Digital Art Zone
1 of 2
1
Low-lying, cotton-candy-like fog in Daz Studio 4.5. Is it possible?
Posted: 08 October 2012 09:43 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2005-07-29
I need some low-lying, cotton-candy-like fog for a render in Daz Studio 4.5. Is it possible and, if so, how?
I was hoping to avoid post and doing it in render.
 Signature
<End of transmission from Oz>
TUTORIAL - Creating a Genesis Full Body Morph for DAZ Studio Pro 4 by RKane_1
TUTORIAL - Creating a Genesis Partial Body Morph in DAZ Studio Pro 4 Using the DForm Tool by RKane_1
TUTORIAL - Applying Shaders by RKane_1 (as stolen blatantly from Jaderail)
Profile
Posted: 08 October 2012 09:58 PM   [ Ignore ]   [ # 1 ]
New Member
Avatar
Joined  2007-06-17
Have you tried this tool from Nerd3D : http://www.daz3d.com/shop/fog-tool-deluxe-iii/
It may give you what you need or at least be a starting point smile Hope that helps,
BellaDragon smile
 Signature
Anything purple is mine! Everything else can be dyed or painted
If you can’t handle the flames, don’t poke the dragon.
For all your testing requirements, put your trust in our team: TheDreamTeamProject
CreekyPointStudios - creators of high quality Poser & DS content @
http://www.yurdigital.com
http://www.fantasiesrealm.com
Post Count: add 470
Profile
Posted: 08 October 2012 10:00 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2005-07-29
Are you sure that it works in 4.5, though? Or can someone confirm it does?
 Signature
Profile
Posted: 08 October 2012 10:06 PM   [ Ignore ]   [ # 3 ]
New Member
Avatar
Joined  2007-06-17
Gimme a few minutes and I’ll take a look for you - I may need to reinstall it though, but I will be back soon with an answer smile
BellaDragon smile
 Signature
Post Count: add 470
Profile
Posted: 08 October 2012 10:06 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2006-04-16
No idea if that works. Hope it does. An alternate would be pwEffect and creating a primiive plane with a wavey displacement map then playing around witth the effects until you get the look you want. I did once in a render a long time ago.
 Signature
My DeviantArt Page.
The main Supersuit comes with a Basic Suit. It’s UV’s are messed up, making it impossible to do our own textures beyond the basics. Please click here and let Daz know they need to fix this problem. Thank you for your support..
Profile
Posted: 08 October 2012 10:07 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2006-04-16
*Crosses fingers, hopes it works* smile
 Signature
My DeviantArt Page.
Profile
Posted: 08 October 2012 10:37 PM   [ Ignore ]   [ # 6 ]
New Member
Avatar
Joined  2007-06-17
Ok - it seems to work in DS4.5 just fine - there are many options to adjust the planes & the levels of fog (so many options) - this is a very quick & not very good render that I threw together to show the tool in DS4.5 smile With adjustments you could probably get the look you are after smile hope that helps smile
*The Gorilla is between several vertical planes - that is why the effect looks a little odd - with adjustments that cut through effect could be reduced, but I wanted to get an answer to you fast smile
BellaDragon smile
Image Attachments
 Signature
Post Count: add 470
Profile
Posted: 08 October 2012 11:31 PM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2006-04-16
YAY! Thank you. smile
 Signature
My DeviantArt Page.
Profile
Posted: 09 October 2012 01:32 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2005-07-29
Thanks for the quick response!
I appreciate it!
 Signature
Profile
Posted: 09 October 2012 05:37 AM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
You already have a “tool” installed for this, it’s called UberVolume and you’ll find it under shader presets, just create a primitive to cover the area you want the fog to be in and apply the base shader or one of the presets to it, do a spot render and tweek the settings till your happy.
 Signature
**shuffles of with a new headache** tongue wink
Profile
Posted: 09 October 2012 06:17 AM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
Another example with the Fog Tool, I recently checked this out in 4.5 and it needed the settings tweaked in the surfaces tab, but nothing particularly complex:
Image Attachments
Profile
Posted: 09 October 2012 06:52 AM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2005-07-29
Forgot pic, DWG?
 Signature
Profile
Posted: 09 October 2012 07:15 AM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
No, picked the thumbnail by mistake - fixed now!
Profile
Posted: 09 October 2012 07:20 AM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2005-07-29
Cool… Thanks for the post, DWG! smile
I was hoping in what I was doing, though, to have a little texture to the fog. A bit of swirling mists type thing. Any suggestions?
An example:
Image Attachments
 Signature
Profile
Posted: 09 October 2012 07:44 AM   [ Ignore ]   [ # 14 ]
Member
Avatar
Rank
Joined  2005-10-10
You could try this item @ RDNA
http://www.runtimedna.com/RDNA-Atmospherics-Fog-Vol-1.html
best of all, it’s free (just need to register). It is just planes that you can move around. I’m getting ready to use it in a render I’m currently working on.
Hope this is helpful smile
Profile
Posted: 09 October 2012 07:54 AM   [ Ignore ]   [ # 15 ]
Active Member
Avatar
RankRank
Joined  2005-07-29
Do you have a render of it to show off?
I would love to see it in action.
 Signature
Profile
1 of 2
1
