
Avatar
RankRank
Joined  2011-09-25
@Roland:  Both of those images look nice.  I’ve seen areas like the first image in the RW, but for monitor display the second is better.
@Horo:  Thank you.  That image was one of the first ones I made after getting Bryce.  I didn’t know what I was doing, or what to do, but I liked how the whole image turned out and kept it.
This is another of my very first images after getting Bryce.  It was just play, but I liked its look and hung onto it.  I called it Perfect Landing.
Image Attachments
 Signature
If you constantly look backward, it’s guaranteed you’ll run into something on your forward journey.
Profile
Posted: 12 November 2012 01:31 AM   [ Ignore ]   [ # 379 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
David Brinnen - 11 November 2012 03:18 AM
mermaid010, you asked “Why don’t you do some for beginners, most of your videos are for intermediate or advance Brycers.”
The answer to that is that there are 100’s possibly 1000’s of tutorials for beginners already made - and a lot them can be accessed through the Bryce-Tutorials.info website.  So to make more would be “reinventing the wheel”.  What I want to cover, mostly, is tutorials that take advantage of as yet undocumented Bryce 7.1 Pro features.  Tutorials that provide information that isn’t available anywhere else and to promote the use of the new feature set.
Perhaps a nice thing you and Horo could do is go thru at sometime and review the more beginner oriented tutorials on your site and come up with a group of those beginner tutorials that form a comprehensive base of knowledge from which a beginner might move from beginner to intermediate. That way rather then just saying you don’t really do beginner level tutorials you could point people to this group of “reccommended” tutorials?
On a different note, there is something I’ve been meaning to ask if you could do sometime but I keep forgetting. In the Pro Materials that come with Bryce 7 Pro are a number of libraries named with a three letter prefix followed by your name such as Mop_davidbrinnen, Org_davidbrinnen, Pal_davidbrinnen, for examples. I’ve included a picture below that shows what I’m talking about. Each of these libraries contain a fair number of materials but the descriptions all read like Mop Varient followed by www.davidbrinnen.com. Now the reason I mention just these libraries and not all of the libraries in the Pro Materials section is because these libraries with the 3 letter prefix followed by your name all lack something the others do not. They lack a name and/or description that give you some clue as to what the material is and/or how to best use it. All the other libraries contain materials whose name makes it clear what the material is for and/or a description that gives useful tips on using the material. What I’m asking is, would you consider producing a list of names and descriptions for these libraries and materials so that one could get a sense of if a particular material would work for something they’re working on without having to go thru and keep trying random materials hoping one might work for them? I think if you did and then made that list available to people or even better yet apply the names and descriptions in an update of the installer containing the pro materials, it would help the users to start making better use of those materials. I suspect that largely those materials get skipped over because people don’t know what they are or what to use them for and they don’t want to bother with radomly plugging materials in to try to figure them out.
Image Attachments
Profile
Posted: 12 November 2012 01:43 AM   [ Ignore ]   [ # 380 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
eireann.sg - 11 November 2012 06:25 PM
Horo - 11 November 2012 01:43 PM
@eireann - Meshlab can convert the Stanford files. LordHardDriven helped me with comments. Meanwhile, I made a small tutorial that can be found on my website (see sig). Go to Bryce Documents > Guests (PDF) > Objects > Preparing Objects for Bryce using MeshLab
GussNemo - 11 November 2012 11:42 AM
@eireann:  As to the Stanford Models, there is a Mesh Converter you can download.  I’ve not used it yet, but you can use it to convert those models so they can be used in Bryce.  Maybe Horo can explain how it’s done.
Horo, GussNemo,
thanks for the tip.
My problem is how to open the compressed files. they have a .tar.gz format which my computer cant open.
if the files were .zip files then no problem.
My old computer came with Winrar, maybe I can try that.
