Digital Art Zone
2 of 20
2
DAZ Studio 4.5.1.6 is now available
Posted: 11 October 2012 06:57 PM   [ Ignore ]   [ # 16 ]
Power Member
RankRankRank
Joined  2004-07-01
works great so far grin
Profile
Posted: 11 October 2012 07:11 PM   [ Ignore ]   [ # 17 ]
Power Member
Avatar
RankRankRank
Joined  2003-10-09
What happens if you install into a fresh directory that is not under Program Files?
 Signature
My DAZ Store
My Free Stuff
My Deviant Art
Profile
Posted: 11 October 2012 08:58 PM   [ Ignore ]   [ # 18 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
DS 4.5.1.6 runs in Wine with no problems.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 11 October 2012 09:04 PM   [ Ignore ]   [ # 19 ]
Member
Avatar
Rank
Joined  2011-05-19
Daz3D -  THANK YOU smile
For promises kept with Genesis Meets Poser and the New DS 4.5.1!  Its AWESOME smile
 Signature
Trigger your imagination, visit my projects developed with DAZ3D Content
FarmPeeps.com, Free game dev & Farm theme 3D Content site: http://FarmPeeps.com
GoldPeeps Hobby Gold Prospecting & Mining site; http://GoldPeeps.com
CastleVilles.com Medieval Theme Game and 3D Content site; http://CastleVilles.com
TrailPeeps.com, Pioneers, Explorers and Adventure theme site: http://TrailPeeps.com
ArcadePeeps.com, Pinball and Video Beach Arcade Game theme site. http://ArcadePeeps.com
Profile
Posted: 11 October 2012 09:30 PM   [ Ignore ]   [ # 20 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
about compatibility of AMD graphic driver,
I can not use Open GL render in ds 4.5 beta and 4.5.1 product .
show alert window about access violation, then ds must shut down
when I use some shader for material though there is daz default light only..
DAZStudio.exe caused ACCESS_VIOLATION in module “C:\Windows\system32\atio6axx.dll” at 0033:00000000691B1A4C, DrvPresentBuffers()+7073468 byte(s)
I am radeon HD 6870 user,
then hope answer and report from same radeon user.or getting same problem.
which CCT version is best?
I send report mantis already..
Profile
Posted: 11 October 2012 09:42 PM   [ Ignore ]   [ # 21 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
kitakoredaz - 11 October 2012 09:30 PM
ATI’s understanding of OpenGL standards is shaky at best.  The first thing you should do is update the drivers to the very latest available.
Minecraft is having the exact same error.  As is Cinema4D.  Do a google search on “atio6axx.dll DrvPresentBuffers” and you’ll see that the problem is all over.
Kendall
 Signature
Profile
Posted: 11 October 2012 09:43 PM   [ Ignore ]   [ # 22 ]
Member
Rank
Joined  2011-04-11
DavidGB - 11 October 2012 05:31 PM
Windows 7. The first crashed uninstall did manage somehow to wipe out the .dat file for the uninstaller, so on any subsequent attempts to install the uninstall failed again, this time erroring on the lack of the .dat file. And every time the uninstall fails for any reason, the installer itself crashes the moment control is returned to it by my acknowledging the failure of the uninstall.
<Sigh>
This whole DAZ install/uninstall method is so unrobust I could cry. It is just so pathetic.
There should be an option to install without uninstalling, to deal with cases when the uninstall fails.
And the installer should not crash immediately following the failure of an uninstall.
This really isn’t rocket science. Just basic, for heaven’s sake. Build in some flipping robustness. Don’t just assume every step will succeed so when one step fails the whole thing goes tits up.
This happened, and I reported it, virtually every DS 4 beta before the first DS4 public release. And since the public release and my demotion to the ranks of the plebs, it’s kept on happening every public version and public beta of DS 4 and DS4.5 too.
