Digital Art Zone
5 of 72
5
Genesis Meets Poser - Introducing DSON Importer for Poser
Posted: 11 October 2012 03:20 PM   [ Ignore ]   [ # 61 ]
New Member
Joined  2008-07-16
I’ve an issue right at the start of PoserPro 2012.
I download and installed the right plug-in file for the 64bit in my c:\PoserPro directory.
I’ve installed the 2 Essentials in the secondary SSD drive d:\runtime\etc etc
When I fire up poser it opens a small scrip windows called “MainWacros and inside there is writen the following:
An errror occurred importing addon dson :
if I try to load Genesis from my runtime library, it gives me this error
Traceback (most recent call last):
  File “D:\Runtime\libraries\Character\DAZ People\Genesis.py”, line 1, in <module>
  import dson.dzdsonimporter
  File “C:\PoserPro\Runtime\Python\addons\dson\__init__.py”, line 3, in <module>
UnicodeDecodeError: ‘utf8’ codec can’t decode byte 0xe8 in position 37: invalid continuation byte
I made sure to follow the instruction from the tutorial and all seems in place, expect for this errors, any leads?
Profile
Posted: 11 October 2012 03:21 PM   [ Ignore ]   [ # 62 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
FSMCDesigns - 11 October 2012 03:16 PM
Male-M3dia - 11 October 2012 03:10 PM
Keep in mind this is an importer… all of your content development still needs to be done in DS until Poser natively supports the format.
Gotcha, so if I save a character that uses GenX morphs, do you know if it import fully?
GenX 4.5 update saves the the morphs in the 4.5 format so I think they should work.
Profile
Posted: 11 October 2012 03:21 PM   [ Ignore ]   [ # 63 ]
Moderator
Avatar
RankRank
Joined  2007-10-17
FSMCDesigns - 11 October 2012 02:58 PM
Wow, if this works as advertised, this will be huge!! I use both poser and DS and have enjoyed genesis in DS4 (with reality and luxrender) for quite some time. I rarely open poser 2012 lately as I love working with genesis. Now all I need if the new reality to poser plugin when released.
Any idea if GenX will updated to work with the poser version?
If this works as advertised, the negative poser users that bashed DAZ in the past will have nothing to complain about, oh wait, they will find something, my bad.
SInce Gen-X adds morphs to Genesis, the generated Morphs already work using the DSON importer.
Profile
Posted: 11 October 2012 03:22 PM   [ Ignore ]   [ # 64 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-29
timoteo - 11 October 2012 03:16 PM
Hi.  Very excited about this, but it doesn’t seem to work (at least for me.)  I’m running Poser Pro 2012 on Win7 64-bit.  I installed the DSON importer, then the Genesis Files, then the Genesis for Poser files.
When I launch Poser I am getting the following error in a “mainWacros” window:
ERROR: DLL load failed: The specified module could not be found.
ERROR: DLL load failed: The specified module could not be found.<<<<
Also, when trying to use an item under the DSON Scripts menu, I get the following ...
  File “C:\Graphics\Poser Pro 2012\Runtime\Python\poserScripts\ScriptsMenu\DSON Support\Importer Preferences….py”, line 2, in <module>
  import dson;
  File “C:\Graphics\Poser Pro 2012\Runtime\Python\addons\dson\__init__.py”, line 3, in <module>
ImportError: DLL load failed: The specified module could not be found.
It appears the module is not being found.  Is there a specific directory that the DSON Importer is supposed to be installed to?
Thanks,
Tim
You need SR3 of Poser 2012 to get this to work.
 Signature
Community Volunteer
Proud member of the Bald Wizards Club
Free RPG adventures for DnD, O:FR and more: http://4eyes.code66.se
I always look on the bright side of life, ‘cause I never expected the Spanish inquisition!
Profile
Posted: 11 October 2012 03:23 PM   [ Ignore ]   [ # 65 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
DAZ_KatBriggs - 11 October 2012 03:19 PM
  import dson;
Thanks,
Tim
Make sure you downloaded the correct 32 or 64bit version.  If you are in Poser 9, install to that directory.  The DSON Importer Documentation covers exactly what should go where.  smile
You also need SR3 for your Poser version.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 11 October 2012 03:23 PM   [ Ignore ]   [ # 66 ]
Administrator
Rank
Joined  2007-05-14
Totte - 11 October 2012 03:22 PM
  import dson;
Thanks,
Tim
Yes.  Thank you for that too.  We do have that in the doc, but I always forget to mention that one.  smile  Sorry!!
