Digital Art Zone
2 of 2
2
mcjHIDKit - live puppetry in daz studio using a microphone and a gamepad (WIN-PC)
Posted: 06 February 2013 12:20 AM   [ Ignore ]   [ # 16 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
~ Release News ~ Release News ~ Release News ~ Release News ~ Release News ~ Release News ~
https://sites.google.com/site/mcasualsdazscripts2/mcjhidkit
a first release
if you use it at the default data rate of 10 per seconds, it seems to work quite well
Profile
Posted: 06 February 2013 02:36 PM   [ Ignore ]   [ # 17 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
here’s a demo made today
https://www.facebook.com/video/embed?video_id=10151703443064746”
i’ll probably add a button to mcjClient, to make it de-select the nodes
this way if you screen-capture a session, you wont have the wireframe boxes (bounding boxes) around the selected objects
Profile
Posted: 06 February 2013 03:13 PM   [ Ignore ]   [ # 18 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
- update - update - update - update - update - update - update - update -
de-selection of target nodes while the script is running
this should be practical for live shows and screen-captures
since it removes the selection boxes around the target objects
Image Attachments
Profile
Posted: 06 February 2013 11:49 PM   [ Ignore ]   [ # 19 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
good news - i figured why the data rate was limited to 10 Hz
communication between the server and the client is done over stdin / stdout
apparently buffering and polling happens around 10 times per second ( in Daz or in Windows )
if the report rate from the server is over 10 Hz, sometimes
the client (script) will receive more than 1 status report at a time.
in the previous version of the script, those reports were thrown out for fear of being corrupt
the next version of the script will instead unpack them and feed them to the part of the script that processes them
just now i tested 30 Hz data rate
at 60 Hz i still get some “misses”, say, 1 miss per second
actually the image below isnt a valid test, by mistake i re-launched the server after changing the data rate to 30 !
but it gives you a glimpse of an upcoming script that will use the HIDServer to pilot a camera or a car
Image Attachments
Profile
Posted: 07 February 2013 09:06 PM   [ Ignore ]   [ # 20 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
- update - - update - - update - - update - - update - - update - - update - - update - - update - - update - - update -
new version handles higher data rates like 30 Hz
also fixed Load/Save of links lists issues
Image Attachments
Profile
Posted: 09 February 2013 03:37 PM   [ Ignore ]   [ # 21 ]
Member
Rank
Joined  2004-10-23
Great job will give this a try. Thnks for sharing your work.
Profile
Posted: 09 February 2013 05:47 PM   [ Ignore ]   [ # 22 ]
Active Member
Avatar
RankRank
Joined  2006-01-19
Tugpsx - 09 February 2013 03:37 PM
thanks
eventually i think i’ll make an OSC ( http://opensoundcontrol.org/ )  plugin
which will let people interface a lot of things including the kinect and even musical keyboards
Profile
Posted: 09 February 2013 06:59 PM   [ Ignore ]   [ # 23 ]
Member
Rank
Joined  2004-10-23
Actually you are almost there. Check the MS Kinect dev kit
Profile
2 of 2
2
