I’ve transferred some facial expression morphs via GenX, and I can successfully apply those to the main genesis figure in Carrara 8.5 beta.
I can capture that as an NLA and then add it to an NLA track and have it work.
I also have a genesis based character, however (was based on the genesis female as opposed to the main genesis figure), and that genesis based character doesn’t react to the facial morphs at all.
Any idea why that might be or if there’s a way around it?
(I needed to base my character off the female genesis character to have it work correctly with FaceGen)
Thanks for any help.
EDIT - I may have figured out where I messed up. My genesis character was stored in my browser. Since that time, I got GenX and transferred over varied morphs. SO loading a new Genesis may be loading that new and improved genesis base whereas my character made a couple of months ago and stored under objects in the browser must not.
Will test things out - create a new genesis char with my character’s morphs and see if it works.
