Digital Art Zone
Got the Supersuit for Genesis but nothing will load
Posted: 30 May 2012 04:24 AM   [ Ignore ]
New Member
Joined  2008-09-27
hi,
Just Got the Supersuit for Genesis last night but nothing will load. I click on the pre-set characters such as Fury, and nothing happens.
Is there something I need to click on first, before clicking on the pre-sets?
I do have a problem with having lots of ‘content’ folders. Even when following the prearranged file path when installing I still end up with lots of content folders. I don’t know if that is why the Supersuit will not load though.
When loading content on a mac can someone tell me what is the correct file path?
What is the best place to install Daz Studio (4)?
If anyone has any advice I’d appreciate it.
I am using a apple mac, Mac osX 10.5.8
Profile
Posted: 30 May 2012 07:05 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2006-09-09
this is going to sound like a strange question, but you are loadign the supersuit (not hte basic one) and then selecting it and clicking on the preset? (and btw, the presets can take a little bit to load apparently) Apologies if you’re rolling your eyes right now and going “duh” LOL, but it has been known to happen before (yeah i’ve done it myself in a senior moment) :D
Profile
Posted: 30 May 2012 12:35 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2008-09-27
What you typed was not silly:)
After reading what you typed I had another go and finally found what I needed to click on. I had to click though 4 different locations to find the supersuit loader thingy.
Now I need to find my way back to the presets lol.
Thanks for your reply.
Peter
Profile
Posted: 30 May 2012 05:45 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2003-12-06
pduffy4 - 30 May 2012 12:35 PM
Odd, shouldn’t the presets folder be inside the location you loaded the actual supersuit object from? You should be able to see it in the Content Library tab. Unless you’re using the Smart Content tab, that works by different rules.
Although I have noticed already some products have parts installed by default in some very unobvious places. I don’t use Smart Content, so I always install manually and re-sort folders manually so that related bits and pieces (e.g. customised poses, expressions, props etc.) are together.
 Signature
Gone to Vegas to play poker. Back when I run out of clothes.—Your Muse.
Profile
Posted: 01 June 2012 03:20 AM   [ Ignore ]   [ # 4 ]
New Member
Joined  2008-09-27
SpottedKitty - 30 May 2012 05:45 PM
They are in two different folders. I don’t know enough about how DAZ works to start moving folders around unfortunately.
Profile
Posted: 01 June 2012 07:27 AM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
I cannot use smart content on it, nothing happens and I have reimported metadata etc
but from the content library under content, Daz, people, Genesis, wardrobe,supersuit everything works fine.
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
