Digital Art Zone
7 of 20
7
DAZ Studio 4.5.1.6 is now available
Posted: 21 October 2012 08:30 AM   [ Ignore ]   [ # 91 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Richard Haseltine - 21 October 2012 08:02 AM
Shouldn’t - go to help>About installed plugins and make sure the serial took.
It shows up with a Green Plug as installed.
I’m working from the PDF Guide which seems to be written for one of the old versions that had a Tabs menu. So I guessed that it should show up under Window-Tabs now. Except that it doesn’t show.
It does show up as an action in the Customize dialog and there is a menu defined there for the Decimator Pane. So I’ve used that to place it in the Tabs menu by hand.
It should show up there automatically if installed and registered. Is it a minor bug?
 Signature
Freebies
Profile
Posted: 21 October 2012 08:45 AM   [ Ignore ]   [ # 92 ]
Member
Rank
Joined  2004-03-03
Baglet - 21 October 2012 08:30 AM
Not usually a bug, as such. More an unfortunate consequence of the system design.
Presuming you are a previous user, DS will have recorded the layout, menus etc as used by you. Installing some plugins etc adds actions to the action list, and default menus etc, but DS still looks at its custom menu list from your prior use, not the (new) defaults. So after things like upgrades, and adding certain products/functions, you don’t see new and/or changed menu entries. The plus side is that you don’t lose customisations you may have made to menus, toolbars etc. The minus side is you don’t get updated menus with new, rennamed or moved menu entries and new toolbar buttons.
There was quite an argument about this back during the DS1 and 2 versions, with the consequence being that DAZ took it that they could keep the larger number of voluble users happy by preserving the prior user customizations rather than the priority of getting the new/chenged toolbars and menus to show at the price of previous customizations.
Throughout the DS 4 and 4.5 versions I’ve been noticing mentions of changes to menus and toolbars in the changelogs, which weren’t, of course, showing up for me after the version changes due to this issue. So after each version change, I’ve been going to Window->Workspace>Customize and using the Import button down the bottom to import the new default menus and toolbars so that the latest chages and new tools and menu entries show up ... and then redone my customisations after. It’s a bit of a pain, but that’s hoiw its been for a long time.
Profile
Posted: 21 October 2012 09:06 AM   [ Ignore ]   [ # 93 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Thanks DavidGB, it makes sense now.
 Signature
Freebies
Profile
Posted: 21 October 2012 01:23 PM   [ Ignore ]   [ # 94 ]
Addict
Avatar
RankRankRankRank
Joined  2007-11-06
...egads, if you have to rename your texture folders that’s not good.
I think I’ll wait until this one gets sorted out.
 Signature
...forsaken daughter is watching over you…
Profile
Posted: 21 October 2012 02:41 PM   [ Ignore ]   [ # 95 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Kyoto Kid - 21 October 2012 01:23 PM
What are you referring to?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 21 October 2012 02:49 PM   [ Ignore ]   [ # 96 ]
Addict
Avatar
RankRankRankRank
Joined  2007-11-06
...this.
fixmypcmike - 18 October 2012 09:22 PM
barbult - 18 October 2012 09:19 PM
I updated to DS 4.5.1.6 from a previously installed 4.5 version. I installed 14812_GenesisStarterEssentials_1.6_trx.exe. Now whenever I open a previously saved DUF scene that used content from the Genesis Starter Essentials, it cannot find the texture files. The textures are there in the same folder, but they have new names! I had the problem with Aldora hair, SallyMae hair, Journey Scout and Kids 4 Basic Wear.
I submitted a bug report. https://bugs.daz3d.com/view.php?id=48199
Can anyone confirm this problem?
It looks like they’ve changed the folder names rather than the file names—are you seeing the same folder but different file names?
ETA:  I see, in some cases they renamed the files as well.
 Signature
Profile
Posted: 21 October 2012 03:22 PM   [ Ignore ]   [ # 97 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Ah, that refers to some of the files in the default content - not to a general change that affects everything, and certainly not a change to the base folder name.
 Signature
Profile
Posted: 21 October 2012 03:31 PM   [ Ignore ]   [ # 98 ]
Addict
Avatar
RankRankRankRank
Joined  2007-11-06
...so is there a “no content” version like in the past?
 Signature
Profile
Posted: 21 October 2012 03:55 PM   [ Ignore ]   [ # 99 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Kyoto Kid - 21 October 2012 03:31 PM
Do you use any of the supplied content - or more to the point the supplied textures? If not this won’t affect you. But only a to a point - the bulk of the content is in a separate installer, but it has been updated (hence the changed paths) so if you don’t use the latest version you may miss out on some fixes (if nothing else, I think you need the 1.6 version for the DSON Importer for Poser if you use that).
 Signature
Profile
Posted: 21 October 2012 04:01 PM   [ Ignore ]   [ # 100 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Richard Haseltine - 21 October 2012 03:55 PM
Also, KK, since you are new to DS4 it’s unlikely that you’ve used much, if any, of the affected content.  Therefore, you should be good to go with no problems at all.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 21 October 2012 04:20 PM   [ Ignore ]   [ # 101 ]
Addict
Avatar
RankRankRankRank
Joined  2007-11-06
...so everything from the Genesis Essentials DL should be fine then?
...still using .114 as it seems to be working OK on my ancient system (unless I do something silly like load up the entire Big City set by Stonemason as I did last night).
Render time is a vast improvement over 3Advanced.
 Signature
Profile
Posted: 21 October 2012 04:49 PM   [ Ignore ]   [ # 102 ]
Active Member
Avatar
RankRank
Joined  2012-02-04
The problem with the Genesis Essentials textures comes when you reload a scene that was saved with a previous version. If you create a new scene, there is no problem finding the textures for the new content.
For example, I had saved a scene a month ago that used the Aldora hair. When I reloaded that scene with DS 4.5.1.6 (which uses new Genesis Essentials 1.6), DS couldn’t find the texture for Aldora hair. It gave me about a dozen error pop up messages. The workaround is to tell DS to stop looking for those textures and then go to the Smart Content (or Content Library) materials and reselect the texture after the scene loads.
Profile
Posted: 21 October 2012 04:56 PM   [ Ignore ]   [ # 103 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
It looks to me like what happened was that the original default content in DS 4.0 used reduced res versions of the textures for the content that was converted to Genesis (hair and clothing), but now it uses the full res versions.  The reduced res versions were uninstalled when the new ones were installed, but of course if you used the old versions the textures are no longer there.
An annoyance, but it’s just a matter of going to the content and reapplying the mats.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 21 October 2012 04:59 PM   [ Ignore ]   [ # 104 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Yup.  Just tested… Works fine for a new scene, save, load.  4.5.1.6 + GE1.6
Kendall
 Signature
Profile
Posted: 22 October 2012 07:26 AM   [ Ignore ]   [ # 105 ]
Member
Avatar
Rank
Joined  2004-06-28
I gave up with 4.5 on my Win7 64 bit machine.  I upgraded and lost my Daz3 content folder etc…Np with Win XP 32 bit…But this is the 2nd time I uninstalled and tried to reinstall…. Not worth the frustration.  I had to reinstall all my Daz3 purchases. Good thing I saved all to external HD….
Profile
7 of 20
7
