Digital Art Zone
How can I see the rendered output of my objects.
Posted: 05 October 2012 04:39 PM   [ Ignore ]
Member
Rank
Joined  2011-10-27
I’ve scanned the manual etc and also examined all the menus on the Hexagon program and I cannot see for the life of me - an option to render / view the object as it is without all those lines.
... and whilst I am on the subject of viewing objects, can you apply material effects to the surfaces in Hexagon or is that done later in Bryce - should I expect to model in white only surfaces?
Thank you in advance for your feedback.
Terry
Profile
Posted: 05 October 2012 05:08 PM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2009-01-27
tdrd - 05 October 2012 04:39 PM
...I cannot see for the life of me - an option to render / view the object as it is without all those lines
Hexagon doesn’t have a rendering engine per se, but it will display a colored and textured model.
To see your model without the mesh gridlines, you have to deselect it. Selecting all or part of your model shows the gridlines on the selected areas.
Look on the left-hand side of your work area, and click on the little blue arrow mark in the middle.
This opens up the materials window, and here you can assign colors and/or texture maps to the various materials.
Colors can be assigned to materials with or without the model being UV mapped, but to apply TEXTURE MAPS you must UV map the model first.
Probably the best way to see how this works is to get an OBJ file of a model that has already been mapped and textured. Load that model into hexagon and hexagon will load and assign the colors and textures from the OBJ file’s MTL file.
 Signature
For any arguments or illustrations I give, my system specs are:
Hexagon version 2.5.1.79,  XP pro 32 bit,  pentium core2 duo,  ATI radeon 3870, 2 gigs ram
Profile
Posted: 06 October 2012 12:02 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
If you look way down in the bottom right corner there is a camera - that lets you do a render of the current view - the sphere next to it does this with ambient occlusion and the last two spheres in the fourth box from the right lets you do a view or render under different light conditions and with AA and shadows.
Profile
Posted: 09 October 2012 11:07 AM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2005-01-15
You could export your object as an OBJ file and render it in Daz Studio, it is free at the moment so why not give it a try.
Profile
