There must be difference from pose.duf with pose.dsa
if I set ds 4.5 preference pose preset dialog “show the preset exceeding limits” (I think it is diffault setting )
I think when apply pose file with out of limits rotation, ds must show dialog.
but if I saved the pose as dsa , when I apply it, the dialogue never show up.
the value just stop at max limits of the node.
of course if you changed the limits by parameter tab, or top menu, before loading the dsa pose file,
you can apply the correct value.
but I do not like, everytime change setting of node rotation for some poses.
and many user do not think so. (I think your friend too)
in many case, it is better not to change limit of rotation, because
the figure shape is adjusted in the limits. so if you change setting limits off
ordinally, and pozing it, the shape of body change ugly.
it may cause another difficulty when you pozing your figure by manually
by pose tool, etc.
but, if I saved the pose as duf pose preset, when I load it,
dialogue show up, and ask me. to use the limit off.
the “off limits” only work about current figure, and current node.
even if you use zero figure, about the node status keep ” limit off “
untill you delete the figure from the scene.
but you load new figure, the figure has lmits of the rotation.
so you better not save as dsa. I think. I feel, pz seems same as duf.
so I recommend if you make pose, save as poser type file.
because duf can not use , ds 4.0.3 and ds 3 etc,,
if your friend ds is ds 4.5, you just make pose as duf,
and present the pose with massage your friend as same as matty said,,
“please use these poses, by setting
Edit>preferende>content libraly >“show the preset exceeding dialogu”
I want to check about dsf pose file,, but,, now I do not install the ds 4.0.3 sorry@@;
