Digital Art Zone
80 of 100
80
Show Us Your Bryce Renders! Part 2
Posted: 12 December 2012 04:30 PM   [ Ignore ]   [ # 1186 ]
Member
Avatar
Rank
Joined  2009-05-04
GeroblueJim - 12 December 2012 04:10 PM
GeroblueJim - 11 December 2012 05:38 PM
Trying something that looks better. Two rocks, and two terrains. Basically, water level, with a ground plane and the 4 objects. I tried to change the water level, but it doesn’t look like I thought it would. Rocks Beneath, turbulent. I have downloaded Bryce Pro, but not had a chance to install it yet. The orignal is larger, but I cropped it as the rest is open ocean.
Any suggestions on how to improve this ?
Thanks.
Try to change the angle of your camera. This way it looks dull. Show us a bit of your heaven. Further it depends of your intention. Realistic isalnds? Stones in the water?
Profile
Posted: 12 December 2012 05:12 PM   [ Ignore ]   [ # 1187 ]
Active Member
RankRank
Joined  2004-06-12
I might not have much time to post, but I still intend to read for now, and bloody hell, Armageddon thread or what.
It’s even less Bryce-related than the Bryce post-work!
You wouldn’t catch me going off topic like that!
Profile
Posted: 12 December 2012 05:17 PM   [ Ignore ]   [ # 1188 ]
Active Member
RankRank
Joined  2004-06-12
@dwsel_
Liking the post-work.
@Roland
Liking the Bridge render, I actually prefer the dark one, I like the overall feel of it better.
Profile
Posted: 12 December 2012 05:20 PM   [ Ignore ]   [ # 1189 ]
Member
Avatar
Rank
Joined  2010-11-24
electro-elvis - 12 December 2012 04:30 PM
Thanks.
More realistic islands, with a beach along one side, flat areas. Maybe some buildings later on. As for the rocks, birds could live out there, or some ruins with birds.
More of a side view showing the sky. I can change the sky, I just clicked sky view and took the one it gave. I think a bluer ocean and a night sky with moonlight would look better. What do you think ?
(Signing off for sleep, I get up about 2 hours after midnight and head for work.)
Image Attachments
 Signature
‘Through the thorns to the stars.’ from Ghost in the Shell.
Profile
Posted: 12 December 2012 06:08 PM   [ Ignore ]   [ # 1190 ]
Member
Avatar
Rank
Joined  2012-10-14
Roland4 - 12 December 2012 08:28 AM
@eireann.sg
better now ?
Yes, better now.
Its nice to see some details and some more colours.
You dont want to burn your colours with too much light but there should be enough light to show everything you want to show and the lights and / or sun should create the right amount of shadow so the picture doesnt look flat.
If that was a photo of mine I would colour correct it towards blue to get rid of all the red.
Profile
Posted: 13 December 2012 01:41 AM   [ Ignore ]   [ # 1191 ]
Active Member
Avatar
RankRank
Joined  2007-12-10
GeroblueJim - 12 December 2012 05:20 PM
Welcome GeroblueJim.
It’s a good starting point, but the first thing I would do would be to create a viewpoint and composition that showed off the depth of the scene.
Think about foreground, mid ground and background and try to get the elements to overlap each other, this will further increase the illusion of depth.
In the render below, I’ve tried to keep the elements the same as the ones you’ve used, but you’ll notice I’ve got the camera much lower so that the islands are overlapping the horizon line breaking it up and that the foreground island is most definitely in front of the background island.
I’ve then further added to the depth and illusion of distance by increasing the thickness and density of the haze (in the sky lab).
Other things I’ve done to tweak the basic materials are to try and make sure that the geology matches, so both islands are covered in the same basic material and the two rocks are a similar colour to the rock showing through on the islands.
Don’t be fooled into thinking Clam Waters are actually calm, usually I have found they produce much better reflections and tweaking the frequency will allow you to lose the almost grid-like uniform appearance of the waves. In my render I’ve used Calm Water; Deep Sea.
Finally, to make the beach, I duplicated the terrain and flattened it out, dropped it down to ground level and gave it the standard ‘Bright Beach Sand’ material which you’ll find in Terrains in the Plains sub category in the material library.