Winrar can open that format of archive (called a tarball I believe) but you might have to specify for winrar to open it in the file associations part of the program first, which can be found under Options -> Settings -> Integration
Profile
Posted: 12 November 2012 01:46 AM   [ Ignore ]   [ # 381 ]
Member
Avatar
Rank
Joined  2009-10-02
I think now it´s best results.
Image Attachments
Profile
Posted: 12 November 2012 02:10 AM   [ Ignore ]   [ # 382 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
pumeco - 11 November 2012 05:59 PM
Still going through David’s videos and have to say that strange reflection issue seems quite a biggie!
Thing is, if they fix it it might increase the render times because I’m guessing Bryce is missing out some calculations in order to arrive at those effects.  A bit like telling a Radiosity renderer to ignore, say, some reflection characteristics to speed things up a bit.
So far as I’ve been able to tell from testing, it seems to be something to do with the anisotropic vector response.  What reflection is applied under certain conditions, even if specularity is set to 0, linking between diffuse and reflection automatically generates a specular response.  This in turn causes the render engine to consider specular halo settings and anisotropic vectors - even when you don’t want it to - even when anisotropy is set to zero also it seems.  I think this is because the reflection control tries to be “helpful” - you can observe this yourself in a series of tests by making comparisons between response of the diffuse channel under the changing circumstances of reflection without channel control, reflection through alpha channel and reflection through alpha channel with alpha scaling.  Running all three at 50% - different outcomes occur.  What is not clear at first glance is that specular response according to specular halo values also shifts.  But by isolating in an entirely lit by specular environment, this seems to be so also.  Helpful but annoying at the same time.
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 12 November 2012 02:35 AM   [ Ignore ]   [ # 383 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
LordHardDriven - 12 November 2012 01:31 AM
For the tutorials there will be a rating system on the website to allow for peer review.  Another reason that I don’t do beginner tutorials is because I’m not really in a position to judge what is the most appropriate thing for a beginner to know is (though it is kind of you think that I am).  However I am self taught, and for a year or more all I had was the Bryce 5 manual and Bryce 5 - the internet was yet to arrive in our town.  I did the tutorials in the manual and then started making stuff up.  I spent a lot of that time just fiddling with the DTE - if I had had access to the tutorials on line, I might have taken more of an interest in modelling, or making scenes.  I don’t know if that would be better or not.  So what I’m saying is, my perspective is rather biased.  Judgements made by beginners will be of more value since beginners will know what can drive them forwards with enthusiasm in their hobby.
As for the materials… well if you’d have asked me this in 2005 when I gave them to DAZ 3D, then I would have known what to say.  But somehow they got lost in the system and have only resurfaced recently (I believe the disparity between “DAZ time” and time as we experience it in every day life has already been discussed elsewhere - so I hardly need to labour the point here).  But after all this time (real time), even I don’t know what they are all for.  Probably the best thing I can do, is make a tutorial about how to go about assessing what a material might be useful for by looking at the material properties.  This then will not only solve the issue of the mysterious materials, but it will solve the issue of future mysterious materials.  And it will be an interesting thing to do and it will be something new - newer than seven years ago!  I could also cover what to do to go about updating them to include modern features.  Maybe I will make a tutorial for each set.  That should cover a lot of options.  How does that sound?
 Signature
Profile
Posted: 12 November 2012 04:11 AM   [ Ignore ]   [ # 384 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Bryce 10 minute render project - combine two renders with a mask in PSP8 - by David Brinnen
A topic from a few pages ago…
Image Attachments
 Signature
Profile
Posted: 12 November 2012 04:35 AM   [ Ignore ]   [ # 385 ]
Member
Rank
Joined  2008-11-26
Jamie, glad to hear you got your video watching issues sorted.
