Hi Brian
I’ve not used Poke away, ...I think it’s a DS only product,.. but i could be wrong ..
you can usually adjust for poke-through with smoothing on the figure or the clothing
or handle it in the old way by making the part of the figure invisible.
You could also use Magnets to deform the mesh, as you can in DS.
Carrara can handle some types of data from DS, but things which rely on scripts don’t generally work..
As far as I know, there’s no way to turn OFF Auto-fit. either globally or selectively.
you could add a bug report of stuff like this , so that the developers can look into it.
Hi The KD
Is there a quick and easy way to tell which things installed needs to be saved into the DUF format?
The new DSON stuff is all coming out ready to go, and most of the main products like M5 V5 etc.. have been updated,. so,.. it’s time to download it all again :(
As for where to install stuff,. that’s customisable, but the default should be “My Documents\Daz3D\ My Library” :
you can also test Cararra 8.5 without DS and genesis, ..you can just install the Carrara beta into a new folder and run it as you would normally,.
To test Carrara with genesis you also need to install Daz Studio,. since the genesis base figure comes as part of the default content.
there’s also a separate Content installer,. (Daz Studio Essentials) and that gives you a bunch of content to work with.
Daz Studio creates a couple of folders when you install it, the main one is the (My Documents\Daz3D\My Library) where all of your Daz and Genesis content should be installed to, and the other folder is the Daz Studio program folder. where you should NEVER install anything into.
Any Genesis products should be installed to your “My Documents Daz3D\My Library” folder,.
“My Library” is the DS4 replacement name for the “Content” folder in DS3 .
Install Daz Studio4.5,., and the “Daz Studio Essentials”,. If you use Poser or Carrara, install the “Poser Essentials” files.
You’ll need to Open Daz Studio once, so that it can create the dynamic database which the Content Management Service uses to update the Smart content in the browser.
The CMS should normally start when you boot up, or restart your system, and it’ll then be running whether you’re working in Daz Studio or Carrara.
but you don’t need to have Daz Studio running to use genesis in carrara,.. it’s just the CMS service that’s needed.
Install the Carrara 8.5 beta. to a new folder,. and run it
that’s it.
Hope it helps
