Digital Art Zone
74 of 100
74
Show Us Your Bryce Renders! Part 2
Posted: 09 December 2012 10:20 AM   [ Ignore ]   [ # 1096 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Horo - 09 December 2012 09:52 AM
pumeco - 09 December 2012 09:10 AM
BTW, does anyone know what the “installed” minimum requirement is for Bryce 7 Pro in size?  I might be able to delete a few demo programs I have to make space if it’s not too much.  I might be able to install the program without the extras assuming they fixed the material crash that used to occur if you failed to install the materials as well.
You should be fine with 745 MB installed. That’s what I have from my PLE installation.
My Bryce 7 pro installation is actually less than that for some reason, only showing as 623 MB, installed on drive D
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 09 December 2012 10:28 AM   [ Ignore ]   [ # 1097 ]
Active Member
Avatar
RankRank
Joined  2007-12-10
LordHardDriven - 09 December 2012 09:21 AM
What would really sell the stiches for me would be if there was a slight indication of pulling the material together, little depressions where the stitching passes thru the material it’s stiching together. The way it is now it looks like the stiching is there more for show then to actually bind the material together. As it is now it’s as if the layers of leather are completely rigid with absolutely no give or flexibility and the stiching is unable to pull the material together any more then the pieces just being laid on top of each other. Below are some example images that show the look I’m trying to describe
Yes, that was my concern with the stitches too.
I’ve no idea how I could create that effect though, without having to make 100 negatives to boolean model to the sheath (there are 100 stitches. And as the sheath is already a complex boolean model, it wold mean having to ungroup certain parts and it would all get way too messy and confusing for me.
What I am going to try however is using ‘Transfer material of negative boolean’ to try and get a logo gold embossed on the belt loop section.
 Signature
I’ve got nothing of my own to promote, no models, no tutorials, no website, nothin’, nada, nill, nowt.
Profile
Posted: 09 December 2012 10:38 AM   [ Ignore ]   [ # 1098 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
TheSavage64 - 09 December 2012 10:28 AM
Yeah it would be rather tedious and I was thinking along the same lines only worse, I was thinking little negative toruses <sp?> at every point the stitch passed thru to create a depression. So if there are 100 stitches then that would mean 200 of those tiny negative booleans. That being said I’ve seen real world examples that are pretty close to what you achieved already so it’s not that it’s implausible for it to look like it does but in the real world examples the stiching is more for show then function.
Profile
Posted: 09 December 2012 12:54 PM   [ Ignore ]   [ # 1099 ]
Active Member
Avatar
RankRank
Joined  2007-12-10
Yes, true LHD.
I was thinking that a single negative joining up each stitch would do (if it wasn’t as tricky as it would be at this point), thereby managing to jeep the amount to 100 as each one would cover two points where the stitch penetrated the leather and also make a slight depressed groove along the stitch line.
Meanwhile, this is what I’m thinking for the embossed logo, these are just a few material tests:
Image Attachments
 Signature
Profile
Posted: 09 December 2012 01:27 PM   [ Ignore ]   [ # 1100 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
chohole - 09 December 2012 10:20 AM
Well, you may be right or wrong as I. Checking the 7.1.0.107 installation (we’re at 7.1.0.109), I have a 520 MB footprint.
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 09 December 2012 01:28 PM   [ Ignore ]   [ # 1101 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
@TheSavage64 - embossed logos look cool!
 Signature
Profile
Posted: 09 December 2012 01:35 PM   [ Ignore ]   [ # 1102 ]
Active Member
Avatar
RankRank
Joined  2010-02-18
A somewhat, ‘suspended’ (non-realistic), submission.
Title: “The Observatory”
Jay
Image Attachments
Profile
Posted: 09 December 2012 01:36 PM   [ Ignore ]   [ # 1103 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
Been fooling around a bit with Wings3D and the ALST creating an anaglyph. Lit by IBL, using soft IBL shadows. Rendered in 3/4 hours.
Image Attachments
 Signature
Profile
Posted: 09 December 2012 01:38 PM   [ Ignore ]   [ # 1104 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
Jamahoney - 09 December 2012 01:35 PM
Jay
Hey, looks great!
 Signature
Profile
Posted: 09 December 2012 01:42 PM   [ Ignore ]   [ # 1105 ]
Active Member
RankRank
Joined  2004-06-12
Well no matter on the size, I got it installed so cheers Horo, Pam.
Got greeted with some weirdness though.  Stuck two elongated cubes in the scene and rendered them.  Then, I tried copying the material from one to another and it turned all the objects black and wouldn’t right itself without quitting.
Weird, never had that one before!
Profile
Posted: 09 December 2012 01:49 PM   [ Ignore ]   [ # 1106 ]
Active Member
RankRank
Joined  2004-06-12
Nice renders BTW!
Profile
Posted: 09 December 2012 01:51 PM   [ Ignore ]   [ # 1107 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
Strange things happen at odd moments. May be Bryce, may be Windoze. Rarely happened to me, but it did. Restart Bryce and everything is fine.
 Signature
Profile
Posted: 09 December 2012 02:41 PM   [ Ignore ]   [ # 1108 ]
Member
Avatar
Rank
Joined  2003-10-09
pumeco - 09 December 2012 01:42 PM
...I got it installed…
Suddenly that end-of-the-world-on-the-21st thing doesn’t look so implausible.
Profile
Posted: 09 December 2012 03:06 PM   [ Ignore ]   [ # 1109 ]
Active Member
RankRank
Joined  2004-06-12
@Peter
It wasn’t the 21st, it was the 3rd, and you missed it.
I’m famous now and have my comment on the map to show off to my Peasant Girls :mrgreen:
You can still get yours on there too, it’s still live!
@dwsel_
I completely forgot to comment on your snow test.  Very nice, and I like the one on the bottom left the most because it looks closest to the snow we get here.
Profile
Posted: 09 December 2012 03:25 PM   [ Ignore ]   [ # 1110 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
_ PJF _ - 09 December 2012 02:41 PM
Image Attachments
 Signature
Profile
74 of 100
74