Hello? Anyone listening? Well, I was never listened to as a tester, all my open bug reports were closed awhile ago even though I kept adding notes the bugs were still there (and no, I am NOT going to type them all out again in a new bug tracker - typing hurts, and you could have damn well migrated the open bugs, or checked them yourselves instead of just closing them), so I don’t suppose I’ll be listened to as a mere customer.
Yes, I’ve got it to install by going into my Program Files and manually deleting the broken uninstaller .exe. A user SHOULD NOT NEED TO DO THAT.
Then the installer ran to completion - but threw up an error message about a problem installing the CMS.
AGAIN.
JUST LIKE LAST BETA INSTALL AND THE ONE BEFORE.
Good thing i don’t use the CMS - though ti would be nice to have it just in case I ever want it.
It would be REALLY NICE if DAZ actually spent some time fixing things, instead of just releasing new things (some broken) while leaving all the broken stuff unfixed. It would be ESPECIALLY NICE if, for the first time ever in all the beta and public versions of DS 4 and DS 4.5 JUST ONE would actually install without crashes of installers and uninstallers and error messages about parts of the install process and me needing to go rooting through the Program Files folders to find and delete things just to get the bloody thing to install.
Crazed.  I got the same problem.  It appears to be an issue with the Remove-DAZStudio4_Win64.exe that was installed with the 4.5.0 release.  Windows reports “...is not a valid Win32 application” when trying to run it directly.
After attempting to run the 4.5.1.6 installer, DAZ studio no longer even appears in the Control Panel list of installed programs (registry now screwed up?).  Not possible to uninstall using any standard method that I can see.  This is so pathetic and also so typical of DAZ.  Before trying anything else, would be useful to find out what others have successfully done to get this to work.
Profile
Posted: 11 October 2012 09:50 PM   [ Ignore ]   [ # 23 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
artistb3 - 11 October 2012 09:43 PM
<Sigh>
AGAIN.
I’ve installed 4.5.1.6 on numerous machines: XP/32, XP/64, Vista/32, Vista/64, Win7/32,Win7/64,MacOS and Linux/Wine.  No problems.  Start the investigation on a Windows problem on your machine.  It is likely that you have something interfering with the process.
Kendall
 Signature
Profile
Posted: 11 October 2012 09:57 PM   [ Ignore ]   [ # 24 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
Kendallsea, I have already updated Catalyst very latest t driver.
Catalyst 12.8
of course I know, if it can work newest driveri is best .
Profile
Posted: 11 October 2012 10:05 PM   [ Ignore ]   [ # 25 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
kitakoredaz - 11 October 2012 09:57 PM
Catalyst 12.8
Just verifying that you are up to date.  The problem is in ATI’s code.  Nothing DAZ or anyone else can do right now.  Also, some in other groups have stated that the problem can be traced to faulty hardware.  I don’t personally agree with that reasoning in this case.  I think the problem is a problem in the ATI drivers.
Everything from JavaGL to Cinema4D is choking on the ATI dll.  That is not a good thing.
Kendall
 Signature
Profile
Posted: 11 October 2012 10:12 PM   [ Ignore ]   [ # 26 ]
Member
Rank
Joined  2011-04-11
<Sigh>
AGAIN.
Some additional information.  Just information and I don’t recommend anyone else do this as I may regret my haste.  In any case, I renamed the Remove-DAZStudio4_Win64.exe in Program Files\DAZ 3D\DAZStudio4\Uninstallers to Remove-DAZStudio4_Win64.exe.bak and re-ran the 4.5.1.6 installer.  It installed.  However, since an uninstaller did not run for the previous version, I do not know what impact this may have.  I will probably run the uninstall and then re-install before proceeding.
Previous post indicates that this problem was reported during beta testing.  If it is the same problem, there is simply no valid excuse for not fixing it prior to the general release of 4.5.  Period.
