Digital Art Zone
79 of 100
79
Show Us Your Bryce Renders! Part 2
Posted: 12 December 2012 02:57 AM   [ Ignore ]   [ # 1171 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
_ PJF _ - 11 December 2012 06:25 PM
Don’t know much about history…
but I do know that I can’t figure out where I’ve gone wrong with setting up the tutorial scene. Whilst this is low noise for boost light use, it’s way higher than appears in David’s scenes. There’s aliasing too.
Actual size at 256 AD - sorry, rpp.
My scenes are mostly lit with a large fairly even TA light-sources and that helps a lot with the noise.  Also… I often add one or two normal radial lights here and there, because this also reduces noise.
In your example, your predominant light source is relatively speaking small.  And the smaller it gets the worse the noise gets I’ve found.  So what I would do is put a few ordinary radial lights inside the lit sphere that don’t include the lit sphere as a target and supplement the TA effect.  It won’t be as nice and pure as your original example, but it should help with the noise.
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 12 December 2012 06:20 AM   [ Ignore ]   [ # 1172 ]
Member
Avatar
Rank
Joined  2009-10-02
The bridge
Image Attachments
Profile
Posted: 12 December 2012 06:32 AM   [ Ignore ]   [ # 1173 ]
Member
Avatar
Rank
Joined  2012-10-14
Roland4 - 12 December 2012 06:20 AM
The bridge
Any more light?
It looks so dark and in the dark all details get lost.
Profile
Posted: 12 December 2012 07:11 AM   [ Ignore ]   [ # 1174 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
Roland4 - 12 December 2012 12:25 AM
@Rareth
better now ?
it looks great, although I’m not the one that commented on the DOF in the first render.
 Signature
http://rarethdigitalmusings.blogspot.com/
http://rareth1966.deviantart.com/gallery/
Profile
Posted: 12 December 2012 07:44 AM   [ Ignore ]   [ # 1175 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
ok screen grabs of the specular halo setting I’ve been playing with, I’m sure the guru’s could come up with a better way to do this.. or even make what I’ve done work alot better than what I have done so far..
also attached a wire showing how the dome lights are set in the scene.
Image Attachments
 Signature
Profile
Posted: 12 December 2012 08:28 AM   [ Ignore ]   [ # 1176 ]
Member
Avatar
Rank
Joined  2009-10-02
@eireann.sg
better now ?
Image Attachments
Profile
Posted: 12 December 2012 12:19 PM   [ Ignore ]   [ # 1177 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
This is a beautiful scene, Roland. If you contemplated it that way, than everything is fine. My suggestion would be to add a stronger light from a direction, e.g. sunlight, to give it more contrast. The lit part are only a bit brighter than the shadows. This would also give the scene a better 3D feeling.
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 12 December 2012 12:52 PM   [ Ignore ]   [ # 1178 ]
Member
Avatar
Rank
Joined  2009-10-02
Thanks Horo. Over the scene in the middle is a blue Radial Light with 0 specular and 4 diffuse and no shadow. Behind the camera is the same but the color is a dark red.
Profile
Posted: 12 December 2012 01:51 PM   [ Ignore ]   [ # 1179 ]
Member
Avatar
Rank
Joined  2009-10-02
and now i have add a additional Radial Light from the direction of the sun.
Image Attachments
Profile
Posted: 12 December 2012 01:54 PM   [ Ignore ]   [ # 1180 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
As I said, the artist is the final judge of his/her artwork. Personally, I think it improved.
 Signature
Profile
Posted: 12 December 2012 02:38 PM   [ Ignore ]   [ # 1181 ]
Member
Avatar
Rank
Joined  2008-11-04
Roland4 - 12 December 2012 01:51 PM
Do you, by any chance, use a Mac? Just curious..
 Signature
“We probably wouldn’t worry about what people think of us if we could know how seldom they do.”
Mark Twain
Profile
Posted: 12 December 2012 03:00 PM   [ Ignore ]   [ # 1182 ]
Active Member
Avatar
RankRank
Joined  2010-02-18
Brrrrr…cold tonight in the observatory. Still, that galaxy in the ‘scope’s eyepiece would warm the coldest of astronomer hearts.
Title: “Moments in the eye”.
Jay
Image Attachments
Profile
Posted: 12 December 2012 03:17 PM   [ Ignore ]   [ # 1183 ]
Member
Avatar
Rank
Joined  2009-10-02
cjreynolds - 12 December 2012 02:38 PM
No, win 7 PC.
Profile
Posted: 12 December 2012 04:05 PM   [ Ignore ]   [ # 1184 ]
Member
Avatar
Rank
Joined  2009-05-04
I am not the fastest, I know. That’s why I was still working on a knife (David and Dave inspired me to it). It is a pure Bryce model. All materials are from the library. An ordinary sky.
Image Attachments
Profile
Posted: 12 December 2012 04:10 PM   [ Ignore ]   [ # 1185 ]
Member
Avatar
Rank
Joined  2010-11-24
GeroblueJim - 11 December 2012 05:38 PM
Trying something that looks better. Two rocks, and two terrains. Basically, water level, with a ground plane and the 4 objects. I tried to change the water level, but it doesn’t look like I thought it would. Rocks Beneath, turbulent. I have downloaded Bryce Pro, but not had a chance to install it yet. The orignal is larger, but I cropped it as the rest is open ocean.
Any suggestions on how to improve this ?
Thanks.
 Signature
‘Through the thorns to the stars.’ from Ghost in the Shell.
Profile
79 of 100
79
