Digital Art Zone
18 of 72
18
Genesis Meets Poser - Introducing DSON Importer for Poser
Posted: 11 October 2012 08:55 PM   [ Ignore ]   [ # 256 ]
New Member
Avatar
Joined  2005-03-12
Bigest problem I see is that V5 is still genesis and an import, what like made in china?
it looks like another boof….
say how about a v6 made for poser?.............
actually the whole genesis buisness has saved me a lot of money wink
 Signature
If it has Testicles or wheels your going to have problems with it!
Profile
Posted: 11 October 2012 08:55 PM   [ Ignore ]   [ # 257 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Nath - 11 October 2012 08:50 PM
In the first post it says “Yes, an action to convert files for use in the DSON Importer for Poser has been added to DAZ Studio version 4.5.1.6 “, which sounds great, but when I try to update Studio, I get version 4.5.0.114… is 4.5.1.6 not out yet, or ....?
See if there are more files on the next page, or just “buy” it again here:  http://www.daz3d.com/shop/daz-studio-4-pro
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 11 October 2012 08:56 PM   [ Ignore ]   [ # 258 ]
Member
Rank
Joined  2004-12-26
Salem2007 - 11 October 2012 08:37 PM
ok—I’ve done a fresh install of Poser 9, ran the SR3 update, installed both genesis essential files, and the 32bit DSON importer.
I an running windows 7, 64 bit…
I get the dll failed to load (similar to what others are seeing) on the start up of Poser:
An errror occurred importing addon dson :
ERROR: DLL load failed: The specified module could not be found.
and these types of messages when I try to run the Scripts:
Traceback (most recent call last):
  File “H:\Poser 9\Runtime\Python\poserScripts\ScriptsMenu\DSON Support\Importer Preferences….py”, line 2, in <module>
  import dson;
  File “H:\Poser 9\Runtime\Python\addons\dson\__init__.py”, line 3, in <module>
  import dson.dzdsonimporter
ImportError: DLL load failed: The specified module could not be found.
I had the same problem with the Aniblock Importer for Poser, but was not able to resolve it.
My Poser 9 is not installed in my Program Files…I installed to a seperate location, but installed everything in the same folder (ie H:/Poser 9)
Is everyone having this problem running Windows 7, 64bit?
Can you do the following.
Launch the python shell (Scripts > Python Shell)
Then type: “sys.path” and hit enter
It will print out a list of paths.  Is the “dzdsonimporter.pyd” file located in one of the printed paths?
Profile
Posted: 11 October 2012 09:04 PM   [ Ignore ]   [ # 259 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
Sunfire - 11 October 2012 08:51 PM
midnight_stories - 11 October 2012 08:26 PM
Sunfire - 11 October 2012 08:19 PM
I need my werewolf… that would be Lycan…
Yes the Lycan is working and the JCMs working on that to. Next I need to start working on the Mat presets export and get that working in Poser to.
Oh *BIG HUG* I really like Lycan, but I like my ability to light scenes better in Poser. Which means I’ll be able to light him even better once I get him in Poser.
OK we have lift off with the scripts but they only pull over the diffuse color nothing else so that means the rest of the poser stuff like Disp Bump and Spec are going to have be done manually.
Image Attachments
 Signature
The Mind on the other side!
http://www.daz3d.com/shop/midnight_stories/
Profile
Posted: 11 October 2012 09:05 PM   [ Ignore ]   [ # 260 ]
Member
Rank
Joined  2008-04-10
oops, I even quoted you saying that.
Profile
Posted: 11 October 2012 09:08 PM   [ Ignore ]   [ # 261 ]
Member
Rank
Joined  2003-10-09
Go Figure - 11 October 2012 04:52 PM
Very cool stuff DAZ
Gregorius - 11 October 2012 04:39 PM
I keep getting this “mainWacros” window when I open PP12 SR3:
ERROR: DLL load failed: %1 is not a valid Win32 application.
Plus, I’ve installed the Starter content, but there’s nothing new in my library yet.
Any ideas?  I’m looking forward to toying around with Genesis in Poser!
