Digital Art Zone
Conforming clothing for Genesis child
Posted: 05 October 2012 04:32 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Hi there smile
I made this mermaid tail to fit the Genesis child.  The idea is to use it as conforming clothing, adding boes to make it more flexible and hiding the Genesis legs.  I used an .obj export to fit it in Hexagon.  When imported to Studio, it fits perfectly, but after putting it through Utility Transfer, it scales down.
Obviously the problem is that I used the child as a mannequin.  So tried fitting by scaling it up to a basic genesis figure in Hexagon, using the transfer Utility then shaping to the child.  This works as far as length scaling goes, but no longer fits around the waist - the proportions between adult and children are not simply one of linear scale.
I have used smoothing with collision detection, with 100 iterations, but there remains an offset around the waist.
Is there any way to get it to fit - surely clothing can be made for the Genesis figures, not only for the base shape?
Secondly, if this is not possible, would making the tail into a figure in it’s own right and parenting it to Genesis work in an animation?
Image Attachments
Profile
Posted: 05 October 2012 04:49 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
The child shape includes scaling - one option may be to take your original shape and in the Transfer Utility, under Source shape choose Current, and in the extended options choose reverse Source shape from target.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 05 October 2012 08:24 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Thanks once again - Richard to the rescue - worked like a charm.smile
You should write a book on the CCT
Profile
Posted: 05 October 2012 08:41 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Wow, Richard…answering a question I didn’t even know I needed to ask.  I suppose that this would work if there are custom sculpts involved, too.
And thanks, Roygee for putting words to the problem…
I was having the same problem, but hadn’t figured out exactly what to ask, if anything, yet.
Basically, I’m making some alien morphs and am having a hard time with clothing intersecting.  And yes, I’m planning on at least one item of clothing specifically made for the one morph.  So, when I rig that item, I should be using ‘current’ (of course, having the morph dialed in, first), as the shape, right?
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 05 October 2012 10:31 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
As I bit-by-bit peel back the mysteries of the CCT (with Richard’s help), I come to realize why it’s taking so long to get documentation released - there are just so many options to this wonderful tool that it would take a book on it’s own.smile
Profile
Posted: 05 October 2012 11:29 PM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
That and the problem is that the people who do know the most about it aren’t actually involved in the documentation process…except maybe, indirectly.
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 06 October 2012 03:52 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2005-08-25
Roygee - 05 October 2012 08:24 AM
I would like to see that book wink
to bad we all searching for the hidden secrets and manual.
very frustratring to play in studio without the hidden secrets explained well.
 Signature
DAZSTUDIO FUTURE REQUESTS - CLICK ME TO JOIN
Feel free to join, sign and vote for dazstudio future improvements.
(550 users and still counting up to 1000) would like to see improvements, and you?
What features would you like to see appear in dazstudio 5?
Profile
Posted: 07 October 2012 10:17 PM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
OOPs - an unexpected outcome.
When I had the tail fitted and conformed as clothing, it took on the shape of the thighs and the part below the thighs flattened out snf the flukes distorted.  I expected that, as it would be trying to conform to competing bone influences.
After giving the tail its own rigging and getting rid of all other influences, I expected it would go back to the original shape - but no.  It is still conforming to non-existent thighs and the center part looks like the air has been sucked out of it.  It deforms beautifully otherwise and I have checked that it does not react at all to rotations of the Genesis rigging, which is what I want..
Any ideas on how to re-inflate the tail?
Image Attachments
Profile
Posted: 08 October 2012 02:50 AM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2005-08-25
Roygee - 07 October 2012 10:17 PM
I would discuss this with the daz developers, to see if this is possible to do or not?
Or else make this a future request as some morphing between skeleton sounds useful in this case the Mermaidtail.
i still would like to see the genesis legs+feet morphing to tail and have a tail control rig available.
 Signature
Profile
Posted: 08 October 2012 03:38 AM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Thanks - looks like conforming clothing is the wrong option for this.  I’ll try making the tail as a character and parenting it, see how that goes.
I did see a video of someone morphing Genesis into a mermaid using ZBrush.  I tried doing it using Sculptris - looked good until I applied the morph and it simply exploded.smile
Profile
Posted: 08 October 2012 07:26 AM   [ Ignore ]   [ # 10 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Is this with the figure unmorphed, or after applying a morph? If it’s after applying a morph, and you didn’t supply your own, then the auto-generated morph may give undesirable results - the fix is to replace it with a custom morph that does only what you want. Also, have you applied a smoothing modifier to the tail?
 Signature
Profile
Posted: 08 October 2012 08:35 AM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Are you asking about the mermaid tail or the mermaid i morphed in Sculptris?
If about the tail, I fitted it to Genesis child - the tail has no morphs and I never applied any morphs after fitting.
If about the morph I did in Sculptris, this was the Genesis female, exported as .obj, morphed in Sculptris without changing number of verts, imported as a morph target with morph loader pro.
Profile
Posted: 08 October 2012 12:59 PM   [ Ignore ]   [ # 12 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I was asking about the tail that developed odd deformations when fitted in DS - applying the child shape is applying a morph, and if you are relying on the auto-generated morph it may well account for the distortion; what happens if you fit the tail to a base Genesis?
 Signature
Profile
Posted: 08 October 2012 02:39 PM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
OK - I understand:)
When I fit a scaled-up version of the tail to a base Genesis using the Transfer Utility, I get pretty much the same result, only less pronounced.  When I apply it using an option I’ve only now discovered - simply “make clothing”, I get an almost perfect result.  Haven’t had time to tweak the weights yet, but I’m sure this will get me where I want to be.  It also morphs perfectly with all the Genesis shapes, so I can get a whole family out of this.
Will just have to re-model the waist to fit the base figure nice and snug.
So, I suppose, to answer my original question, it is possible to model clothing for the Genesis child, as long as it covers the body in the conventional sense, and not have a part hanging between the legs?  That was the part which gave the trouble - from the knees down, with the shin and feet bones on either side exerting influence which I could not get rid of.
Profile
Posted: 08 October 2012 03:19 PM   [ Ignore ]   [ # 14 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Yes, or simply replace all of the lg bones with new bones though that might be tricky (a lot of influences to remove). However, it is odd that it would happen with a fully zeroed figure at all.
 Signature
Profile
Posted: 08 October 2012 10:32 PM   [ Ignore ]   [ # 15 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Yes, I had replaced all the leg bones with a series of bones down the centre, removed all the influences.  Checked that the influences were removed by rotating the Genesis legs - all was fine in that department, yet the original leg influences which had distorted the mesh remained.  May have something to do with the templates - there is nothing for a long dress, for instance.
Anyway, all’s well that ends well.  When I have the time, I’ll test with a long loin-cloth, see what happens.
Thank you all for all your help:)
Profile
