Digital Art Zone
clipping not working
Posted: 11 October 2012 04:51 AM   [ Ignore ]
Member
Rank
Joined  2005-09-04
Help please, In the terain editor when i try to clip it turns white not red or yellow and then when i save nothing changes what could be wrong?
Profile
Posted: 11 October 2012 07:26 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2007-12-10
OK, sorry if this is stating the obvious to you but first we need to know if you’re doing it correctly.
A; Click this icon to get the clipping tools down the right side
B; Slide this edge of the bracket down to clip high range
C; Slide this edge of the bracket up to clip the low range
Is this what you are doing?
Can you post some screen grabs of what you’re seeing?
Thanks
Image Attachments
 Signature
I’ve got nothing of my own to promote, no models, no tutorials, no website, nothin’, nada, nill, nowt.
Profile
Posted: 12 October 2012 12:21 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2011-09-25
@Dave:  That looks like a egg with a side of mashed potatoes. LOL
 Signature
If you constantly look backward, it’s guaranteed you’ll run into something on your forward journey.
Profile
Posted: 12 October 2012 02:52 AM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2005-09-04
Savage I can not post a screen shot but I am doing as you direct the problem is the slider goes white from the bottom and black from the top. the slider is moving   in its entirely as pulled down it doesn’t reduce in size but just repeats black to white.
Profile
Posted: 12 October 2012 08:44 AM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Yes, move the ends of the curly bracket, not the grey - scale?  Although the mouse pointer does not modify itself to show you this is possible, just have faith and put it over the end of the bracket and drag up and down.
Image 1 shows an enlarged example of where precisely you should put your pointer before holding down the left mouse button to drag the end of the curly bracket.  Helpful?
Edit.  Tip - if your cursor transforms into a double headed arrow pointing up and down.  Then you have got hold of the wrong thing.
Image Attachments
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 13 October 2012 06:48 AM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2005-09-04
thanks david I was doing it wrong while using your fine learning CD.
Profile
