OH…so only DSON Genesis clothing will fit the Poser Genesis?
I tried loading the V4 shape and then adding some V4 clothing. That was a catastrophe. V4 clothing doesn’t work on the V4 Genesis body shape?? I had hoped that DSON would have transferred rigging to the clothing (since basically that is what happens in the Poser setup room these does; is that what I have to do to get it to fit??)
If only DSON Genesis clothing works on this, it’s usefulness is low for me, since there are only a handful of expensive (except the PC items) clothing in the store. :-(
Question: what’s the “Core” vs the “Poser Companion”? I didn’t download the former, thinking it to be for computers that used DSON in a more fundamental way. Now that I read more about it, though, it seems DSON doesn’t work that way. That’s the only other mistake I can think of that I may have made. I’m downloading it now (or trying to, since it seems to be unusually slow).
Core has the textures and geometries, the Poser companion just has the Poser library files to load those. You do need both.
Downloaded and installed. As I expected, it didn’t solve the problem. My brief research on Google shows that the most likely culprit is that my Python installation is somehow meant for a 32-bit system (I installed 64-bit DSON), The problem is that I got Python with Poser and know nothing about how Python works independently, so I have no clue how to verify that this is a case of architectural mismatch.
So, if I have this right…there is a limited number of items that can be imported into PP2012. Not complaining….I just want to be sure I’m not missing anything. For example, if I make a Sabatic Goat or a Chibi girl in DS4.5….can that be imported into PP?
Content needs to be in DS 4.5 format (.duf files) and needs to have a Python script anda Poser library file that calls the script. You can set things up by hand, even without DS, using the existing stuf as a guide but I wouldn’t want to do it for a big project. Pretty well all content should be getting updated - some, the stuff in 4.0 format, will need updating and all will need the companion files added.
Yikes! I’m too dull-witted for that. I’m sure a lot of stuff will be coming down the pike. All is good.
i use 2010 pro.
and i only coth the poser esentials instald,,1.6 dpc
and the program dson poser installer in the map c program files x 86 smid
and i poet the contens in a sepered map,,and i lodet the runtime in poser,,the maps are thare buth when i klik on it i geth the messits,,this is a newer fersion?? poser whil trai to load it anny way?
and than i ceth the messits that thare is not a program? inporterror no module named dson. dzdsonimporter
This will only work in Poser 9 or PP2012—earlier versions do not have weight-mapping and do not have the plugin capability.
that is strains becos poser pro2010 is newer as poser 9 ??
There are also a fair number of freebies, and some Prime items at Rendo (as well as some full price items). Any DS4 Genessi clothing can be made to work, by the creator or - if a copy of DS 4.5 is available - by the end user. I haven’t tried saving an AutoFitted Gen 4 item and generating a conmpanion file for it, but it won’t work in Poser (unless PhilC’s Wardrobe Wizard Plugin works - and I would think it would, since the figure’s rigging is the same as the exported CR2).
I did try to render and there is just a blank screen..it is like when you try to load an obj file..and the obj file cannot be found…the drop down list says it is there..but actually it is not.
I had the same thing happen on my initial install…give me one sec.
i use 2010 pro.
No, Poser 9 and PP 2012 came out a year ago, PP2010 came out alongside Poser 8.
i use 2010 pro.
No, Poser 9 is newer - it was relased at the same time as PP 2012.
i use 2010 pro.
PoserPro 2010 is the Pro sibling of Poser 8, Poser 9 or PoserPro2012 are the requirements for the importer (or for loading the CR2 exported directly from DS) as they are the versions that have weight-mapping.