Hope this helps as a starting point for you to produce a landscape you will then be ready to start populating with buildings, birds and maybe some ships. smile
PS: You really should take advantage of the free Bryce Pro 7 download though as it’s capabilities are much better and the extra content supplied by our very own David Brinnen will help you to achieve more realistic materials in your islands.
Image Attachments
 Signature
I’ve got nothing of my own to promote, no models, no tutorials, no website, nothin’, nada, nill, nowt.
Profile
Posted: 13 December 2012 02:10 AM   [ Ignore ]   [ # 1192 ]
Active Member
Avatar
RankRank
Joined  2011-09-25
@Roland:  The last image is, IMHO, much better.  If only because we now can see the good detail you created.  I too would lean away from as much red as you’ve applied.  But that’s me.  As Horo said, you have the final say so.
@electro:  That’s a mighty fine looking knife.  Nice job.
@Geroblue:  That’s a nice start.  Besides what The Savage told you, also keep in mind to keep adjacent object in perspective.  If you have an island, like you have, then the surrounding rocks would be much smaller than the island itself.  Looking at your last image, the rock behind the green island is almost as large as the green island.  To combat this either make the island larger or the rock smaller.  Same goes for the other rock.  You could move the other island back a bit and, with its current size, use it to portray a distant island like The Savage has shown.
 Signature
If you constantly look backward, it’s guaranteed you’ll run into something on your forward journey.
Profile
Posted: 13 December 2012 06:56 AM   [ Ignore ]   [ # 1193 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
Thanks.
this is a great start, I will also suggest you get the Bryce 7.1 pro (its free) and the included Pro content files that come with it, should be 3 downloads in all, some of the materials included are fantastic, also might I suggest the bryce tutorials site, it is an excellent resource for Bryce users .
http://www.bryce-tutorials.info/index.html
 Signature
http://rarethdigitalmusings.blogspot.com/
http://rareth1966.deviantart.com/gallery/
Profile
Posted: 13 December 2012 12:49 PM   [ Ignore ]   [ # 1194 ]
Active Member
Avatar
RankRank
Joined  2007-12-10
A few more Peter The Polar Bear pics.
Image Attachments
 Signature
Profile
Posted: 13 December 2012 01:12 PM   [ Ignore ]   [ # 1195 ]
New Member
Avatar
Joined  2008-04-14
“December”
Image Attachments
Profile
Posted: 13 December 2012 04:24 PM   [ Ignore ]   [ # 1196 ]
Member
Avatar
Rank
Joined  2010-11-24
I have 7Pro installed. Moved the second island further away. Changed the ocean. Added a sand ground plane… I think I lost in the ocean somewhere…  I shrunk the rocks and changed the sky. Looks like i’m too far away from the front island. When I find the sand ground pane and get it to render, I’ll post both pictures.
 Signature
Profile
Posted: 13 December 2012 04:44 PM   [ Ignore ]   [ # 1197 ]
Member
Avatar
Rank
Joined  2010-11-24
Sand… I thought I had grabbed the small ground plane under the front island… but got the sea instead.
I tried the ‘layer cake’ method by looking in from the side, and moving each layer up until well separate. Got the ocean back to ocean, and lost the sand somewhere.
Second picture is without sand.
Image Attachments
 Signature
Profile
Posted: 13 December 2012 04:44 PM   [ Ignore ]   [ # 1198 ]
Power Member
RankRankRank
Joined  2004-07-01
GeroblueJim - 13 December 2012 04:24 PM
use the TAB key to move from obj to obj - it will have red outline
Profile
Posted: 13 December 2012 05:23 PM   [ Ignore ]   [ # 1199 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
TheSavage64 - 13 December 2012 12:49 PM
I keep expecting to see a bottle fo coke or a can of pepsi in these Polar bear pictures they remind me so much of the holiday commericals.
 Signature
Profile
Posted: 13 December 2012 05:52 PM   [ Ignore ]   [ # 1200 ]
Member
Avatar
Rank
Joined  2008-11-04
Rareth - 13 December 2012 05:23 PM
I keep expecting to see a bottle fo coke or a can of pepsi in these Polar bear pictures they remind me so much of the holiday commercials.
Exactly what I was thinking, LOL!
Has anyone done the little santa riding on the Norelco razor? That ad’s been running every year since I can remember!
 Signature
“We probably wouldn’t worry about what people think of us if we could know how seldom they do.”
Mark Twain
Profile
80 of 100
80
