Digital Art Zone
5 of 6
5
DSON for Poser - Whats YOUR verdict ?
Posted: 27 December 2012 02:02 AM   [ Ignore ]   [ # 61 ]
Active Member
Avatar
RankRank
Joined  2006-07-28
Unfortunately, it’s touch and go whether the clothing fits non base shapes in Poser.
I’ve also found that sometimes Transfer Active Morphs makes it worse.  It runs through ALL the clothing on the figure every time you run it.  It would be nice if that could be changed to Transfer Active Morphs on only the selected clothing.  You should see what happened to a helmet with wings on a figure with big ears.  It was ... REALLY, REALLY hideous.
LycanthropeX - 27 December 2012 01:31 AM
nope, didn’t know I had to. Just tried it and it helps some, still not perfect. Still a lot of poke through
 Signature
Satira Capriccio on deviantART
Profile
Posted: 27 December 2012 02:06 AM   [ Ignore ]   [ # 62 ]
Power Member
Avatar
RankRankRank
Joined  2003-10-09
So I will save a lot of money by not buying Genesis clothes and just painting everything in post work, ok
Profile
Posted: 27 December 2012 04:55 AM   [ Ignore ]   [ # 63 ]
Active Member
Avatar
RankRank
Joined  2007-12-13
So glad you got your issues fixed. I checked out that auto adapted cache and there are loads of folders in there, however, if, as ps1borg says, you can’t load saved scenes without them then I’ll leave them where they are.
I use this for poke through:
http://www.daz3d.com/shop/poke-away
Basically, it’s a set of morphs for Genesis that shrink the X axis of any body part that is causing poke through. If you’re over zealous it can look weird when say V5 is wearing a bikini, but, even that can look good in any pose if you’re careful. The best way to use it is start low and gradually increase the value till all the poke through you want gone is gone. Look for morph dials that say XAway, those are for Poke-Away. DS made it a bit redundant with autofit, but it is still useful for Poser users.
CHEERS!
Profile
Posted: 27 December 2012 09:17 PM   [ Ignore ]   [ # 64 ]
New Member
Joined  2006-06-10
My experiments with the Genesis Bikini Top did not go well.  I learned a few things, which although disappointing, may ultimately help me zero in on a solution.
1)  I cannot export the auto-morphed top alone as a CR2 from DAZ Studio.  Exporting the OBJ results in the entire figure being welded and exported wholesale.  Exporting the CR2 gives me just an unmorphed top.  Editing the CR2 to reference the OBJ I manually exported results in a top that explodes when fitting is attempted
2)  I tried to transfer the rigging from a saved Genesis CR2 (originally imported via DSON and then re-saved) to the raw OBJ of the combined Genesis/Bikini figure, thinking I could just set Transparency to 1 for all the non-bikini material zones.  The resulting skeleton is invariably taller than the mesh, with essentially everything below the waist matching up well but losing its way above the waist.  Poser also crashes consistently when I attempt to return to the Pose room.
3)  I tried all this again after making turning off SubD for the Genesis base figure in DS before re-exporting the OBJ.  Same results as above.
4)  Ordering Auto-Fit appears to give me access to the PDF manual (and a surprisingly short one at that) and nothing else.
So, for now, Genni remains topless.  I’m a guy, so I can’t really complain at the moment grin, but I would like to properly clothe the poor girl eventually.
Profile
Posted: 27 December 2012 10:12 PM   [ Ignore ]   [ # 65 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
Gregorius - 27 December 2012 09:17 PM
You’ll probably have to fix any remaining pokethru with the morph brush. You’re not able to rig anything in Poser for Genesis. It’s possible that the bikini relies too much on smoothing and collision. Perhaps you could export the fix for the bikini as an obj, then load them into the bikini as fits using Morph Loader Pro and save the morphs. Then in Poser when you transfer morphs, you’ll have a morph fits that shape that may work better.
Profile
Posted: 28 December 2012 03:54 AM   [ Ignore ]   [ # 66 ]
Active Member
Avatar
RankRank
Joined  2007-12-13
It is possible to fit the bikini top in Poser. You load it, conform it, run Transfer Active Morphs and then do XAway_Body (Poke-Away) dialled to 0.040. The result is below.
CHEERS!
Image Attachments
Profile
Posted: 28 December 2012 06:17 PM   [ Ignore ]   [ # 67 ]
Member
Rank
Joined  0
sadly my verdict after months of trying to have it work is still negative
very negative.
These young teens.. FUN of course
but their clothes look like pastique
It shines.. it folds strange..
horrible
I see much more future for Crosstalk technique
and think DAZ should no longer go on with Genesis and M5/V5 things
The V4 and M4, especially with the Boom technologies by Iron man is giving us so much more
Stop walking this side road and return to V4/M4 .. make them more prefect instead of start all over again.
Profile
Posted: 28 December 2012 11:12 PM   [ Ignore ]   [ # 68 ]
Active Member
Avatar
RankRank
Joined  2004-12-14
efron_24 - 28 December 2012 06:17 PM
very negative.
horrible
DAZ has no intention of dumping genesis.  To do that, they would have to admit that they misjudged the market.
Ain’t gonna happen.