For those that are getting these dll load failed errors, but are sure they installed right, I think you may want to install one or both of the following and report if it fixes it for you for the benefit of all:
- http://www.microsoft.com/en-us/download/details.aspx?id=8328
- http://www.microsoft.com/en-us/download/details.aspx?id=13523
Am testing this… seems to load without error after updating. Thank you for the tip. Haven’t yet tried the dson script, bu no error at load on a Win 7 64 bit machine after doing this… Thanks again smile Crosses fingers that the script works.
Profile
Posted: 11 October 2012 09:11 PM   [ Ignore ]   [ # 262 ]
Member
Avatar
Rank
Joined  2007-07-28
ketthrove - 11 October 2012 08:56 PM
  import dson;
“dzdsonimporter.pyd” is not listed in the list, but I can confirm I have at this location:
H:\Poser 9\Runtime\Python\addons\dson\dzdsonimporter.pyd
There is one path that reads “H:\Poser 9\Runtime\Python\addons\” but no path that ends directly at “H:\Poser 9\Runtime\Python\addons\dson\”
Profile
Posted: 11 October 2012 09:12 PM   [ Ignore ]   [ # 263 ]
Member
Avatar
Rank
Joined  2003-10-09
*sigh*
I’m in the group that has an invisible Genesis.
I’m on Windows 7 64 bit.  Everything is outside of Program Files and any protected system folders.  In fact, Poser Pro 2012 and all my Runtimes are on a completely different partition.
I downloaded and installed the 64-bit DSON Importer for Poser Win 64.
I installed the Genesis Starter Essentials Poser in a new Runtime, which I added to Poser Pro 2012 (D:\Content\Genesis)
I installed the Genesis Starter Essentials to D\Content\Genesis and de-selected install DAZ Studio files.
But I am noticing that now I have folders all over the place under D:\Content\Genesis.
Am I just not doing something right?
Profile
Posted: 11 October 2012 09:13 PM   [ Ignore ]   [ # 264 ]
Member
Avatar
Rank
Joined  2007-07-28
Go Figure - 11 October 2012 09:05 PM
no problem smile
I only mentioned the aniblock importer becasue I think this is a windows problem, not Poser/Daz….
Profile
Posted: 11 October 2012 09:14 PM   [ Ignore ]   [ # 265 ]
New Member
Joined  2006-06-10
Nester751 - 11 October 2012 09:08 PM
Very cool stuff DAZ
Lucky you.  Out of desperation I tried both of them.  Neither solved the problem for me, and I have the same system you have (Windows 7, 64-bit).
Should I try deleting older versions of the Visual C++ Redistributable perhaps?
Profile
Posted: 11 October 2012 09:15 PM   [ Ignore ]   [ # 266 ]
Member
Avatar
Rank
Joined  2007-11-26
  import dson;
Ok. I was having the same problem. I have Windows 7, 64 bit. I used the 32 bit for Poser 9.  I have it on an external hard drive. I have the Poser 9 folder. Then there is the Poser 9 Content folder. I put the DSON Importer for Poser in the Poser 9 folder. The others I put in the Poser 9 Content folder. Now it works.
Image Attachments
 Signature
Profile
Posted: 11 October 2012 09:16 PM   [ Ignore ]   [ # 267 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
No just make a new runtime in Poser Pro 2012 and direct it the the runtime in the Daz content folder make sure you installed the 14812_GenesisStarterEssentialsPoserCF_1.6_dpc there to
 Signature
Profile
Posted: 11 October 2012 09:16 PM   [ Ignore ]   [ # 268 ]
Active Member
Avatar
RankRank
Joined  0
Somebody might want to fix the M5 Pro Bundle. I’ve reset my downloads and found there are now two Mac copies of the Benjamin for M5 Poser Companion file but no PC version of same. Could be problematic, that.
Profile
Posted: 11 October 2012 09:17 PM   [ Ignore ]   [ # 269 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
Netherworks - 11 October 2012 09:12 PM
*sigh*
 Signature
Profile
Posted: 11 October 2012 09:17 PM   [ Ignore ]   [ # 270 ]
Member
Avatar
Rank
Joined  2012-07-29
namrettek - 11 October 2012 02:43 PM
I just got this.  IN my downloads I have a WHOLE bunch of items.  They seem to be duplicates…
I’m not sure if there is any difference.  They seem to have the same names…
great more unnecessary files in my downloadable products wish there was a way to filter them to only the ones I need
Profile
18 of 72
18