The answer to that is that there are 100’s possibly 1000’s of tutorials for beginners already made - and a lot them can be accessed through the Bryce-Tutorials.info website.  So to make more would be “reinventing the wheel”.  What I want to cover, mostly, is tutorials that take advantage of as yet undocumented Bryce 7.1 Pro features.  Tutorials that provide information that isn’t available anywhere else and to promote the use of the new feature set.  Many of the features in themselves are not hard to use, a beginner could easily turn IBL or TA but… a beginner would not really understand the role of these features in a way a more experienced user would instantly grasp - so I am careful to stress that the tutorials are intended for intermediate to advanced users to try to avoid confusion and frustration for beginners.
eireann.sg, nice modelling and rendering.
Some more Happy Buddha’s
I agree with you, David there are 100s of tutorials for beginners online. Robin Wood’s tutorials are great, but you have wonderful way of explaining things – a great teacher. Your videos are fascinating and I’m encouraged to try them, even though I don’t understand what I’m doing. Normally I follow what you are doing. I was hoping you will direct me to some of your earlier videos, not found on Bryce-info, but going by your reply to LordHardDriven, I guess there aren’t any.
This is a proof of your teaching method. This is my very first attempt at using Wings3d. I downloaded the program on Saturday.
These two examples were done, following your Wings3D to render to postwork, but I did not follow the video completely. I used a preset sky from the Fantasy-Scifi catergory.  I used the materials for the Wing3d and the ground plane as per the video, used the sky for the hdri and the settings you suggested for the IBL and Render option except that I used 64RPP and not 256RPP for the final render.
In 2nd image-  I changed the ground plane to reflective, and added a reflective material to the object and rendered with Superfine 64RPP.
I did not save as the images as hdri or follow the rest of the video as it was a bit beyond my comprehension. Hopefully it is something to look forward at a later date.
Thanks for introducing me to a new toy. Wings3d is a cool program and its free. grin
Unfortunately I’m one of those people who needs to settle for freebies. downer
Image Attachments
Profile
Posted: 12 November 2012 04:41 AM   [ Ignore ]   [ # 386 ]
Member
Rank
Joined  2008-11-26
David Brinnen - 12 November 2012 02:35 AM
Sounds great to me and I will be looking forward to them.
Profile
Posted: 12 November 2012 06:32 AM   [ Ignore ]   [ # 387 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
LordHardDriven - 12 November 2012 01:43 AM
[Horo, GussNemo,
thanks for the tip.
I use the Total Commander http://www.ghisler.com/ which is shareware. It can also open Linux tar and gzip files and it does so as if they were folders. You can copy out of archives and into archives without ever unpacking them. I have used this tool since Windows 3.1, Updates are free forever if you get a license for $44.
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 12 November 2012 06:38 AM   [ Ignore ]   [ # 388 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
I love my free ExtractNow: http://www.extractnow.com/
What archive types are supported?
  zip (+jar,xpi), bzip2 (+bz2,tbz2,tbz), rar, arj, z, lzh (+lha), 7z, cab, nsis, lzma, lzma86, xz (+txz), ppmd, udf, xar, mub, hfs, dmg, compound (+msi,doc,xls,ppt), wim (+swm), iso, chm (+chm,chi,chq,chw,hxs,hxi,hxr,hxq,hxw,lit), split (+001), rpm, deb, cpio, tar, gzip (+gz,gzip,tgz,tpz), mslz, flv, swf, ntfs (+ntfs,img), fat (+fat,img), mbr, vhd, pe, elf, apm, macho, ace, sit
I don’t know of any other that opens sit on a PC.
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 12 November 2012 06:39 AM   [ Ignore ]   [ # 389 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
Cheers
GG
Thank you!!!
 Signature
Profile
Posted: 12 November 2012 06:42 AM   [ Ignore ]   [ # 390 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
@LordHardDriven - concerning the names of David’s contributions to the materials library. I understand what you say. In fact, David and I had discussed that several years ago when I wanted to change names and add comments. Problem is, if you do not name each new item for the library and add a comment at the moment you save it, you’ll forget about the details as soon as you add more. Working on a project can mean creating a couple of materials, and naming and commenting each one will hinder the development of the scene.
 Signature
Profile
26 of 100
26
