Digital Art Zone
1 of 2
1
Another reason I hate painted on brows…
Posted: 30 May 2012 09:47 AM   [ Ignore ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Has anyone noticed that when you’re using Subsurface Scattering that your eyebrows lose their definition so much that they’re barely there and look like they’re a smudge?  UHG!  It’s just another reason I despise the practice of painting eyebrows onto the main texture!  I always hated it, because it always killed the ability of render artists to change the brows out, but this is just another reason why I think it’s a horrible idea.
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 30 May 2012 12:37 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Have you tried using the skin textures as a SSS strength map? If the brows are darker than the est of the skin that might help a bit.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 30 May 2012 12:53 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
That’s what I do 100% of the time.  The results are better, but still unsatisfactory.
 Signature
My ShareCG Gallery
Profile
Posted: 30 May 2012 03:55 PM   [ Ignore ]   [ # 3 ]
New Member
Avatar
Joined  2007-04-10
I’m with ya 100% I also cannot stand burned-in highlights on the skin/cornea/iris either, but I do see the artistic merit for them to be there, as they’re excellent for stylistic renders, plus they’re already included in the photo ref sites for the most part. That’s why I like Daz’s textures as they don’t have the highlights, nor breasts/glutes burned into the texture either…I forgot to mention those black nostrils, because they look completely unnatural if you’re trying to go for realism over the stylistic approach…
However, the nostrils/eyebrows are easy enough to fix, simply edit them out with the stamp/healing brush. wink
Image Attachments
 Signature
This is my avatar…
Profile
Posted: 30 May 2012 04:03 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2006-06-12
Wancow, are you a Daz Studio user? I could whip you up some fibermesh brows pretty quickly if that’s the case, and they’d naturally follow Genesis’ morphs.
Facial fibermesh for Daz figures in poser is a bit more of a hassle.  With a figure like Apollo, I could just morphing clothes all of the morphs in and make the facial hair superconforming, since there’s a one to one relationship between the dials and the morphs they affect.  V4 and M4 are much less direct in that many of their facial morphs are actually control dials which affect multiple morphs at once.  You try to transfer that using morphing clothes and the results are pretty ugly.
But yeah, I could make Genesis brows in both masculine and feminine varieties in less than a couple hours, I’m sure.
 Signature
My Daz Store
ShareCG Freebies
Tumblr
Profile
Posted: 30 May 2012 04:49 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2003-10-09
Joequick - 30 May 2012 04:03 PM
If that were a product, I’d buy it. I do have the Genesis Eyebrows, and they work fairly well, but they don’t conform completely to all morphs (eg. Chibi-Boy). I haven’t tested it extensively but I think the farther you go off “norm” the more problems.
A set of eyebrows that worked with any (or even most) morphs with both a male and female style would certainly be worth purchasing to me.
—Walt Sterdan
Profile
Posted: 31 May 2012 01:29 AM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2006-06-12
Here are some eyebrows.  They’re texture-less, so read the description for some pointers on how to set up your shaders (basically, save the shader setup from your favorite hair prop as a shader preset, strip out the textures, and then apply it to the brows).
They’re 10,000 poly, so I wouldn’t fill a room with them.  At their base resolution they’re composed of three sided strands of polys three polygons in length.
http://www.sharecg.com/v/62327/view/21/DAZ-Studio/Free-Genesis-Fibermesh-Eyebrows
Image Attachments
 Signature
My Daz Store
ShareCG Freebies
Tumblr
Profile
Posted: 31 May 2012 04:57 AM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2004-10-19
Thank you so much! grin
Profile
Posted: 31 May 2012 09:53 AM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
wsterdan - 30 May 2012 04:49 PM
—Walt Sterdan
DITTO DITTO DITTO!  Yes, am a D|S4 User (and huge Genesis Sycophant)
 Signature
My ShareCG Gallery
Profile
Posted: 31 May 2012 09:57 AM   [ Ignore ]   [ # 9 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Joequick - 31 May 2012 01:29 AM
Amazing!  Thank you so VERY MUCH!
 Signature
My ShareCG Gallery
Profile
Posted: 31 May 2012 10:03 AM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
this is a simple test with the Die Trying Eyebrow Arc Morph!  THEY WORK YYEEEEHAW!
Image Attachments
 Signature
My ShareCG Gallery
Profile
Posted: 31 May 2012 10:07 AM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Joequick, I’m looking at the UVS in UVMapper and it shows that some of the geometries are outside of the zone, which means they’ll tile… would you like me to correct them, and extend them over the entire UVS area (they currently only occupy half) and send it to you?
 Signature
My ShareCG Gallery
Profile
Posted: 31 May 2012 10:13 AM   [ Ignore ]   [ # 12 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Actually… here’s something else I could do, is create a UVS file, assuming I could figure out how it works, to apply to the new eyebrows.
Here’s something that might work since we could make them thinner with transparency:
That said: IF you decide to make say, six different brows and put them up for sale: I WILL BE YOUR FIRST CUSTOMER!
Edited to remove over-sized images http://www.daz3d.com/forums/viewannounce/510_98/
 Signature
My ShareCG Gallery
Profile
Posted: 31 May 2012 10:28 AM   [ Ignore ]   [ # 13 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
More Die Trying morphs, this time with the Bree No Brow texture.
One thing I did notice, I tried the Pose morphs, and those don’t seem to get along with the new brows.  Not a huge problem, as we happen to have this neat thing called “deformers” but in a product it’ll be nice if they had those too.
Can anyone clue me in as to how to apply a UVS file to a mesh in D|S4?
Image Attachments
 Signature
My ShareCG Gallery
Profile
Posted: 31 May 2012 01:49 PM   [ Ignore ]   [ # 14 ]
New Member
Avatar
Joined  2007-04-10
Thanks a lot for the free eyebrows, not everything should be up for sale, as there are those of us who can’t dispose of any of their income! smile
Image Attachments
 Signature
This is my avatar…
Profile
Posted: 31 May 2012 02:31 PM   [ Ignore ]   [ # 15 ]
Active Member
Avatar
RankRank
Joined  2006-06-12
takezo_3001 - 31 May 2012 01:49 PM
Don’t go thinking I’m particularly saintly.  I’m all about making money on product. I just don’t feel comfortable selling things where I know the software has done more of the work than I have.  I’ve seen a fair deal of people use a lot of hyperbole, when really genesis fibermesh hair is very simple to make.  The only real hurdle is the cost of entry, purchasing zBrush.
 Signature
My Daz Store
ShareCG Freebies
Tumblr
Profile
1 of 2
1
