Congratulations! You are a March Madness BONUS BUYER!
Enjoy 10% OFF* ALL PURCHASES STOREWIDE or enjoy 30% OFF items with a SKU number lower than 16000 & 30% OFF items from Runtime DNA.
Get 70% OFF featured Cookie & Chip items instead of 50% OFF - no additional purchase necessary. (Discount applies in Shopping Cart)
Offer valid for intended recipient only
* 10% discount DOES apply to Gift Cards and Memberships. **Items must be in cart simultaneously for discount to apply.
[ collapse ]
Detect if an object is modified
mattiascibienmattiascibien Posts: 135
Hello fellow developers,
I am continuously working on my bachelor thesis and I have found that I need to detect wether an object in my scene is modified. For example added, removed does not seem to be a problem but when it is modified (moved, rotated, scaled) or posed I am not able to find a signal for it in dzScene.
Is there some signal to detect whether an object is modified? I have seen a signal which tells me that an object needs to be redrawn but it does not seem to be my case.
Thank you for your help
(I will quote you in the acknowlegments obviously)
  • edited December 1969
    If your object inherits from DzObject, the DzObject::drawnDataChanged() signal should o the trick.
  • mattiascibienmattiascibien Posts: 135
    Isn't something like that is the DzScene? I should not inherit from DzObject,.
    That one is actually also called drawnDataChanged().
    So if you connect to the dzScene->drawnDataChanged() signal, it should, at least conceptually, work :)
    edited October 2012
    The problem is that I should able to get the geometry of the modified node in another class and drawnDataChanged() doesn't seem go pass me the DzNode.
    EDIT: can i do that with a cas on QObject::sender() in my slot?
    EDIT2: sender() made my day but however using drawDataChanged() for a node is almost impossibile since it is called every time my Node il clicked other than moved, morpehed or similar.
    EDIT3: by setting breakpoints i have detected that it acutally acts even during the manipulation? isn't there anyway to detect whether an object manipulation ends?
    Post edited by mattiascibien on
    DzNode has its own implementation of drawnDataChanged(), so I guess you could hook up to that one instead of the DzScene one.
    Without having tried it, I guess the problem with "spam" messages will stay the same though.
    A simple solution could be to hook up to the selected signal ( DzNode::selected(DzNode* node , bool onOff) ) and spawn a manual update once the node is no longer selected.
    Of course, this has it's own drawbacks - but at least you can handle your internal magic in a single slot definition in your own program (switch on the node->getLabel()).
    If I had a better idea on what your are trying to accomplice I might be able to give a better suggestion......
    I have to pass every geometry of the scene to Bullet Physics in order to get a Raycast. And my supervisor asked me to try to see if I can update the Bullet Wolrd only when objects are modified (and maybe update only the one I modify)
    Unless you are really keen on re-implementing DzNode I guess that the simple solution is to hook up to the DzNode::drawnDataChanged() signal and filter out the events you do not need.
    I would do that by using a simple timer.
    [pseudo code]
    isInEdit = false
    drawnChanged
       if isInEdit
          reset timer
       else
          isInEdit = true
          set timer for 2 seconds
    OnTimerEvent
       isInEdit = false
       update the node for render // This should ensure that the geometry has been finalized
       send update to Bullet
    Somewhat crude - but it should get the job done and you get a "per node" event.
    look's like a nice idea... However. If I subclass DzNode to detect if node is in editing mode will the subclass be on my scene everytime I add a DzNode or do I have to do a lot of casting?