 Signature
“Facts do not cease to exist because they are ignored” - Aldous Huxley
Profile
Posted: 29 December 2012 02:19 AM   [ Ignore ]   [ # 69 ]
Active Member
Avatar
RankRank
Joined  2007-12-13
To my mind, the only major thing Daz did wrong was to make the original instructions for installing DSON very unclear, which left a lot of users confused as to how the product was to be installed.
If installed correctly the eventual version of DSON does work, but the confusion as to why it didn’t after following the unclear instructions is what has led to the majority of issues.
Solutions also been presented by users that were able to get it to work and, due to others not bothering to read the whole thread, they needed reiterating several times. If there is an issue, the first thing one should do is search the forums to see if it has been reported by anyone. If it has, read the thread and try solutions provided.
If you can’t find your issue listed or can’t seem to solve it by following solutions provided in threads then file a bug report. NEVER BE AFRAID TO ASK!!
Profile
Posted: 29 December 2012 11:11 AM   [ Ignore ]   [ # 70 ]
Active Member
Avatar
RankRank
Joined  2006-07-28
Well ... we could get into a long winded discussion about all the things DAZ did (or does) wrong, but that list rather depends on whether you’re a Poser, DAZ, or other user, and whether you’re into Gen4, Genesis, or non-DAZ figures.  Actually, the list of reasons why customers feel DAZ did them wrong would go on forever just by itself.
As a Poser user, I was disappointed (maybe even extremely upset) when DAZ abandoned Poser compatible figure development for a figure system that was unusable in Poser.  Now, over a year after the release of Genesis both Smith Micro and DAZ have implemented changes making it possible for Genesis to work in Poser, though it still needs a great deal of work.  Anyone who has used Genesis in DAZ Studio and in Poser knows DSON is still lacking.  But, after a year of purchasing less content from DAZ, I’m less inclined to care that DAZ went in that direction.  Now when I see a clothing product I like but is Genesis Only, I tend to shrug rather than feel cheated.
I find the Poser Morphing Tool is less effective on DSON clothing, and it is harder to see whether the pokethrough is actually fixed.  But neither Transferring Active Morphs or the Poser Morphing Tool is going to fix mesh that is crumpled ... as sometimes happens with shoes/boots.
Because of the problems with DSON, I may purchase the $1.99 Genesis PC products from time to time.  Most of that will be clothing suitable to be worn by both male and female characters.  But, I will rarely purchase Genesis clothing in the $15+ range ... though I have been known to purchase Gen 4 clothing in that range (those products were mostly made by vendors who are now exclusively Genesis).
Well ... I’m going to go watch it snow now.  And be eternally grateful it will be Wednesday before I have to go back to work.  Driving in Philly in the snow in rush hour traffic is such a ... joy.
Almost as much fun as DSON in Poser ...
Rogerbee - 29 December 2012 02:19 AM
 Signature
Profile
Posted: 29 December 2012 01:21 PM   [ Ignore ]   [ # 71 ]
Member
Rank
Joined  2004-08-13
Satira Capriccio - 29 December 2012 11:11 AM
Exactly!
It’s not that we can’t get Genesis to work in Poser. We can.
We just can’t get it to work very well.
It needs serious improvement before sinking cash into Genesis clothing becomes a reasonable proposition.
Hopefully Daz will continue with those needed improvements. But until they’re implemented, claiming that the Genesis-in-Poser issue is now resolved is just wishful thinking.
Profile
Posted: 29 December 2012 01:27 PM   [ Ignore ]   [ # 72 ]
Member
Avatar
Rank
Joined  2006-05-25
I’m having trouble getting morphs to work on Genesis with DSON in Poser Pro 2012 and no one has answered my help thread. I don’t want to double-post so I’ll just link to the topic here. http://www.daz3d.com/forums/viewthread/14035/
If anyone could help, I’d be very grateful!
 Signature
~Lizzie P.
Visit Dream 9 Studios for art, graphic novels, and more.
My RDNA Store | My Renderosity Store
Facebook | Twitter | deviantART
Profile
Posted: 29 December 2012 02:45 PM   [ Ignore ]   [ # 73 ]
New Member
Avatar
Joined  2003-10-09
Lizzie,
I had the same problem when I installed the Young Teens.  The dials were there but when I dialed them up, it only changed the scale of the character, and nothing else happened.  April had several suggestions and one of them worked for me.  The solution for me was to delete the auto_adapted folder and let DSON rebuild it.  Please see posts 40 through 46 in this thread (pages 3 and 4) where April provided several suggestions.  Not sure if you’ve seen those.  Also note that someone reported that deleting the auto_adapted folder causes saved scenes not to load, so if you try this method, you might want to copy the files/folders to another location before deleting them so you can restore them if you need to.
Profile
Posted: 30 December 2012 05:02 AM   [ Ignore ]   [ # 74 ]
Active Member
Avatar
RankRank
Joined  2007-12-13
Ok, if you want to see improvements, list them, either here or in a separate thread. Then file a feature request bug report, link to the suggestions and see if any of the suggestions can be implemented.
It has been said that if you don’t ask, you don’t get
CHEERS!
Profile
Posted: 30 December 2012 09:04 AM   [ Ignore ]   [ # 75 ]
Power Member
Avatar
RankRankRank
Joined  2003-10-09
can i get a million dollars and a monkey?
just testing the idea
Profile
5 of 6
5
