whell i coth 6 runtime maps,,and 2 smid poser 8-2010 pro,,
and thwe installer poet the starter in poser 2010,,buth my qwestion is now,where do al the maps co in poser,,in the map c program files,
or in the map c program files (x86) becos windows 7 yuse 2 directions,,
i poet the esentials in a seppered map,becos the installer and i dont know ware to poet them,,so i have a buns of maps 12 and i dont know ware to poet them.by hand??
Content should not be installed to Program Files or Program Files (x86). Are you using Poser 9 or PP2012 with SR3?
i use 2010 pro.
and i only coth the poser esentials instald,,1.6 dpc
and the program dson poser installer in the map c program files x 86 smid
and i poet the contens in a sepered map,,and i lodet the runtime in poser,,the maps are thare buth when i klik on it i geth the messits,,this is a newer fersion?? poser whil trai to load it anny way?
and than i ceth the messits that thare is not a program? inporterror no module named dson. dzdsonimporter
So, if I have this right…there is a limited number of items that can be imported into PP2012. Not complaining….I just want to be sure I’m not missing anything. For example, if I make a Sabatic Goat or a Chibi girl in DS4.5….can that be imported into PP?
If you make it in DS4.5 you can—there are Genesis products which were made before DS4.5 which need to be converted to .duf format, either by the PA/DAZ 3D or by you using DS 4.5.1.6
Just tested the new DSON Importer for Poser, in PP 2012, it’s cool! Didn’t have a single problem when testing it. Can’t see any content than that which is in Genesis Starter Essentials though, even though it seems to use the DAZ Library.
Nice to know! I doubt Genesis will replace Gen4 for me just yet, but there are times it would be nice to use—M5, particularly, and hopefully soon Luthbel’s sets. How long will the stuff that’s on sale be on sale?
Question: what’s the “Core” vs the “Poser Companion”? I didn’t download the former, thinking it to be for computers that used DSON in a more fundamental way. Now that I read more about it, though, it seems DSON doesn’t work that way. That’s the only other mistake I can think of that I may have made. I’m downloading it now (or trying to, since it seems to be unusually slow).
Core has the textures and geometries, the Poser companion just has the Poser library files to load those. You do need both.
i use 2010 pro.
This will only work in Poser 9 or PP2012—earlier versions do not have weight-mapping and do not have the plugin capability.
Content needs to be in DS 4.5 format (.duf files) and needs to have a Python script anda Poser library file that calls the script. You can set things up by hand, even without DS, using the existing stuf as a guide but I wouldn’t want to do it for a big project. Pretty well all content should be getting updated - some, the stuff in 4.0 format, will need updating and all will need the companion files added.
I did try to render and there is just a blank screen..it is like when you try to load an obj file..and the obj file cannot be found…the drop down list says it is there..but actually it is not.
And you installed both the Core and the Poser Companion Files?
