Ya,,thank your reply,, now I have been checking virutual store problem in web^^;
before I heared that,,
I find,,, only the powerpoze template.dsx file only set as virutal store file,,
it seems so strange,,,
then now I can copy and paste from other directory,,, to
C:\Users\mysign\AppData\Local\VirtualStore\Program Files\DAZ 3D\DAZStudio4\plugins\PowerPose
after that,, the template.dsx in program folda cahge,,
then,,, I could edit (could not copy and paste,, or delete)
because,, before I changed folda permission to change files in the powerpose directory already,,
(I read your kind PDF many times ^^; so that I could when first install and apply your dsx files,,)
then this time ,,it can not work for me,,,,, so that I will try to delete in vertula store directory,
as you said ,,
Yes Yes Yes,,,first change permission,, then,, I must need to delete
directory,,,
after that,, I edit file,, the file modified date are renew!!!
what a terrible virtual store ^^;;; I do no know why it need,,, , but terrible,,
then,, now I get buck the lovely templates @@; thank you much!!!
(about windows,, I thought install aprication to another directory seems better,,
when install under program directory,, this problem may happen,, about files which user need modify)
any way thank you much,, if I could not,, I will check more ^^;