Profile
Posted: 11 October 2012 10:27 PM   [ Ignore ]   [ # 27 ]
Member
Avatar
Rank
Joined  2006-09-04
I’m experiencing the same problem again with this update here is what I posted before:
stumpc - 30 September 2012 01:33 PM
stumpc - 20 September 2012 08:57 AM
After loadiing up DS 4.5 and rendering an old scene I think I found a bug in the Open GL GLSL render setting( stage 3 on the render slider). The program crashes and needs to be restarted. I’m running :
Windows Vistaâ„¢ Home Premium
Version 6.0.6002 Service Pack 2
AMD Athlon(tm) 64 X2 Dual Core Processor 5200+, 2600 Mhz
Physical Memory (RAM) 8.00 GB
NVIDIA GeForce GT 430
Display Driver 3.06.23.
And I get this error and crash:
WARNING: interface\dialogs\dzbasicdialog.cpp(164): No parent specified for DzBasicDialog!
Rendering in OpenGL…
Compile failed on OpenGL Default Material Shaders, rendering without GLSL.
I tried it with DS 4.0.3.47 and did not have any problems. As far as I can tell I’m up to date on display drivers so it may be a bug. I haven’t read through all of this thread so bear with me but I’m wondering if there are others with the same problem or if they are working on it.
Thank’s in advance my friends.
Addendum:
I also get this in the crash Message:
DAZStudio.exe caused ACCESS_VIOLATION in module “C:\Windows\system32\nvoglv32.dll” at 0023:63B27DF4
The nvogl32.dll is an Nvida module so something needs to be addressed there, I also loaded and tried Firery Scene 2 and got the same crash. I reset the 3D setting for DS 4.5 in the Nvidia control panel and it still crashes. After reading threads I saw where some shaders may be a problem which is why I loaded the new ready to render scene and am still having problems.
Has Anybody else had this problem?
I’ll Ask this again, has any body else had this problem or can try this for me .
Once again thank’s in advance.
It seems to be still conflicting with the NVidia Open GL driver, If you can please report this to the bug tracker.
Profile
Posted: 11 October 2012 10:40 PM   [ Ignore ]   [ # 28 ]
Member
Rank
Joined  2011-04-11
Kendall Sears - 11 October 2012 09:50 PM
<Sigh>
AGAIN.
Kendall
I have installed hundreds of applications on various machines over the years.  Very rarely had any issue with an installer.  However, in every case, it came down to an issue with the installer and not with the system.
I have installed all of the DS4 updates over the past year without issue until now.  At this point, I am quite confident This is a DAZ problem and not a Windows problem.
In over 30 years of developing software, one of the things that I know from experience is that just because it works on system A and not on system B, does not automatically mean that root cause lies with system B.  It means that the software process better be robust enough to determine exactly what the root cause is when reported.  Too often, wishful thinking combined with “...well, it works on my machine so the problem must be with yours…” will result in defects getting overlooked.
Profile
Posted: 11 October 2012 10:41 PM   [ Ignore ]   [ # 29 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Kendall Sears - 11 October 2012 08:58 PM
Kendall
Is that with or without the redraw ‘fix’?
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 11 October 2012 10:47 PM   [ Ignore ]   [ # 30 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
kendalsea, ,blank stare
I have no idea to talk about compatibility with so many online games and 3D tools when I talk about one online game and that forum.
there seems no difference when talk about daz studio and video card
I just want to know I can use newest daz studio by my PC ATI graphic card with driver.
if I can not, want to know what driver is best. or I must need change the graphic card for new daz studio.
if I want
actually I could Open GL render (but seldom I use it, so it is not so important for me)
,with my ATI graphic card in 4.0.3. I had not changed my graphic card, only updated daz studio and driver.
and daz can announce the compatibility with graphic card, if daz know whati is the true user service.
is there any discribe about compatibility with ATI graphic card ?
Now I become angry about this problem, so I decide my all anger throw to AMD support vampire
Profile
2 of 20
2