Profile
Posted: 11 October 2012 03:23 PM   [ Ignore ]   [ # 67 ]
Power Member
Avatar
RankRankRank
Joined  2003-10-09
Nightsong - 11 October 2012 03:12 PM
LizzieP_D9S - 11 October 2012 03:02 PM
Thank you for this, especially I thank you for making the DSON free. I’m going to give it a go just as soon as everything downloads. If I like what I see (i.e. how well Genesis looks and works in Poser), I will rejoin the Platinum Club and grab some of those outfits that I liked but was unable to make use of before. smile
Question: I did buy a few Genesis things just in case this day came like Anubis and a couple RawArt sets. Those are not in the DSON category yet but you mentioned earlier in the thread that “an action to convert files for use in the DSON Importer for Poser has been added to DAZ Studio version 4.5.1.6” So can I just do that instead of waiting for new downloads for those products?
I second everything LizzieP said, including the questions. :D
I will be working on updating my files
Unfortunately I dont have a new enough version of poser to see how this all works yet.
But I should be able to find a way to do conversions regardless.
It may take a while…so be patient with me…..I have ALOT of genesis stuff
 Signature
The Mighty Morphing PA Ranger
http://www.daz3d.com/shop/rawart/
Profile
Posted: 11 October 2012 03:24 PM   [ Ignore ]   [ # 68 ]
Active Member
Avatar
RankRank
Joined  2005-11-06
Richard Haseltine - 11 October 2012 03:17 PM
GenX morphs should load fine - they just get added to the Genesis Data folder like any other morph.
Thanks Richard!
I am assuming that poser needs to have SR3 installed before using this, correct?
EDIT you guys are fast today,, thanks for all the info!!
 Signature
Regards, Michael
“Documentation? Who needs documentation, just open it and learn!”
My DeviantArt Gallery
Profile
Posted: 11 October 2012 03:25 PM   [ Ignore ]   [ # 69 ]
Member
Rank
Joined  2003-10-09
Follow-up to my post about it not working (same error as ExGemini) ... Do you need to have DazStudio installed perhaps??
Profile
Posted: 11 October 2012 03:25 PM   [ Ignore ]   [ # 70 ]
Moderator
Avatar
RankRank
Joined  2007-10-17
Male-M3dia - 11 October 2012 03:21 PM
They do, that was part of my testing before release. smile
Profile
Posted: 11 October 2012 03:26 PM   [ Ignore ]   [ # 71 ]
New Member
Avatar
Joined  2011-09-02
Trying it out right now. I knew this day would come eventually =P
 Signature
Are you sure you aren’t asleep?
Profile
Posted: 11 October 2012 03:29 PM   [ Ignore ]   [ # 72 ]
Member
Rank
Joined  2003-10-09
DAZ_KatBriggs - 11 October 2012 03:23 PM
Yes, I already have SR3 (which broke the wind generator, btw, in case any of you didn’t know.  They are supposed to working on a hotfix.), and I installed (only downloaded) the 64-bit version.  I installed it into my default Poser 2012 path.  Anything else I could be missing here?  Again, does DazStudio need to be installed by any chance?
Thanks,
Tim
Profile
Posted: 11 October 2012 03:30 PM   [ Ignore ]   [ # 73 ]
Moderator
Avatar
RankRank
Joined  2007-10-17
RawArt - 11 October 2012 03:23 PM
The conversion is done in DS, you can’t test it without 9 SR3 or 2012 SR3, but you can do the conversion. smile
Profile
Posted: 11 October 2012 03:33 PM   [ Ignore ]   [ # 74 ]
Member
Avatar
Rank
Joined  2008-12-31
it gives me an error while running the script…its says
  File “C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\poserScripts\ScriptsMenu\DSON Support\Importer Preferences….py”, line 2, in <module>
  import dson;
  File “C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\dson\__init__.py”, line 3, in <module>
ImportError: DLL load failed: %1 is not a valid Win32 application.
but im on a 64bit machine with latest sr3 poser pro 2012 and i installed the 64 bit version!!!
what is going on?
 Signature
isikol.deviantart.com
my full gallery
Profile
Posted: 11 October 2012 03:34 PM   [ Ignore ]   [ # 75 ]
Power Member
Avatar
RankRankRank
Joined  2003-10-09
DAZ_Spooky - 11 October 2012 03:30 PM
Doing a conversion without testing it is like making ice on the sun…it might technically work, but you can never tell.
(so all I can say is…everybody who wants conversions…vote for my image in rosities halloween contests…..I cant tell you which it is, but vote anyway LOL)
Rawn
 Signature
Profile
5 of 72
5
