Digital Art Zone
Detect if an object is modified
Posted: 08 October 2012 05:34 AM   [ Ignore ]   [ # 3 ]
New Member
Joined  2009-10-15
If your object inherits from DzObject, the DzObject::drawnDataChanged() signal should o the trick.
Profile
Posted: 08 October 2012 05:45 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2007-09-12
Isn’t something like that is the DzScene? I should not inherit from DzObject,.
 Signature
Favourite Figure: Victoria 5
My Art Gallery: http://mattiascibien.azurewebsites.net/3d-art/
Developer of CameraReady for DAZ Studio (thesis project).
Profile
Posted: 08 October 2012 05:50 AM   [ Ignore ]   [ # 5 ]
New Member
Joined  2009-10-15
That one is actually also called drawnDataChanged().
So if you connect to the dzScene->drawnDataChanged() signal, it should, at least conceptually, work smile
Profile
Posted: 09 October 2012 05:17 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2007-09-12
The problem is that I should able to get the geometry of the modified node in another class and drawnDataChanged() doesn’t seem go pass me the DzNode.
EDIT: can i do that with a cas on QObject::sender() in my slot?
EDIT2: sender() made my day but however using drawDataChanged() for a node is almost impossibile since it is called every time my Node il clicked other than moved, morpehed or similar.
EDIT3: by setting breakpoints i have detected that it acutally acts even during the manipulation? isn’t there anyway to detect whether an object manipulation ends?
 Signature
Profile
Posted: 09 October 2012 07:06 AM   [ Ignore ]   [ # 7 ]
New Member
Joined  2009-10-15
DzNode has its own implementation of drawnDataChanged(), so I guess you could hook up to that one instead of the DzScene one.
Without having tried it, I guess the problem with “spam” messages will stay the same though.
A simple solution could be to hook up to the selected signal ( DzNode::selected(DzNode* node , bool onOff) ) and spawn a manual update once the node is no longer selected.
Of course, this has it’s own drawbacks - but at least you can handle your internal magic in a single slot definition in your own program (switch on the node->getLabel()).
If I had a better idea on what your are trying to accomplice I might be able to give a better suggestion…...
Profile
Posted: 09 October 2012 10:30 AM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2007-09-12
I have to pass every geometry of the scene to Bullet Physics in order to get a Raycast. And my supervisor asked me to try to see if I can update the Bullet Wolrd only when objects are modified (and maybe update only the one I modify)
 Signature
Profile
Posted: 10 October 2012 04:01 AM   [ Ignore ]   [ # 9 ]
New Member
Joined  2009-10-15
Unless you are really keen on re-implementing DzNode I guess that the simple solution is to hook up to the DzNode::drawnDataChanged() signal and filter out the events you do not need.
I would do that by using a simple timer.
[pseudo code]
isInEdit false
drawnChanged
if isInEdit
      reset timer
else
isInEdit true
      set timer
for 2 seconds
OnTimerEvent
   isInEdit
false
   update the node
for render // This should ensure that the geometry has been finalized
send update to Bullet
Somewhat crude - but it should get the job done and you get a “per node” event.
Profile
Posted: 10 October 2012 07:46 AM   [ Ignore ]   [ # 10 ]
Member
Avatar
Rank
Joined  2007-09-12
look’s like a nice idea… However. If I subclass DzNode to detect if node is in editing mode will the subclass be on my scene everytime I add a DzNode or do I have to do a lot of casting?
 Signature
Profile
